Author Topic: Is it possible to search file name  (Read 4047 times)
Adesu
« on: February 22, 2007, 11:51:21 PM »
Hi Alls,
I'm still confuse how to searching a file name in one drive,it say "D:\",as the sample to clear this question is,if I or you forgot put location folder a file name,let say "testXX.dwg",you only remember 2 poin drive and file name.
How to find it
(defun c:test (/ )
  (setq opt (getstring t"\nEnter file name: "))
  (setq file_name (strcat opt ".dwg"))
  (setq drive "D:\"")
  ;(setq lst (vl-directory-files drive file_name 0))
  ;(setq test1 (member file_name lst))
ElpanovEvgeniy
  • Moscow (Russia)
Re: Is it possible to search file name
« Reply #1 on: February 23, 2007, 12:24:18 AM »
 Function of search of all folders inside of the root folders specified in the list.
 Arguments:
 P - the list of root folders.
 For example '("C:\\Program Files") or ' ("C:" "D:" "E:")
 To cause
 (GetFolders '("C:\\Program Files\\AutoCAD 2004\\Sample"))
 Returns the list of folders, including specified in the list of search.
 ' ("C:\\Program Files\\AutoCAD 2004\\Sample"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\ActiveX"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\Database Connectivity"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\DesignCenter"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\VBA"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\VisualLISP"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\ActiveX\\ExtAttr"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\ActiveX\\ExternalCall"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\Database Connectivity\\CAO"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\VBA\\VBAIDEMenu"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\VisualLISP\\activex"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\VisualLISP\\External"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\VisualLISP\\mdi-vlx"
    "C:\\Program Files\\AutoCAD 2004\\Sample\\VisualLISP\\reactors"
(defun GetFolders (p)
 ;; By ElpanovEvgeniy
 ;; (GetFolders '("C:\\Program Files\\AutoCAD 2004\\Sample"))
 (if p
  (append
   p
   (GetFolders
    (apply (function append)
           (mapcar
            (function (lambda (b)
                       (mapcar (function (lambda (a) (strcat b "\\" a)))
                               (vl-remove ".."
                                          (vl-remove "." (vl-directory-files b nil-1))
            p
 Function of search of a file or files in the specified folder and all enclosed folders
 The file is set by a name or a mask
 Arguments:
 P - an initial way of search,
 For example "C:" or "C:\\Program Files"
 F - the name of a file,
 Use WCMATCH symbols is possible.
 For example
 "*.dwg" - will find all dwg-files
 Or "acad*.lsp"
 To cause
 (getfile "acad*.lsp" "C:\\Program Files")
 Returns the list of files with full by up to them and the name without a mask.
 ' ("C:\\Program Files\\AutoCAD 2004\\Express\\acadinfo.lsp"
    "C:\\Program Files\\AutoCAD 2004\\Support\\acad2004.lsp"
    "C:\\Program Files\\AutoCAD 2004\\Support\\acad2004doc.lsp"
    "C:\\Program Files\\AutoCAD 2004\\Support\\acadinfo.lsp"
(defun GetFile (f p)
 ;; (getfile "acad*.lsp" "C:\\Program Files")
        (cons (if (vl-directory-files p f)
               (mapcar (function (lambda (x) (strcat p "\\" x))) (vl-directory-files p f))
              ) ; _ if
              (mapcar (function (lambda (x) (GetFile f (strcat p "\\" x))))
                      (vl-remove ".." (vl-remove "." (vl-directory-files p nil-1)))
              ) ; _ mapcar
        ) ; _ cons
 ) ; _ apply
 Function of search of a file inside of the root folders specified in the list
 And all enclosed folders
 Search stops on the first specified file
 In comparison with function GetFile works more quickly,
 Since interrupts search, after a finding of a file.
 It is recommended for search of files with the unique name.
 Arguments:
 For example '("C:\\Program Files") or '("C:" "D:" "E:")
 For example:
 "a?ad.exe"
 To cause:
 (GetFirstFile "a?ad.exe" '("C:\\Program Files"))
 Returns a line - a full way to a file with the full name.
"C:\\Program Files\\AutoCAD 2004\\acad.exe"
(defun GetFirstFile (f p)
 ;; (GetFirstFile "a?ad.exe" '("C:\\Program Files"))
  ((not p) nil)
  ((vl-directory-files (car p) f) (strcat (car p) "\\" (car (vl-directory-files (car p) f))))
  ((GetFirstFile
    f
    (append (mapcar (function (lambda (x) (strcat (car p) "\\" x)))
                    (vl-remove ".." (vl-remove "." (vl-directory-files (car p) nil-1)))
            ) ; _ mapcar
            (cdr p)
    ) ; _ append
   ) ; _ GetFirstFile
 ) ; _ cond
) ; _ defun
« Last Edit: February 23, 2007, 08:42:38 AM by ElpanovEvgeniy »
Adesu
« Reply #2 on: February 23, 2007, 01:03:18 AM »
Hi Elpanov,
Wow...that great,thanks.
Adesu
« Reply #3 on: February 23, 2007, 03:15:06 AM »
Hi Elpanov,
Here my code after I completed,thanks for your share.
; sfnbd is stand for Search File Name Base on Drive
;        Design by  : Adesu <Ade Suharna>
;        Email      : mteybid@yuasabattery.co.id
;        Homepage   : http://www.yuasa-battery.co.id
;        Create     : 23 February 2007
;        Program no.: 0541/02/2007
;        Edit by    :
(defun GetFolders (p)         ; By ElpanovEvgeniy
    p
    (append
      p
      (GetFolders
       (mapcar
     (vl-remove ".."
p
(defun c:sfnbd (/ cnt drive fil file_name len leng lst name_file opt)
      (setq len (strlen file_name))
      (setq drive (getstring "\nEnter drive name <D>: "))
(= drive "")
(setq drive "D:\\")
(setq drive (strcase (strcat drive ":\\")))
      (setq lst (GetFolders (list drive)))
      (setq lst (cdr lst))
      (setq leng (length lst))
      (setq cnt 0)
      (repeat
leng
(setq fil (nth cnt lst))
(setq name_file (vl-filename-base fil))
(setq name_file (strcat name_file ".dwg"))
  (= file_name name_file)
  (alert (strcat "\nHere location your file name"
"\n"
fil))
  )             ; if
(setq cnt (1+ cnt))
)               ; reapet
      )                 ; progn
    )                   ; if
  )                     ; defun
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: February 23, 2007, 03:20:50 AM »
Hi Adesu,
Why, did not begin to use:
(getfile file_name drive)
Adesu
« Reply #5 on: February 23, 2007, 03:29:01 AM »
Hi Elpanov,
I'm not yet focus to "(getfile file_name drive)"
I just test with "GetFolders",maybe next time I would try again,thanks.
Hi Adesu,
« Reply #6 on: February 23, 2007, 08:39:37 AM »
Very nice work Evgeniy. :-)
