Author Topic: moving text using insertion point  (Read 3015 times)
confusedCADguy
« on: June 08, 2004, 03:35:48 PM »
I am writing a routine to move a piece of text and draw a line from where that text is placed to a user defined point. I want to move the text using the insertion point and use that point as the start of my line. Any ideas?
« Reply #1 on: June 08, 2004, 03:44:01 PM »
(defun c:lft (/ ent ins_pt_txt p1)
  (if (setq ent (car (entsel "\nSelect (D)Text: ")))
(setq ins_pt_txt (cdr (assoc 10 (entget ent))))
  (if ins_pt_txt
(if (setq p1 (getpoint ins_pt_txt "\nSelect end point of line: "))
 (command "_.line" ins_pt_txt p1 "")
« Reply #2 on: June 08, 2004, 09:45:47 PM »
confusedCADguy
Jeff answered it for you here :
http://www.cadvault.com/forums/showpost.php?p=75009&postcount=9
« Reply #3 on: June 09, 2004, 04:39:00 AM »
- confusedCADguy
please update your e-mail address, the one you are using bounces.
thanks
