The "X" option in SSGET means "select all and then some" (look up SSGET in the help reference to see what "then some" means).
If you omit the selection method, the user is given control of how ents are selected:
(ssget '((2 . "WID_VD_1,WID_VD_1_5,WID_VD_2,WID_VD_MV")))
To force a window'ed selection you can use "W". If called without points, the user is asked where to select. If called with points you are in control and the user won't notice a thing.
