Author Topic: (Challenge) bounding box of the points list.  (Read 4849 times)
ElpanovEvgeniy
  • Moscow (Russia)
« on: February 20, 2007, 09:31:38 AM »
You have a list of points:
(while (setq p (getpoint "\n  Specify point:  ")) (setq pt-list (cons p pt-list)))Example:
(setq pt-list '((0. 5. 0.) (1. 10. 0.) (-2. 0. 10.) (-18. 3. -4.)))
;; Explanation - all point 3D
It is necessary to receive the dimensional container of this list
As vla-GetBoundingBox, only list point...
Write two programs:
The first program: - calculates 3D list point
(GetBoundingBox-3d pt-list) = >> '((-18.0 0.0 -4.0) (1.0 10.0 10.0))
;; Explanation - return '((min-X min-Y min-Z) (max-X max-Y max-Z))
The second program: - calculates 2D list point
(GetBoundingBox-2d pt-list) = >> '((-18.0 0.0) (1.0 10.0))
;; Explanation - return '((min-X min-Y) (max-X max-Y))
PS. Last time, I have written not clearly...  :oops:
Ask also I shall explain once again!   :-)
gile
  • Marseille, France
Re: (Challenge) bounding box of the points list.
« Reply #1 on: February 20, 2007, 10:35:26 AM »
Here's my contribution.
(defun GetBoundingBox-3d (pt_lst)
  (list (apply 'mapcar (cons 'min pt_lst))
(apply 'mapcar (cons 'max pt_lst))
(defun GetBoundingBox-2d (pt_lst)
  ((lambda (l)
     (list
       (apply 'mapcar (cons 'min l))
       (apply 'mapcar (cons 'max l))
    (mapcar '(lambda (p) (list (car p) (cadr p))) pt_lst)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #2 on: February 20, 2007, 10:41:56 AM »
Hello gile!
My function GetBoundingBox-3d is identical to yours!
But my function GetBoundingBox-2d is easier than yours...
gile
  • Marseille, France
« Reply #3 on: February 20, 2007, 10:50:36 AM »
Another way for GetBoundingBox-2d
 (mapcar '(lambda (p) (reverse (cdr (reverse p))))
     (list
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: February 20, 2007, 10:56:26 AM »
Already better! :)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: February 20, 2007, 11:42:23 AM »
Already better! :)
I wished to tell, that it is possible to reduce quantity of calculations...
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #6 on: February 21, 2007, 03:21:19 PM »
     (list
my variant:
 ((lambda (l)
   (list
   ) ;_  list
  ) ;_  lambda
  (cons (list (caar pt_lst) (cadar pt_lst))
        (cdr pt_lst)
  ) ;_  cons
) ;_  defun
gile
  • Marseille, France
« Reply #7 on: February 21, 2007, 03:47:34 PM »
Nice one, Evgeniy. :-)
I have to learn more about ((lambda ...) using  :roll:
efernal
« Reply #8 on: February 22, 2007, 12:49:14 PM »
;; So, we can draw a box with these points...
(DEFUN _3dbbox (points_list / pa pb pc pd pe pf pg)
  (IF (AND (= (LENGTH points_list) 2)
           (= (TYPE (CAR points_list)) 'LIST)
           (= (TYPE (CADR points_list)) 'LIST)
           (= (LENGTH (CAR points_list)) 3)
           (= (LENGTH (CADR points_list)) 3)
           (/= (LAST (CAR points_list)) (LAST (CADR points_list)))
    (PROGN (SETQ pa (CAR points_list)
                 pg (CADR points_list)
                 pb (LIST (CAR pg) (CADR pa) (CADDR pa))
                 pc (LIST (CAR pg) (CADR pg) (CADDR pa))
                 pd (LIST (CAR pa) (CADR pg) (CADDR pa))
                 pe (LIST (CAR pa) (CADR pa) (CADDR pg))
                 pf (LIST (CAR pb) (CADR pb) (CADDR pg))
                 ph (LIST (CAR pd) (CADR pd) (CADDR pg))
           (COMMAND "_.PFACE")
           (FOREACH x (LIST pa pb pc pd pe pf pg ph) (COMMAND "_NON" x))
           (COMMAND ""                  ;
                    1 2 3 4 ""          ;
                    5 6 7 8 ""          ;
                    1 2 6 5 ""          ;
                    2 3 7 6 ""          ;
                    3 4 8 7 ""          ;
                    4 1 5 8 ""          ;
    nil
  (PRINC)
;; Usage = (_3dbbox (list pa pb)) where pa and pb are 3d points, ie: (0 0 0) and (100 100 100)
e.fernal
Joe Burke
« Reply #9 on: February 23, 2007, 09:10:52 AM »
Here's an old one by Tony Tanzillo. Obviously similar to code already posted, but I'm not sure about how it differs.
It works well for me.
;; Returns the lower left and upper right corners of a point list.
(defun extents (plist)
   (list
      (apply 'mapcar (cons 'min plist))
      (apply 'mapcar (cons 'max plist))
