Author Topic: Download with vlisp  (Read 12327 times)
Patrick_35
Download with vlisp
« on: February 23, 2007, 05:22:11 AM »
Hello,
How download a link without Dialog Box and without use SendKey ?
I try
(setq shell (vlax-create-object "Shell.Application"))
(vlax-invoke shell 'open "http://carnet-de-cablage.chez-alice.fr/Lisp/Rbloc.zip")
(vlax-release-object shell)
And
(setq ie (vlax-Create-Object "InternetExplorer.Application"))
(vlax-invoke ie 'navigate "http://carnet-de-cablage.chez-alice.fr/Lisp/Rbloc.zip")
(vlax-release-object ie)
but i have the dialog box  :-(
ElpanovEvgeniy
  • Moscow (Russia)
Re: Download with vlisp
« Reply #1 on: February 23, 2007, 09:37:03 AM »
« Reply #2 on: February 23, 2007, 09:42:11 AM »
What about ``GetRemoteFile''.
GetRemoteFile URL, LocalFile, IgnoreCache
Patrick_35
« Reply #3 on: February 23, 2007, 10:46:52 AM »
Excel ElpanovEvgeniy: -)
I thus arrive at well translating into vlisp, but how to write the response into binary  :?
'Create local file and save results to it
    vFF = FreeFile
    If Dir(vLocalFile) <> "" Then Kill vLocalFile
    Open vLocalFile For Binary As #vFF
    Put #vFF, , oResp
    Close #vFF
Se7en, I will make a research with regard to ``GetRemoteFile''.
Thank you with you two  :-)
« Reply #4 on: February 23, 2007, 11:49:23 AM »
This used to work ...
(defun mst-activate (/ key)
  (setq key (MST-GetFileFromURL
      "http://www.theswamp.org/lilly.pond/public/key.txt"
  (if key
    (alert
      (strcat
"Thank you for being my beta tester\n Make note of this number -> "
key
(defun MST-GetFileFromURL (strURL / fo key vlUtilObj RemoteFile TmpFile)
  (setq vlUtilObj (vla-get-Utility
    (vla-get-ActiveDocument (vlax-get-acad-object))
  (if (and (= (type strURL) 'STR)
   (= (vla-IsURL vlUtilObj strURL) :vlax-true)
    (setq RemoteFile
   (vl-catch-all-apply
     'vlax-invoke-method
     (list vlUtilObj 'GetRemoteFile strURL 'TmpFile :vlax-false)
    ) ; if
  (if (not (vl-catch-all-error-p RemoteFile))
    (if (setq fo (open TmpFile "r"))
      (if (setq key (read-line fo))
(close fo)
  (if (vl-file-delete TmpFile)
    key
(mst-activate)
Patrick_35
« Reply #5 on: February 26, 2007, 03:46:05 AM »
Great Mark
Thank you very much  :-)
Patrick_35
« Reply #6 on: February 26, 2007, 05:55:26 AM »
For the pleasure, and in spite of the great solution of Mark, I continued with the ElpanovEvgeniy proposal but a problem arises. How to write in a file the character Null (chr 0) ?
Thanks in advance
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: February 26, 2007, 06:34:20 AM »
Thanks in advance
Hi Patrick_35 :-)
This code writes to a file of 100 lines on 8 (chr 0)
(setq f(open "d:\\test.txt" "w"))
(repeat 100
 (WRITE-LINE (VL-LIST->STRING '(0 0 0 0 0 0 0 0)) f)
(close f)
« Last Edit: February 26, 2007, 06:37:36 AM by ElpanovEvgeniy »
Patrick_35
« Reply #8 on: February 26, 2007, 08:10:20 AM »
Thank you Evgeniy  :-)
I'm there almost what I don't understand, this is why when I open the zip and that I look at the files, those are empty  :?
(defun download (url dir / byte fic file http tbl)
  (setq http (vlax-create-object "MSXML2.XMLHTTP"))
  (vlax-invoke-method http 'open "get" url :vlax-false)
  (vlax-invoke http 'send)
  (while (not (eq (vlax-get http 'readyState) 4))
    (repeat 100)
  (setq file (strcat dir (vl-filename-base url) (vl-filename-extension url))
tbl  (vlax-safearray->list (vlax-variant-value (vlax-get-property http 'responsebody)))
fic  (open file "w") n 0)
  (foreach byte tbl
    (if (eq byte 0)
      (princ (vl-list->string '(0)) fic)
      (write-char byte fic)
  (close fic)
  (vlax-release-object http)
(download "http://carnet-de-cablage.chez-alice.fr/Lisp/Latt.zip" "c:/")
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #9 on: February 26, 2007, 08:43:47 AM »
    (repeat 100)
  (foreach byte tbl
    (if (eq byte 0)
  (close fic)
Hello Patrick.
On my computer, this code works! :)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #10 on: February 26, 2007, 09:31:28 AM »
    (repeat 100)
If express established, such variant will load less processor...
   (if acet-sys-sleep
     (acet-sys-sleep 5);;(acet-sys-sleep [time-pause-msec])
    (repeat 100)
Patrick_35
« Reply #11 on: February 26, 2007, 10:17:06 AM »
    (repeat 100)
  (foreach byte tbl
    (if (eq byte 0)
  (close fic)
Hello Patrick.
Good idea with express  8-)
but the code works in my computer to
But if you launch the zip and extract the files, they're empty  :?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #12 on: February 26, 2007, 10:22:08 AM »
All works for me!  :-)
Patrick_35
« Reply #13 on: February 26, 2007, 11:04:52 AM »
Thanks Evgeniy
I don't understand.  :-(
It's a windows version ? . I work with Xp Professional.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #14 on: February 26, 2007, 11:10:04 AM »
Thanks Evgeniy
I too use XP Professional +SP2 (ru)
The program checked for AutoCAD 2007 +SP1 (en)
