Author Topic: Execute commands on all open drawings  (Read 12896 times)
terrycadd
« on: February 05, 2007, 02:45:32 PM »
I’m trying to find a way to execute a few commands on every open drawing. Such as “pspace”, “zoom e”, and “qsave”.  Or the commands may be different per the users or programmers requirements.  Here are two functions that I was hoping would help get me started, GetDwgsList and ActivateDwg.  The problem I’ve encountered is that once ActivateDwg changes to another open drawing, no further AutoLISP command are executed.  I’ve heard that AutoCAD 2007 has something similar as in saving all open drawings, but it’s going to be a long wait before we get 2007.  Also it would be great to have it execute any custom set of functions also.  Here is what I’ve got to start from.
; GetDwgsList - Returns a list of open drawings
; Use (length (GetDwgsList)) for the number of open drawings.
 (defun GetDwgsList (/ AcadOBJ DocsOBJ DwgsList@)
  (if (>= (atoi (getvar "ACADVER")) 15)
      (setq AcadOBJ (vlax-get-acad-object)
            DocsOBJ (vlax-get-property AcadOBJ "Documents")
            DwgsList@ nil
      );setq
      (vlax-for ForItem DocsOBJ
        (setq DwgsList@ (cons (strcat (vlax-get-property ForItem "Path") "\\"
        (vlax-get-property ForItem "Name")) DwgsList@))
      );vlax-for
      (setq DwgsList@ (reverse DwgsList@))
    );progn
    (setq DwgsList@ (list (strcat (getvar "DWGPREFIX") (getvar "DWGNAME"))))
  );if
  DwgsList@
);defun GetDwgsList
; ActivateDwg - Switches between open drawings
; Arguments: 1
;   DwgPathFilename$ = Path and filename string of drawing
; Returns: Makes the drawing of DwgPathFilename$ current
(defun ActivateDwg (DwgPathFilename$ / Cnt# Num#)
  (setq Cnt# 0 Num# 0)
  (foreach Item (GetDwgsList)
    (if (= (strcase DwgPathFilename$) (strcase Item))
      (setq Num# Cnt#)
    );if
    (setq Cnt# (1+ Cnt#))
  );foreach
  (command "vbastmt" (strcat "Application.Documents.Item(" (itoa Num#) ").Activate"))
);defun ActivateDwg
Re: Execute commands on all open drawings
« Reply #1 on: February 05, 2007, 03:14:22 PM »
Not going to happen with lisp.  Unless you can use a reactor to execute when you switch it from one drawing to the next, and then code in the reactor to switch to the next one until it reaches the end.
terrycadd
« Reply #2 on: February 05, 2007, 03:23:43 PM »
VBA code will be great.  Are there any examples around doing this?
« Reply #3 on: February 05, 2007, 03:26:46 PM »
You might find it better to post to the VBA forumn then.  I know some of them look here also, but you might be a faster respond by just posting your questions there, as I really have no idea how to code in VBA.
« Reply #4 on: February 05, 2007, 04:05:13 PM »
Forgive me if I am wrong, but with VLisp you can work on ANY open document regardless of which document is current .. can't you?
« Reply #5 on: February 05, 2007, 04:49:58 PM »
Care to explain ?
« Reply #6 on: February 05, 2007, 04:55:13 PM »
Yes, but you can't do what is asked.  Here is what you can do with a document that isn't active in the editor.
Command: (dump dbxapp)
; IAxDbDocument: IAxDbDocument Interface
; Property values:
;   Application (RO) = Exception occurred
;   Blocks (RO) = #<VLA-OBJECT IAcadBlocks 0df4d834>
;   Database (RO) = #<VLA-OBJECT IAcadDatabase 0df48dd4>
;   Dictionaries (RO) = #<VLA-OBJECT IAcadDictionaries 0df4d4a4>
;   DimStyles (RO) = #<VLA-OBJECT IAcadDimStyles 0df4d284>
;   ElevationModelSpace = 0.0
;   ElevationPaperSpace = 0.0
;   FileDependencies (RO) = #<VLA-OBJECT IAcadFileDependencies 0df48d74>
;   Groups (RO) = #<VLA-OBJECT IAcadGroups 0df4fca4>
;   Layers (RO) = #<VLA-OBJECT IAcadLayers2 0df4f894>
;   Layouts (RO) = #<VLA-OBJECT IAcadLayouts 0df4f664>
;   Limits = (0.0 0.0 12.0 9.0)
;   Linetypes (RO) = #<VLA-OBJECT IAcadLineTypes 0df4f474>
;   ModelSpace (RO) = #<VLA-OBJECT IAcadModelSpace3 0df4f144>
;   Name = ""
;   PaperSpace (RO) = #<VLA-OBJECT IAcadPaperSpace3 0df4d744>
;   PlotConfigurations (RO) = #<VLA-OBJECT IAcadPlotConfigurations 0df4ee64>
;   Preferences (RO) = #<VLA-OBJECT IAcadDatabasePreferences 0df48da4>
;   RegisteredApplications (RO) = #<VLA-OBJECT IAcadRegisteredApplications 0df4e7c4>
;   SummaryInfo (RO) = #<VLA-OBJECT IAcadSummaryInfo 0df4c884>
;   TextStyles (RO) = #<VLA-OBJECT IAcadTextStyles 0df4e474>
;   UserCoordinateSystems (RO) = #<VLA-OBJECT IAcadUCSs 0df4e424>
;   Viewports (RO) = #<VLA-OBJECT IAcadViewports 0df4e774>
;   Views (RO) = #<VLA-OBJECT IAcadViews 0df4c264>
; Methods supported:
;   CopyObjects (3)
;   DxfIn (2)
;   DxfOut (3)
;   HandleToObject (1)
;   ObjectIdToObject (1)
;   Open (2)
;   Save ()
;   SaveAs (2)
Guest
« Reply #7 on: February 05, 2007, 05:05:31 PM »
This should work for you.
