Author Topic: Passing Variables  (Read 4429 times)
deegeecees
Passing Variables
« on: June 07, 2004, 01:30:17 PM »
Ok, I know this question has probably been asked, (and I did a search on this) is there a way to pass a variable from lisp to vba and vise versa?
Passing Variables
« Reply #1 on: June 07, 2004, 02:39:45 PM »
Yes.
Search for the VLAX class code that allows the use of lisp in vba. Then set/read lisp variables in lisp & vba.
Jeff
deegeecees
Passing Variables
« Reply #2 on: June 07, 2004, 03:09:53 PM »
I'm not too familiar with vlisp, could you give me an example of how that would work? Lets say I have this in VBA:
dim test1 as string
test1 = "test"
Now, how could I retrieve the value of test1 in lisp?
Passing Variables
« Reply #3 on: June 07, 2004, 04:18:47 PM »
Here's an example using the vlax class.
Sub test()
Dim vlax As New vlax
Dim strText As String
strText = "Hello there!"
vlax.SetLispSymbol "test", strText
End Sub
Running the above will allow the symbol "test" to be used in a lisp function. Typing !test at the command line yields this:
Command: !test
"Hello there!"
HTH,
Jeff
Passing Variables
« Reply #4 on: June 07, 2004, 04:29:16 PM »
Or, to retrieve a lisp symbol.....
(setq test 1234.5432)
Sub test2()
Dim strText
strText = vlax.GetLispSymbol("test")
Debug.Print strText
End Sub
deegeecees
Passing Variables
« Reply #5 on: June 07, 2004, 04:29:29 PM »
Just what the doctor ordered! Thanks Jeff!
Passing Variables
« Reply #6 on: June 07, 2004, 05:20:35 PM »
Glad I could help!
