I was thinking about a thread on that, like an excel form with lisp vba net etc listing can and cant does. I only got as far as jotting a few things down, I know there are plenty more.
Well wipeout in 2007 is a no go in vba and as you said a no go with net. The rest look a bit like I need to listen to Kerry and study up.
1) Ghosting (Inserts, rotations etc. require send command)
2) Add wipeout.
3) Make a layer filter active.
4) Set views and Ucs's in a split viewport.
5) Read and set dxf codes.
6) Set clip boundaries.
7) Get activeview that has not been saved.
Set imageframe
9) Recognise Rtext
10) Set arclength symbol
11) Add a command.
12) 3dSolid endpoints,midpoints etc.
Can do but requires lisp.
1) Math class- using vlax-curve
2) Set LeaderType
3)Viewports- set viewangle and dxf 79 (Orthographic type of UCS)
4)Mtext width
5)Dimension block name
6) Imagedef, 280
7) Dims (dxf 10,13,14,50)