Option Explicit
Public Const AppName = "VBA Thing-a-ma-jig"
Public Sub Main()
    Dim oDwg As AcadDocument
    Dim oAcad As AcadApplication
    Dim iDwgCnt As Integer
    Set oAcad = AcadApplication.Application
    iDwgCnt = 0
    For Each oDwg In oAcad.Documents
        oAcad.Documents.Item(iDwgCnt).Activate
        oDwg.ActiveSpace = acPaperSpace
        oDwg.Application.ZoomExtents
        oDwg.Save
        iDwgCnt = iDwgCnt + 1
    Next oDwg
    MsgBox "Done!", vbInformation + vbOKOnly, AppName
« Reply #8 on: February 05, 2007, 05:21:42 PM »
I was thinking of something along the lines of
(defun c:alldocs ()
 (setq app (vlax-get-acad-object))
 (setq docs (vlax-get-property app 'Documents))
 (vlax-for doc docs
       (do_something doc)
 (vlax-release-object docs)
 (vlax-release-object app)
« Reply #9 on: February 05, 2007, 05:40:47 PM »
(defun c:alldocs ()
 (vlax-for doc docs
       (do_something doc)
Still no zoom method
;   Activate ()
;   AuditInfo (1)
;   Close (2)
;   CopyObjects (3)
;   EndUndoMark ()
;   Export (3)
;   GetVariable (1)
;   Import (3)
;   LoadShapeFile (1)
;   New (1)
;   Open (2)
;   PurgeAll ()
;   Regen (1)
;   Save ()
;   SaveAs (3)
;   SendCommand (1)
;   SetVariable (2)
;   StartUndoMark ()
;   Wblock (2)
But it does look like you might be able to change the active layout.
;   ActiveLayout = #<VLA-OBJECT IAcadLayout 1beb2ae4>
terrycadd
« Reply #10 on: February 05, 2007, 06:06:55 PM »
Matt W.
In your code is it possible to pass arguments of commands or functions, so anybody can customize it as they need to? Or are we limited to editing VBA code per each change we want to make?
TC
« Reply #11 on: February 05, 2007, 09:48:16 PM »
You are quite correct, however that is not necessarily a fault of the software. If you understand that zooming in a drawing requires the calculation of the "visible" attributes of the objects in the drawing, it will be easy to understand.
Now there IS a way you can do it by simply toggling through each drawing in succession invoking the zoom method, which is the only way to do a zoom, however, you CAN cache a zoom command to be executed as soon as the drawing is made active by using
(vla-sendcommand doc (strcat "zoom" (chr 13) "e" (chr 13)))
dan19936
« Reply #12 on: February 06, 2007, 01:10:24 AM »
Can't you zoom with points? Zoom > Window > 0,0 > 11,17
FengK
« Reply #13 on: February 06, 2007, 01:59:03 AM »
I think with lisp, you can use SendCommand to excute (lisp) commands in non-active documents.
Chuck Gabriel
« Reply #14 on: February 06, 2007, 07:55:43 AM »
Terry,
Would it be an acceptable alternative to have a program open each drawing in succession and perform a given set of tasks on each one instead of having the program performs the tasks on all open drawings simultaneously?
Guest
« Reply #15 on: February 06, 2007, 09:04:55 AM »
Matt W.
TC
So if I understand you correctly, you want to make it a hybrid app that runs LSP programs?  Look into SendCommand. *shudders*
OR, you might want to do a search for 'James Buzbee'.  He's posted some hybrid apps here.
Personally, I try to avoid calling a LSP program from a VBA app.  If it can't be done with VBA or it's WAY TOO much coding (and sometimes it is - just look at how many lines of code you need to draw a line), I'll usually do it with LSP.
« Reply #16 on: February 06, 2007, 09:05:58 AM »
Not unless the document is active, if it is not active, AutoCAD cannot redraw the objects at the prescribed zoom level. Since redrawing is a function of the window (WMPAINT event) it cannot be accomplished unless the window is active.
terrycadd
« Reply #17 on: February 06, 2007, 09:58:27 AM »
Per the following post, wouldn’t you have to close all open drawings and re-open them?  Wouldn’t that be too much trouble?
