Author Topic: Blocks..aaahh! theres more than twenty  (Read 8179 times)
DukeNukem
« on: March 08, 2007, 05:06:17 PM »
I only have 20 fingers and toes.  Therefor, if I have populated a drawing with say, 300 doors, and i cant count that high.  Dos'nt AutoCAD have a function to count a specific Block?  It seems that would be a normal need of designers.  I curntly use a ticker to count off of a plotted dwg. :ugly:
Greg B
  • Tell me a Joke!
Re: Blocks..aaahh! theres more than twenty
« Reply #1 on: March 08, 2007, 05:06:52 PM »
21
DukeNukem
« Reply #2 on: March 08, 2007, 05:09:09 PM »
cute.  If I cut my useless pinky's off, i could only go to 18 :lmao:
Tom
CADaver
« Reply #4 on: March 08, 2007, 05:21:46 PM »
bcount?
DukeNukem
« Reply #5 on: March 08, 2007, 05:30:45 PM »
bcount dosnt work in LT.  I do have autoCAD 2000i that is a full version.  I suppose I can save down and try it.  Ive never used bcount, is there anything I should know beforehand.
uncoolperson
« Reply #6 on: March 08, 2007, 05:35:48 PM »
(sslength (SSGET "X" (list '(0 . "INSERT") (cons 2 (getstring "look for what?" t)))))
dang, you just said LT
maybe try the quick select in the properties window
CADaver
« Reply #7 on: March 08, 2007, 05:36:27 PM »
dunno if it was available for 2000i
EATTEXT maybe in LT?
DukeNukem
« Reply #8 on: March 08, 2007, 05:57:19 PM »
i have no idea what EATTEXT means.  I typed it into LT and it dosnt know either
pmvliet
« Reply #9 on: March 08, 2007, 08:57:54 PM »
qselect should meet his needs. Not exactly pretty, but will get him a count.
That is looking at 2002LT.
Pieter
DukeNukem
« Reply #10 on: March 09, 2007, 10:34:55 AM »
oK, Ive tried qselect - i have: Current Selection, block reference, color, =equals, by block, include in new selection - now where do I find the 'count'?  Is it in the General list, Geometry, Misc, or Attributes :?
Josh Nieman
« Reply #11 on: March 09, 2007, 10:38:58 AM »
now that the selection is active, open the propertyies tab and see how many it lists as being selected at the top.
Kate M
« Reply #12 on: March 09, 2007, 11:03:53 AM »
Drop the E and try again. :-) (ATTEXT)
E means "enhanced" in commands like EATTEXT and EATTEDIT -- the "un-enhanced" versions work in LT if you drop the initial E.
DukeNukem
« Reply #13 on: March 09, 2007, 11:20:19 AM »
Wow. Thanks.  That qselect is a 'dirty' way but it will work.  I feel kinda dumb having not caut on to that before, though. Im gonna try the 'drop'n the E' in a little while Kate- i have to get some dwg's to the field, so i will try it when I get back.
Thanks to everyone!! :-)
uncoolperson
« Reply #14 on: March 09, 2007, 12:03:49 PM »
dukenukem, do you do any 3d? :lmao:
