Author Topic: point filter keyboard shortcut  (Read 2656 times)
hornet
« on: February 28, 2007, 11:34:02 AM »
hi everyone
;The idea behind this program is to cut down the keyboard keystrokes to just f12
;a line should be drawn along the "x" axis from a "picked" point
;then another line is drawn square to the original "x" axis line from another "picked" point
;somewhere else on the drawing, this is known as point filtering.
I'm stuck on the correct code on the second point pick, can anyone help.... please
many thanks
Hornet
dan19936
Re: point filter keyboard shortcut
« Reply #1 on: February 28, 2007, 12:59:38 PM »
Not sure if I understood your request correctly, but this is how I use point filters:
In my partial .MNS I modify the shift+right-click pop-up menu and type X or Y hotkeys to get the point filter, the menu macro just returns the X or Y value of the selected point. I had this in R12 way before object tracking. The first CAD system I used, AES, had this as a standard point entry feature. I believe I got the menu code from old softdesk menus.
The key concept is:
starting a line from point A
if you want the .X value of point B
type .Y or .YZ, then NON (no snaps) then @ (to use values of last point A)
AutoCAD then wants the X value, so select B
Dan
my entire POP menu for reference - custom point filters in Red
***MENUGROUP=A+S
***POP0
**SNAP
               [&Object Snap Cursor Menu]
ID_ZoomPrevi   [Zoom &Previous]'_zoom _p
ID_PanPick     [&Pan Pick]'_-pan
ID_TrackingOld [Rubberband Trac&king]_tk
ID_Tracking    [Temporary track point]_tt
ID_From        [&From]_from
ID_MnPointFi   [->Point Fi&lters]
ID_PointFilx     [.X].X
ID_PointFily     [.Y].Y
ID_PointFilz     [.Z].Z
ID_PointFixy     [.XY].XY
ID_PointFixz     [.XZ].XZ
ID_PointFiyz     [<-.YZ].YZ
ID_OsnapEndp   [&Endpoint]_endp
ID_OsnapMidp   [&Midpoint]_mid
ID_OsnapInte   [&Intersection]_int
ID_OsnapAppa   [&Apparent Intersect]_appint
ID_OsnapExte   [Extension]_ext
ID_OsnapCent   [&Center]_cen
ID_OsnapQuad   [&Quadrant]_qua
ID_OsnapTang   [&Tangent]_tan
ID_OsnapPerp   [& Perpendicular]_per
ID_OsnapPara   [Para&llel]_par
ID_OsnapNode   [No&de]_nod
ID_OsnapInse   [In&sert]_ins
ID_OsnapNear   [Nea&rest]_nea
ID_OsnapNone   [&None]_non
//Trap for pline command only taking 2d points
[color=red]               [Hold &X]$M=$(if,$(or,$(eq,$(substr,$(getvar,cmdnames),1,5),PLINE),$(eq,$(substr,$(getvar,cmdnames),1,5),PEDIT)),.Y,.YZ) non @
               [Hold &Y]$M=$(if,$(or,$(eq,$(substr,$(getvar,cmdnames),1,5),PLINE),$(eq,$(substr,$(getvar,cmdnames),1,5),PEDIT)),.X,.XZ) non @
               [Hold &Z].XY non @
[/color]               [--]
               [&1 Midpt of 2 pts]non (midpt)
               [&2 Last Point (@)]non @
               [&0 World Origin]non *0,0,0
               [Dwg Insertion &Base Pt]non (getvar "insbase")
               [Snap Base]non (getvar "snapbase")
ID_Osnap       [&Osnap Settings...]'_+dsettings 2
in the matching .MNL file to load the custom POPs
;;; ;;Replace the right mouse button pop-up menu
(menucmd "A1=A+S.AUX1")
(menucmd "A2=A+S.AUX2")
(menucmd "A3=A+S.AUX3")
(menucmd "A4=A+S.AUX4")
« Reply #2 on: February 28, 2007, 03:02:12 PM »
( (lambda ( / )
    (vl-cmdf "_line" PAUSE PAUSE "<<0")
    (while (eq (logand (getvar "CMDACTIVE") 1) 1)
           (vl-cmdf PAUSE))
    (princ)) )
« Last Edit: February 28, 2007, 08:31:11 PM by Se7en »
