Author Topic: PromptStringOptions allow spaces?  (Read 2891 times)
MDONUT12
« on: February 07, 2007, 11:32:54 AM »
I'm wondering if someone can help me out here. I got this code below I think in the Labs or maybe a post here on this forum. Well I'm trying to allow the user to enter spaces when they type in the response to me string. I found ".allowspaces = true" But when I append it to the end of the PrompStringOptions I get an invalid sytax.
So can someone help me adjust my code to allow strings.
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim pr2 As PromptStringOptions = New PromptStringOptions("Type your Instant Message: ")
        Dim res2 As PromptResult = ed.GetString(pr2)
Re: PromptStringOptions allow spaces?
« Reply #1 on: February 07, 2007, 03:04:14 PM »
Have you tried something like ..
     public void Test()
         Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
         PromptStringOptions ops = new PromptStringOptions("\nLayer name: ");
         ops.AllowSpaces = true;
         PromptResult res = ed.GetString(ops);
         if( res.Status == PromptStatus.OK && res.StringResult != string.Empty )
MDONUT12
« Reply #2 on: February 07, 2007, 03:15:01 PM »
     public void Test()
I swear i tried this before, as I found it in another post. But I must of did it wrong. Anyways this did the trick thank you very much!!
