Author Topic: Check line for accuracy  (Read 11861 times)
V-Man
« on: February 22, 2007, 09:39:58 AM »
I am in need of some direction. I want to be able to check all lines in a drawing for for accuracy. (i.e. straight versus crooked lines). Please see picture.
Basically I want to be able to run a check on an entire drawing and have it check all lines for accuracy within a given tolerance of say 3 degrees from being straight and once found annotate them with somehow so that the user can go back through the drawing and correct accordingly if needed.
Any assistance is greatly appreciated.
GDF
Re: Check line for accuracy
« Reply #1 on: February 22, 2007, 10:46:53 AM »
Check out this routine.
;;;SNAPLINE.LSP   Rectify Lines   (c)1998, Galen A. Light
Gary
« Reply #2 on: February 22, 2007, 10:48:57 AM »
You could always just do the math...http://www.theswamp.org/index.php?topic=5203.0
« Reply #3 on: February 22, 2007, 10:50:42 AM »
Looks like it would be a fun project for some of the swampers! :-)
« Reply #4 on: February 22, 2007, 11:11:24 AM »
(vlax-for Lo (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-Acad-Object)))
 (vlax-for Obj (vla-get-Block Lo)
   (and
    (= (vla-get-ObjectName Obj) "AcDbLine")
    (not
     (or
      (equal (vla-get-Angle Obj) 0.0 0.05)
      (equal (vla-get-Angle Obj) (* pi 0.5) 0.05)
      (equal (vla-get-Angle Obj) pi 0.05)
      (equal (vla-get-Angle Obj) (* pi 1.5) 0.05)
   (vla-put-Color Obj 121)
V-Man
« Reply #5 on: February 22, 2007, 12:46:47 PM »
An example. I have this for for the propoerties of a line...
Command:  LIST
Select objects: 1 found
Command:  LIST
Select objects:
                  LINE      Layer: "A-WALL-TENT-EXST"
                            Space: Model space
                   Handle = CF05
              from point, X=154'-3 1/2"  Y=208'-1 1/8"  Z=    0'-0"
                to point, X=180'-8 3/4"  Y=208'-1 1/2"  Z=    0'-0"
          Length =26'-5 1/4",  Angle in XY Plane = 0.06453059
                  Delta X =26'-5 1/4", Delta Y = 0'-0 3/8", Delta Z =    0'-0
The Angle in the XY plane is off from being "0" by a very small amount. These are the types of lines that I want to be able to search for. In this case it is off by less than a degree.
The supplied code from T.Willey did not catch this line as being incorrect.
« Reply #6 on: February 22, 2007, 12:58:02 PM »
This is what I went off of.  If you want a smaller tolerance, then change these lines in the code.
     (or
* don't forget that the angle is in radians.  That is how I got the 0.05
Command: (* (/ 3.0 180.0) pi)
0.0523599
« Reply #7 on: February 22, 2007, 02:41:45 PM »
Try this one ...
(defun c:checklines ( / ss cntr new_ss x y ang ent )
  (defun check_angle (ang)
      ((= ang (* pi 0.5)) T) ; up
      ((= ang (* pi 1.0)) T) ; left
      ((= ang (* pi 1.5)) T) ; down
      ((= ang 0.0) T) ; zero
  (sssetfirst nil)
  (setq ss (ssget "X" '((0 . "LINE")))
cntr 0
new_ss (ssadd)
  (if (not (zerop (sslength ss)))
    (while (setq ent (ssname ss cntr))
   (setq x (cdr (assoc 10 (entget ent)))
y (cdr (assoc 11 (entget ent)))
ang (angle x y)
   (if (not (check_angle ang))
     (ssadd ent new_ss)
   (setq cntr (1+ cntr))
   );while
    );if
  (if (not (zerop (sslength new_ss)))
    (sssetfirst nil new_ss)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #8 on: February 23, 2007, 12:42:12 AM »
     (or
My variant:
((lambda (a) (equal (sin a) (fix (sin a)) (sin (/ pi 60))))
 (vla-get-Angle Obj)
« Last Edit: February 23, 2007, 12:44:05 AM by ElpanovEvgeniy »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #9 on: February 23, 2007, 02:56:17 AM »
Try this one ...
  (sssetfirst nil)
cntr 0
new_ss (ssadd)
ang (angle x y)
     (ssadd ent new_ss)
   );while
    );if
If at check of a corner, it is not necessary to set accuracy (fuzz)
It is enough to check up:
(or
 (= (- x1 x2) 0.)
 (= (- y1 y2) 0.)
For example:
(vl-some
 (function equal)
 (mapcar (function -)
         (cdr (assoc 10 (entget e)))
         (cdr (assoc 11 (entget e)))
         '(0 0)
 ) ;_  mapcar
 '(0. 0.)
 '(1e-8 1e-8)
) ;_  vl-some
« Reply #10 on: February 23, 2007, 11:05:44 AM »
     (or
My variant:
 (vla-get-Angle Obj)
You're math skills are better than mine, so I will just assume you are correct.  Nice short compact test Evgeniy.  :-)
gile
  • Marseille, France
« Reply #11 on: February 23, 2007, 11:47:22 AM »
 (vla-get-Angle Obj)
I think there's a mistake, except if a equals pi/2 or 3pi/2 (fix (sin a)) will always return 0.0.
Example: if a equals pi/120 radians (very closed to 0.0°), it works
_$ (setq a (/ pi 120))
0.0261799
_$ (sin a)
0.0261769
_$ (fix (sin a))
0
_$ (equal (sin a) (fix (sin a)) (sin (/ pi 60)))
T
But, if a is pi/2 + pi/120 radians (very closed to 90.0°), it don't work.
_$ (setq a (+ (/ pi 2) (/ pi 120)))
1.59698
_$ (sin a)
0.999657
_$ (fix (sin a))
0
nil
Evgeniy's code should be right whith '=' or 'eq' functions, but can't be used with 'equal' and a 'fuzz'.
« Last Edit: February 23, 2007, 11:50:05 AM by gile »
gile
  • Marseille, France
« Reply #12 on: February 23, 2007, 12:18:58 PM »
Another version, less compact, but semms to work
((lambda (a)
   (or
     (equal (sin a) 0.0 0.05)
     (equal (abs (sin a)) 1.0 0.05)
  (vla-get-Angle Obj)
V-Man
« Reply #13 on: February 23, 2007, 12:54:16 PM »
Thanks for all of the responses. Great work. All of the posted code seems to find all lines that are greatly at an angle but not find others that are off just so slightly.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #14 on: February 23, 2007, 12:56:18 PM »
 (vla-get-Angle Obj)
0.0261799
_$ (sin a)
0.0261769
_$ (fix (sin a))
0
T
1.59698
_$ (sin a)
0.999657
_$ (fix (sin a))
0
nil
I am sorry! :oops:
I have hastened and have badly expressed the idea...
Many thanks gile! You have corrected me.
In my example, it is necessary to use
(fix (+ (sin a) 0.5))
Then all example will look:
((lambda (a) (equal (sin a) (fix (+(sin a)0.5)) (sin (/ pi 60))))
 (vla-get-Angle Obj)
