Author Topic: Help for lisp (writing) beginner  (Read 4855 times)
« on: October 24, 2003, 01:11:10 PM »
How do I make a filtered window selection using lisp. I already hade the dxf code for what i want filtered but it does not give me the option to select entities, it just makes a selection set.
(ssget "x"'((2 . "WID_VD_1,WID_VD_1_5,WID_VD_2,WID_VD_MV")))
Thanks,
Ron
SMadsen
« Reply #1 on: October 24, 2003, 01:21:51 PM »
The "X" option in SSGET means "select all and then some" (look up SSGET in the help reference to see what "then some" means).
If you omit the selection method, the user is given control of how ents are selected:
(ssget '((2 . "WID_VD_1,WID_VD_1_5,WID_VD_2,WID_VD_MV")))
To force a window'ed selection you can use "W". If called without points, the user is asked where to select. If called with points you are in control and the user won't notice a thing.
« Reply #2 on: October 24, 2003, 06:27:58 PM »
Thank you. Exactly what i was looking for.
