Author Topic: Check line for accuracy  (Read 11929 times)
Re: Check line for accuracy
« Reply #15 on: February 23, 2007, 12:58:28 PM »
Thanks for all of the responses. Great work. All of the posted code seems to find all lines that are greatly at an angle but not find others that are off just so slightly.
Did you change the my code as I noted?  If so, then it still doesn't grab all the lines?
V-Man
« Reply #16 on: February 23, 2007, 01:07:11 PM »
I used the following code.
(vlax-for Lo (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-Acad-Object)))
  (vlax-for Obj (vla-get-Block Lo)
    (and
     (= (vla-get-ObjectName Obj) "AcDbLine")
     (not
      (or
((lambda (a)
   (or
     (equal (sin a) 0.0 0.02)
     (equal (abs (sin a)) 1.0 0.02)
  (vla-get-Angle Obj)
    (vla-put-Color Obj 221)
« Reply #17 on: February 23, 2007, 01:22:14 PM »
You are still allowing for a tolerance of 1.14592 degrees.  If you want a very small number, then change this
   (or
to
   (or
     (equal (sin a) 0.0 0.0000001)
     (equal (abs (sin a)) 1.0 0.0000001)
This will get all lines that are not at a right angle.
gile
  • Marseille, France
« Reply #18 on: February 23, 2007, 01:23:56 PM »
Evgeniy,
There's still a problem with your new code, if (sin a) is closed to -1.
((lambda (a) (equal (sin a) (fix (+ (sin a) 0.5)) (sin (/ pi 60))))
 (+ (* pi 1.5) (/ pi 90))
Should return T, but return nil.
Maybe replace 'fix' function by a 'round' function working with negative numbers.
(defun round (num)
  (if (minusp num)
    (fix (- num 0.5))
    (fix (+ num 0.5))
V-Man
« Reply #19 on: February 23, 2007, 01:35:06 PM »
Code:
   (or
to
Code:
   (or
Thanks T.Willey That was the problem. Works like a dream.
« Reply #20 on: February 23, 2007, 01:38:09 PM »
Code:
   (or
to
Code:
   (or
You're welcome.  You might want to change the code back the the first one I posted, with making the same changes to it.  It seems like a debate aboutt he math of the code you are using.
« Reply #21 on: February 23, 2007, 01:52:42 PM »
Mine does! :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #22 on: February 23, 2007, 02:51:14 PM »
Evgeniy,
(defun round (num)
  (if (minusp num)
    (fix (- num 0.5))
    (fix (+ num 0.5))
Once again I apologize, for the carelessness...
In Russia today a holiday and not the working day.
Now we with family celebrate.
Thanks gile for the instruction of mistakes!
New variant...
(equal (abs(sin a)) (fix (+ (abs(sin a)) 0.5)) (sin (/ pi 60)))
GDF
« Reply #23 on: February 23, 2007, 03:30:58 PM »
Check out this routine.
;;;SNAPLINE.LSP   Rectify Lines   (c)1998, Galen A. Light
Gary
You should check out the routine above, you can enter a fudge factor, and it will fix the line.
To Rectify Lines that are not truely Horizontal or Vertical.
(prompt "\n* Change angled Line to a 0 or 90 setting *")
(setq dvar (abs (getreal "\n* Enter degrees of variance: *")))
Gary
gile
  • Marseille, France
« Reply #24 on: February 23, 2007, 03:42:02 PM »
 :oops: :|
I'm sorry, none code posted by Evgeniy and I are realy exact.
Comparing only the angle sinus to 0 or 1 is not rigorous.
I'm going to try an explaination. If a equals pi/60 radians (3°) and b equals pi/2 + pi/60 (93°)
sinus a is equal to 0.052336
sinus b is equal to 0.99863
The codes posted by Evgeniy and I were comparing as well sinus a to 0 and sinus b to 1 and the result isn't the same even there's in both case the same rotation from 0° and 90°. The comparation isn't the same for 'horizontal' or 'vertical' angles.
