(defun c:TRIMFNC ()(COMMAND "OSMODE" "0")(COMMAND "trim" "" "F" PAUSE PAUSE "" "")(COMMAND "OSMODE" "47"))
(COMMAND "trim" "" "F")(WHILE (/= (GETVAR "cmdactive") 0) (COMMAND PAUSE))
(defun c:tmm (/ ss pt1 pt2 usercmd *error*) ;vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv ;; error function & Routine Exit (defun *error* (msg) (if (not (member msg '("console break" "Function cancelled" "quit / exit abort" "") ) ) (princ (strcat "\nError: " msg)) ) ;;reset all variables here (setvar "osmode" useros) (setvar "CMDECHO" usercmd) ) ; end error function ;^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ (setq usercmd (getvar "cmdecho")) (setvar "cmdecho" 0) (setq useros (getvar "osmode")) (setvar "osmode" 0) (while (progn (prompt "\nSelect cutting edge(s): ") (if (setq ss (ssget)) (progn (command "._undo" "begin") (if (and (setq pt1 (getpoint "\nDraw line to select items to be trimmed: ")) (listp ptl) (setq pt2 (getpoint pt1 "\nPick end point. ")) (listp pt2)) (not (command "_.trim" ss "" "F" pt1 pt2 "" "")) ) ) ) ) ) (command "._undo" "end") (*error* "") (princ)) ; end defun(princ "\nType TMM to start.")(princ)
