Author Topic: How to realize 3d Offset?  (Read 8837 times)
gilseorin
« on: February 07, 2007, 07:53:28 AM »
I have difficulty in realize 3d Offset.
I have been doing with my code for three weeks.
Any help would be appreciated.
Thanks in advance.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports System.Math
Public Class GILSclass1
    <CommandMethod("TOS")> _
Public Sub TdOffset()
        Dim Db As Database = HostApplicationServices.WorkingDatabase
        Dim Ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim Tr As Transaction = Db.TransactionManager.StartTransaction
        Try
            Dim EntSelOpt As PromptEntityOptions = New PromptEntityOptions("" & Microsoft.VisualBasic.Chr(10) & "Select 3dPolyLine: ")
            EntSelOpt.SetRejectMessage("" & Microsoft.VisualBasic.Chr(10) & "Only Selected 3d PolyLine!")
            EntSelOpt.AddAllowedClass(GetType(Polyline3d), True)
            Dim EntSelRes As PromptEntityResult = Ed.GetEntity(EntSelOpt)
            If EntSelRes.Status <> PromptStatus.OK Then Return
            Dim DrOpt As PromptPointOptions = New PromptPointOptions("" & Microsoft.VisualBasic.Chr(10) & "Specify Offset Direction: ")
            Dim Dres As PromptPointResult = Ed.GetPoint(DrOpt)
            Dim DrDst As PromptDoubleOptions = New PromptDoubleOptions("" & Microsoft.VisualBasic.Chr(10) & "Input Offset Distance: ")
            Dim Ddst As PromptDoubleResult = Ed.GetDouble(DrDst)
            Dim Z_Sig As PromptDoubleOptions = New PromptDoubleOptions("" & Microsoft.VisualBasic.Chr(10) & "Input Z Value: ")
            Dim Z_res As PromptDoubleResult = Ed.GetDouble(Z_Sig)
            Dim Ent As Polyline3d = CType(Tr.GetObject(EntSelRes.ObjectId, OpenMode.ForRead), Polyline3d)
            Dim c As Curve = DirectCast(Ent, Curve)
            Dim sp As Double = c.StartParam
            Dim ep As Double = c.EndParam
            Dim ssp As Point3d = c.GetPointAtParameter(sp)
            Dim eep As Point3d = c.GetPointAtParameter(ep)
            Dim Vspdr As Double = V(Dres.Value, ssp)
            Dim bt As BlockTable = Tr.GetObject(Db.BlockTableId, OpenMode.ForRead)
            Dim btr As BlockTableRecord = Tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            Dim pts As Point3dCollection = New Point3dCollection
            Dim FnPt As Point3d
            Dim fts As Point3dCollection = New Point3dCollection
            Dim qqq As Vector3d = New Vector3d
            Dim ppp As Vector3d = New Vector3d
            ppp.CrossProduct(qqq)
            Dim n As Integer = 0
            For p As Double = sp To ep Step 1.0
                n = n + 1
                Dim pt As Point3d = c.GetPointAtParameter(p)
                Dim gt As Point3d = New Point3d(pt.X, pt.Y, pt.Z + Z_res.Value)
                Dim Vptnt As Double
                Dim nt As Point3d
                If p <> ep Then
                    nt = c.GetPointAtParameter(p + 1.0)
                    Vptnt = V(nt, pt)
                ElseIf p = ep Then
                End If
                Dim SndPt1 As Point3d
                Dim SndPt2 As Point3d
                Dim Vfn As Double
                Select Case (Vspdr > 0 Or Vspdr = 0) AndAlso Vspdr < Atan(1) * 4
                    Case True
                        Vfn = Vptnt + 2 * Atan(1)
                        SndPt1 = PolarPoint(Dst(pt, nt).Item(0), Vfn, Ddst.Value)
                        SndPt2 = PolarPoint(Dst(pt, nt).Item(1), Vfn, Ddst.Value)
                    Case False
                        Vfn = Vptnt - 2 * Atan(1)
                        SndPt1 = PolarPoint(Dst(gt, nt).Item(0), Vfn, Ddst.Value)
                        SndPt2 = PolarPoint(Dst(gt, nt).Item(1), Vfn, Ddst.Value)
                End Select
                pts.Add(SndPt1)
                pts.Add(SndPt2)
                If p <> sp AndAlso p <> ep Then
                    FnPt = API(pts.Item(2 * n - 4), pts.Item(2 * n - 3), pts.Item(2 * n - 2), pts.Item(2 * n - 1))
                    Dim FnlPt As Point3d = New Point3d(FnPt.X, FnPt.Y, gt.Z)
                    fts.Add(FnlPt)
                ElseIf p = sp Then
                    FnPt = PolarPoint(pt, Vfn, Ddst.Value)
                    Dim fnlpt As Point3d = New Point3d(SndPt1.X, SndPt1.Y, gt.Z)
                    fts.Add(fnlpt)
                ElseIf p = ep Then
                        Case True
                        Case False
                    End Select
                    fts.Add(fnlpt)
                End If
            Next
            Dim my3dpoly As Polyline3d = New Polyline3d(Poly3dType.SimplePoly, fts, False)
            btr.AppendEntity(my3dpoly)
            Tr.AddNewlyCreatedDBObject(my3dpoly, True)
            Tr.Commit()
        Catch
        Finally
            Tr.Dispose()
        End Try
    End Sub
    Friend Function PolarPoint(ByVal BasePoint As Point3d, ByVal angle As Double, ByVal distance As Double) As Point3d
