I am having trouble with a vba to update an individual blocks attributes,
you pick tha ansewrs for existing data in the drawing I am testing for acadblock block name then the correct block attribute hence then update (I have 11 attributes in block)
I can not see where I am going wrong some of the lineses have been cut out to make email shorter a fresh set of eye may see the obvious, I had it working but found problems outside of test dwg so I know the code is 99%
Public Sub ModifyPitSchedule4()
' puts in 2 Pts x and y
Dim SS As AcadSelectionSet
'Dim objENT As AcadEntity
Dim Count As Integer
Dim val, pitname As String
Dim PitNameSelect As AcadObject
Dim basepnt, pt1, pt2, pt3 As Variant
Dim attribs As Variant
On Error Resume Next
Set SS = ThisDrawing.SelectionSets.Add("MYSS2")
SS.Select acSelectionSetAll
val = "SCHEDTEXT" ' this is block name
ThisDrawing.Utility.GetEntity PitNameSelect, basepnt, "pick pit name : "
If PitNameSelect.ObjectName = "AcDbText" Then
pitname = PitNameSelect.TextString
MsgBox "pitname selected is " & pitname
End If
If PitNameSelect.ObjectName = "AcDbBlockReference" Then
pitblname = PitNameSelect.Name ' RETURNS BLOCK NAME
attribs = PitNameSelect.GetAttributes
pitname = attribs(0).TextString
End If
code here ok !!!!! lines removed for forum
pt1 = ThisDrawing.Utility.GetPoint(, " pick first point")
pt2 = ThisDrawing.Utility.GetPoint(, " pick 2nd point L ")
pt3 = ThisDrawing.Utility.GetPoint(, " pick 3rd point W ")
lengthpit = CStr(FormatNumber(lz, 0))
widthpit = CStr(FormatNumber(lz, 0))
code starts here again
For i = 1 To SS.Count
Set objENT = SS(i)
If objENT.EntityName = "AcDbBlockReference" Then
attribs = objENT.GetAttributes
MsgBox "1 ATTRIB name IS " & objENT.EntityName & "......" & objENT.Name & "......" & attribs(0).TextString
' NOT GOING IN HERE RETURNS BLOCK NAME
If objENT.Name = val Then ' this does not work
' attribs = objENT.GetAttributes
MsgBox "2 block name IS " & objENT.Name & "......" & i & "......" & attribs(0).TextString
'this finds blocks
If attribs(0).TextString = pitname Then
' update attribute values here.
attribs(1).TextString = txtx1
attribs(2).TextString = txty1
attribs(3).TextString = txtx2
attribs(4).TextString = txty2
attribs(5).TextString = lengthpit
attribs(6).TextString = widthpit
attribs(1).update
attribs(2).update etc etc
end all ifs etc
