Author Topic: Command Line output wider???  (Read 1782 times)
whdjr
« on: March 13, 2007, 12:41:02 PM »
My command line goes all the way across my screen (approx 18") but text only shows up on the first 6" of it.  Is there a way to make the information shown at the command use the entire width of the command line?
Dinosaur
Re: Command Line output wider???
« Reply #1 on: March 13, 2007, 05:19:05 PM »
You can undock it and set it to the size you want.  Depending on where you place it, you may need to hold down the control key to keep it from docking.
« Reply #2 on: March 13, 2007, 06:23:54 PM »
No. It's based on the old display limit of 80 characters
can be demonstrated :
Command: 123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890
Unknown command
"1234567890123456789012345678901234567890123456789012345678901234567890123456789
01234567890".  Press F1 for help.
Dinosaur
« Reply #3 on: March 13, 2007, 07:01:55 PM »
  :-o Sheesh . . . I finally get a chance to log on and even read some posts so I first thing go muff an easy ground ball.   :oops: That will teach me to try to read and attempt intelligent answers with a kitten alternating between my shoulder and the top of my head for a perch!
whdjr
« Reply #4 on: March 13, 2007, 07:17:58 PM »
So can it be changed or do I have to suffer indefinitely?   :-(
« Reply #5 on: March 13, 2007, 07:22:36 PM »
If it's changed then redirecting console output to file or printer will also be affected.
.. thats not saying you couldn't start a campaign to have it changed ...
sinc
« Reply #6 on: March 17, 2007, 11:24:16 AM »
I do like Dino said, and undock it and resize it.  At work, with a single 20" monitor, I resize it so that it is about five lines high and a bit less than half the screen width - this is big enough to show everything I'm interested in, while covering less than half the screen real-estate of the docked toolbar.
At home, with two monitors, I undock the command window and move it to the second monitor, where it's about 12 lines high, and only wide enough to display an 80-character line.
Undocking the command window caused me to have all sorts of problems with my Nostromo n52, but I decided that with the new customizations offered by the CUI, I didn't need the n52 anymore.
whdjr
« Reply #7 on: March 20, 2007, 09:47:15 AM »
Thanks for the examples Sinc.  I am happy with my Command Line where it is I just want it to use all it's allocated screen real estate.
sinc
« Reply #8 on: March 20, 2007, 08:38:21 PM »
That's kind of what I was saying.  You can't use the real estate for text, but if you undock your command window, you can use the real estate for other things.  The attached image shows how I generally configure my setup at work, with a single monitor.
