Author Topic: Block Replacement lisp (continued)  (Read 7887 times)
CECE_CAD
« on: February 27, 2007, 10:24:18 AM »
I have been looking for a block replacement lisp and came to the swamp for the info.  I have found the (Block Replacement lisp post http://www.theswamp.org/index.php?topic=8823.0 that was posted last year.  Seeing that I'm a newbie to lisping/coding yes I read the whole post, I have a question about it.  I would like to keep the ability to pick the block that I want to change, then have the ability to insert any other block to replace it with.  The problem is I don't know how to add it to or change any of the "smaller" and simpler codes posted on here.
I have arch blocks (AL2x4) that I want to change to my company standard blocks (2x4fix)
« Last Edit: February 27, 2007, 10:42:46 AM by CECE_CAD »
CECE_CAD
Re: Block Replacement lisp (continued)
« Reply #1 on: February 27, 2007, 10:48:23 AM »
Sorry I forgot to add the code I was talking about
;;; Change Block Version 2.3.1
;;; Copyright (C) 1997-2006 by K.E. Blackie
;;; You may copy, modify, use or distribute this code provided that
;;; the copyright notice remains in place and that no monetary
;;; consideration be given for the use or transfer of such code.
;;; The function CB will replace a selected block reference(s)
;;; with another block reference that is already defined in
;;; the drawing. All attributes will be retained until/unless
;;; attsync is used.
;; Modified for style by kwb@theswamp 20060303
(defun C:CB (/ intCounter lstOldReference ssBlocks strNewBlockName)
  ;; prompt the user to select items, filtering for blocks only
  (prompt "\nSelect BLOCKS to be replaced.")
  (setq ssBlocks        (ssget '((0 . "INSERT")))
        strNewBlockName (getstring t "\nReplacement Block Name: ")
        intCounter      0
  ;; step through the selection set of blocks
  ;; get the entity list and substitute the new block name for the old block name
  ;; and update the entity with entmod
  (repeat (sslength ssBlocks)
    (setq lstOldReference (entget (ssname ssBlocks intCounter)))
    (entmod (subst (cons 2 strNewBlockName)
                   (assoc 2 lstOldReference)
                   lstOldReference
    (setq intCounter (1+ intCounter))
  ;; Remind about Syncronisation .. don't leave anything on the command line
  (princ "\nAttsync may be required for Attributed Blocks")
This code was posted by Kerry Brown in the above link
« Last Edit: February 27, 2007, 10:54:41 AM by CECE_CAD »
jbuzbee
« Reply #2 on: February 27, 2007, 01:37:07 PM »
what version af autocad are you on?  the following is for 2006.
http://www.theswamp.org/index.php?topic=13283.0
James Buzbee
Windows 8
CECE_CAD
« Reply #3 on: February 27, 2007, 01:44:59 PM »
jbuzbee,  I use 2007
CECE_CAD
« Reply #4 on: February 27, 2007, 04:02:29 PM »
jbuzbee,
how do I use the jbswapblock.dvb...?
jbuzbee
« Reply #5 on: February 27, 2007, 07:41:23 PM »
Matt W tested it on 2007 and seems to work.  Copy the jbVBASwapBlock.lsp and jbSwapBlock.dvb into autocad's search path.  load jbVBASwapBlock.lsp with appload, acaddoc.lsp or *.mnl and type "jbSwapBlock" at the command line.
James Buzbee
Windows 8
CECE_CAD
« Reply #6 on: February 28, 2007, 11:35:51 AM »
jbuzbee, it works..Is there a way to insert blocks that are not listed in the drawing?
Guest
« Reply #7 on: February 28, 2007, 04:44:44 PM »
What's wrong with using BLOCKREPLACE from Express Tools??!?
CECE_CAD
« Reply #8 on: February 28, 2007, 05:44:52 PM »
Matt,  There is nothing wrong with using the Express Tools Block Replace just the fact the block has to be inside the drawing first.  What I really would like to do is have a lisp that I can use to know the blocks that I need to change and the block to replace it with.  But I was settling for what ever I could find.  I also need it to change the layer to our standard layer.  I have the same arch that does the same naming style with his blocks and he has alot of lights, I don't like having the blocks redefined either.  We do alot of work with this same arch so I was just trying to find a nice quick way of being able to replace of his blocks with ours.  Besides giving him our blocks.....
I'm not as advance with writing lisp, but i'm trying..
« Last Edit: February 28, 2007, 05:46:47 PM by CECE_CAD »