        Dim x As Double = distance * Cos(angle)
        Dim y As Double = distance * Sin(angle)
        Return New Point3d(BasePoint.X + x, BasePoint.Y + y, BasePoint.Z)
    End Function
    Friend Function API(ByVal p1 As Point3d, ByVal p2 As Point3d, ByVal p3 As Point3d, ByVal p4 As Point3d) As Point3d
        Dim angAp As Double = Atan((p2.Y - p1.Y) / (p2.X - p1.X))
        Dim angBt As Double = Atan((p4.Y - p3.Y) / (p4.X - p3.X))
        Dim ar1 As Double = (((p3.Y - p1.Y) * Cos(angBt) - (p3.X - p1.X) * Sin(angBt)) / Sin(angAp - angBt))
        Dim ar2 As Double = (((p3.Y - p1.Y) * Cos(angAp) - (p3.X - p1.X) * Sin(angAp)) / Sin(angAp - angBt))
        Dim x As Double = p1.X + ar1 * Cos(angAp)
        Dim y As Double = p1.Y + ar1 * Sin(angAp)
        Return New Point3d(x, y, 0)
    End Function
    Friend Function BPI(ByVal p1 As Point3d, ByVal p2 As Point3d, ByVal p3 As Point3d, ByVal p4 As Point3d) As Point3d
    End Function
    Friend Function V(ByVal p1 As Point3d, ByVal p2 As Point3d) As Double
        Dim ang As Double = Atan((p2.Y - p1.Y) / (p2.X - p1.X))
        Return ang
    End Function
    Friend Function Dst(ByVal p1 As Point3d, ByVal p2 As Point3d) As Point3dCollection
        Dim ds As Double = Sqrt((p2.X - p1.X) ^ 2 + (p2.Y - p1.Y) ^ 2)
        Dim va As Double = V(p1, p2)
        Dim s1 As Point3d = PolarPoint(p1, va, ds / 3)
        Dim s2 As Point3d = PolarPoint(p1, va, ds * 2 / 3)
        Dim ggc As Point3dCollection = New Point3dCollection
        ggc.Add(s1)
        ggc.Add(s2)
        Return ggc
    End Function
End Class
Glenn R
Re: How to realize 3d Offset?
« Reply #1 on: February 07, 2007, 07:48:29 PM »
More dual posting < shakes head >...Help you not, I will.
« Reply #2 on: February 07, 2007, 09:06:03 PM »
Can you describe where and how it is failing you.
That may help.
I don't like VB, so find it difficult to scan read and assimilate.
What is it supposed to do.
What does it do.
What won't it do.
gilseorin
« Reply #3 on: February 08, 2007, 03:30:31 AM »
I attached my code with C#.
It works but not into right direction.
It contains many problem to solve.
If I knew what the problem is, I would solve it for myself.
I can't describe on my code, but general access is available.
First,
 PromptPointOptions DrOpt = new PromptPointOptions("" + Microsoft.VisualBasic.Chr(10) + "Specify Offset Direction: ");
 PromptPointResult Dres = Ed.GetPoint(DrOpt);
  How to determine where the point is situated of the selected 3dPolyline? Up,down,left,right?
Second,
   How to collect right point as in general offset in AutoCad command "offset"?
« Reply #4 on: February 08, 2007, 04:16:54 AM »
Please understand :
The Problem is " what is wrong" or "what is not working" or "How can I do this"
The Solution is how you would solve it.
So you CAN know the problem without being able to solve it.
just a different way of thinking ...
« Reply #5 on: February 08, 2007, 04:32:58 AM »
.. and can you describe ALL the rules you want to use to offset a 3D polyline
for instance if you have an arcs in several planes, how do you treat those ?
.. or this ?
gilseorin
« Reply #6 on: February 08, 2007, 04:49:40 AM »
Thanks for the reply.
Just advise me on that issue? General theory,information etc... on the 2d or 3d offset.
I do not beg complete code. Partial help is also much assistance to me. Thanks.
« Reply #7 on: February 08, 2007, 05:07:08 AM »
I haven't played with offsets in code
but the
Curve.GetOffsetCurves Method
Curve.GetOffsetCurvesGivenPlaneNormal Method
look interesting
I had always thought that an object had to be planar to be able to be offset.
Can anyone confirm this ?
Glenn R
« Reply #8 on: February 08, 2007, 06:20:04 AM »
Well, if you try to offset a 3dpoly, Acad tells you to politely bugger off. :)
gilseorin
« Reply #9 on: February 08, 2007, 06:25:03 AM »
What I want to use to offset a 3D polyline is just like 2d offset made by "offset" command in AutoCad.
In addition to this, Z value = existing z value + inputed z value.
« Reply #10 on: February 08, 2007, 06:36:35 AM »
using this wish, how would you expect the 3D Polyline in my picture to look ?
.. or do you mean you want to flatten it in the current UCS and then offset ?
Glenn R
« Reply #11 on: February 08, 2007, 06:39:45 AM »
Clone the damn thing then and adjust each vertice's Z ordinate.
gilseorin
« Reply #12 on: February 08, 2007, 06:43:35 AM »
Yes, in the current UCS.
« Reply #13 on: February 08, 2007, 07:18:15 AM »
Her's a drawing. The UCS needed is SwampTest in the top right viewport. The 3DPolyline is white. If you can show <manually> how you want a 600 offset to that 3dPolyline it would help me to understand
Jochen
« Reply #14 on: February 08, 2007, 07:43:35 AM »
Do you mean an 3Doffset like this?
(See the 3dpoly at the offset-Layer -
I did it using my OFFSET3D.lsp. Offset distance is 250)
Regards
Jochen