I think it have been more rigorous to compare sinus a and cosinus b both to 0 (as sinus a, cosinus b is equal to -0.052336)
So, if we want to use trigonometry, instead of :
(or
      (equal (vla-get-Angle Obj) 0.0 0.05)
      (equal (vla-get-Angle Obj) (* pi 0.5) 0.05)
      (equal (vla-get-Angle Obj) pi 0.05)
      (equal (vla-get-Angle Obj) (* pi 1.5) 0.05)
the good algorithm should be :
((lambda (a)
   (or
     (equal (sin a) 0.0 0.05)
     (equal (cos a) 0.0 0.05)
  (vla-get-Angle Obj)
« Reply #25 on: February 23, 2007, 03:52:21 PM »
Thanks Gile.  I was going to try and understand what you two have been posting when I got some time.  My trig sucks really bad right now, so it will take a while for me to understand it.
gile
  • Marseille, France
« Reply #26 on: February 23, 2007, 04:56:54 PM »
It's not very difficult to understand.
In my opinion the simplest way to understand/remeber trigonometry is using the 'trigonometric circle'.
A circle which radius is equal to 1, with two axis : cosinus axis (horizontal) and sinus axis (vertical).
In this circle angles are increasing conterclockwise from 0 (East).
The projection of each angle line on cosinus axis is the cos value as well for sinus.
So :
cos 0° = 1 and sin 0° = 0
cos 90° = 0 and sin 90° = 1
cos 1800° = -1 and sin 180° = 0
cos 270° = 0 and sin 270° = -1
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #27 on: February 24, 2007, 04:15:19 AM »
Summed up, at me it has turned out four programs...
Check of a corner of a line, without taking into account fuzz.
function use vla-object.
(defun test-not-orto (/ ss)
 ;; use vla-object
 (if (setq ss (ssget '((0 . "LINE"))))
  (foreach e (mapcar (function vlax-ename->vla-object)
                     (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex ss)))
             ) ;_  mapcar
   (if (not (vl-some (function equal) (vlax-curve-getFirstDeriv e 0.) '(0. 0.) '(1e-8 1e-8)))
    (vla-put-Color e 1)
   ) ;_  if
  ) ;_  foreach
 ) ;_  if
) ;_  defun
function not use vla-object.
 ;; not use vla-object
  (foreach e (mapcar (function entget) (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex ss))))
                     (mapcar (function -) (cdr (assoc 10 e)) (cdr (assoc 11 e)) '(0 0))
                     '(0. 0.)
                     '(1e-8 1e-8)
            ) ;_  vl-some
       ) ;_  not
    (entmod
     (if (assoc 62 e)
      (subst '(62 . 1) (assoc 62 e) e)
      (append (reverse (cons '(62 . 1) (vl-member-if (function (lambda (x) (= (car x) 8))) (reverse e))))
              (cdr (vl-member-if (function (lambda (x) (= (car x) 8))) e))
      ) ;_  append
     ) ;_  if
    ) ;_  entmod
   ) ;_  if
  ) ;_  foreach
 ) ;_  if
) ;_  defun
Check of a corner of a line, taking into account fuzz.
(defun test-not-orto-fuzz (/ ss)
 ;; use vla-object
             ) ;_  mapcar
   (if (not ((lambda (a) (or (equal (sin a) 0.0 0.05) (equal (cos a) 0.0 0.05))) (vla-get-Angle e)))
    (vla-put-Color e 1)
   ) ;_  if
  ) ;_  foreach
 ) ;_  if
) ;_  defun
             (angle (cdr (assoc 10 e)) (cdr (assoc 11 e)))
       ) ;_  not
    (entmod
     (if (assoc 62 e)
      ) ;_  append
     ) ;_  if
    ) ;_  entmod
   ) ;_  if
  ) ;_  foreach
 ) ;_  if
) ;_  defun
fools
  • China
« Reply #28 on: March 01, 2007, 07:45:20 AM »
:oops: :|
((lambda (a)
   (or
  (vla-get-Angle Obj)
how about this solution? :-) a little faster
because SIN(2*A)=2*SIN(A)*COS(A)
((LAMBDA (a)
   (EQUAL (sin (+ a a) 0.0 0.104528))
 (vla-get-Angle Obj)
« Last Edit: March 01, 2007, 08:26:43 AM by fools »
Good good study , day day up . Sorry about my Chinglish .
« Reply #29 on: March 01, 2007, 09:27:04 AM »
Welcome to the swamp fools
Nice lisp, although there is a miss-placed parentheses in your post
  ((lambda (a)
            (equal (sin (+ a a)[color=red])[/color] 0.0 0.0523599) ; +-3 deg
         (vla-get-angle Obj)