Another thought was if I created a temp script on the fly of the various commands or functions I wanted to execute on all open drawings, then couldn’t vba run the same temp script on each drawing.
I haven’t written anything using the sendcommand, so I need to research it further.  Any examples would be appreciated.
« Reply #18 on: February 06, 2007, 10:00:22 AM »
Use ScriptPro (or whatever it is called now) and simply script the LISP commands for the drawings you need modified.
Guest
« Reply #19 on: February 06, 2007, 10:48:11 AM »
TC:
Give this a shot.  This uses SendCommand to load and run VBA.lsp.
DVB code
Option Explicit
Public Sub Main()
    iDwgCnt = 0
        oDwg.SendCommand "(load ""VBA.lsp"")" & vbCr & "vba" & vbCr
    Next oDwg
VBA.LSP file
(defun C:VBA ( / )
   (command "tilemode" 1)
   (command "zoom" "e")
   (command "qsave")
terrycadd
« Reply #20 on: February 06, 2007, 03:44:22 PM »
Matt, I couldn't get this Thing-a-ma-jig to work so I left it out and it worked ok.
i.e.  Public Const AppName = "VBA Thing-a-ma-jig"
Also, I wasn't able to have it run a script on every drawing, so I just modified the function to read in the script file and execute one line at a time. It's able to determine a function by enclosing them in parenthesis.
Thanks for everyone’s help.
TC
; OpenDwgsCmds - Main function that runs the other functions
; Syntax example: (OpenDwgsCmds (list "zoom" "e" "line" "0,0" "100,100" "" "(c:PurgeAll)"))
; Note: Put the functions at the end of the list.
(defun OpenDwgsCmds (ListCmds@ / Cmd$ FileName%)
  (if (not (findfile "C:\\Temp\\Temp.scr"))
    (progn (vl-load-com)(vl-mkdir "C:\\Temp"))
  );if
  (setq FileName% (open "C:\\Temp\\Temp.scr" "w"))
  (foreach Cmd$ ListCmds@
    (write-line Cmd$ FileName%)
  );foreach
  (close FileName%)
  (command "vbaload" "OpenDwgsCmds.dvb")
  (command "-vbarun" "thisdrawing.Main")
  (command "vbaunload" "OpenDwgsCmds.dvb")
);defun OpenDwgsCmds
; c:OpenDwgsCmds - Executed by OpenDwgsCmds.dvb
(defun c:OpenDwgsCmds (/ Cmd$ FileName%)
  ;(command "SCRIPT" "C:\\Temp\\Temp.scr");This caused an Execution error
  (setq FileName% (open "C:\\Temp\\Temp.scr" "r"))
  (while (setq Cmd$ (read-line FileName%))
    (if (= (substr Cmd$ 1 1) "(")
      (eval (read Cmd$));functions
      (command Cmd$);commands
    );if
  );while
  (close FileName%)
);defun c:OpenDwgsCmds
OpenDwgsCmds.dvb - vba part of the code
Option Explicit
Sub Main()
  iDwgCnt = 0
    oDwg.SendCommand "(load ""OpenDwgsCmds.lsp"")" & vbCr & "OpenDwgsCmds" & vbCr
  Next oDwg
« Last Edit: February 08, 2007, 12:48:14 AM by Terry Cadd »
Guest
« Reply #21 on: February 06, 2007, 04:07:56 PM »
Glad you got everything working!!
That's just the "name" that I gave the program.  The only time it was used was at the end when the dialog box popped up saying everything was done.
terrycadd
« Reply #22 on: February 06, 2007, 06:46:04 PM »
I'd been wanting to have a function like this, since I first started using AutoCAD 2000.  I can't believe how quickly it all came together with you guys help.  Here is a quick command line version, which uses the above functions.
TC
; c:ODC - Quick command version of the OpenDwgsCmds function
(defun c:ODC (/ Cmd$ ListCmds@ Loop)
  (princ "\nExecute commands and functions on all open drawings")
  (setq Loop t)
  (while Loop
    (setq Cmd$ (getstring "\nEnter command or function, or type 'END' to end: " t))
    (if (/= (strcase Cmd$) "END")
      (setq ListCmds@ (append ListCmds@ (list Cmd$)))
      (setq Loop nil)
    );if
  );while
  (if ListCmds@
    (OpenDwgsCmds ListCmds@)
  );if
);defun c:ODC
terrycadd
« Reply #23 on: February 09, 2007, 10:36:12 AM »
After testing this function for a few days, I’ve found out that it can run a script, and the reason for the occasional “Execution error” was that it must be run from the last in the list of open drawings. I added the c:CDC, Current Drawing Commands, to be able to test your commands in the current drawing before running them on all open drawings. I’ve attached OpenDwgsCmds.dvb, the vba part of the code, for those who may unfamiliar or uncomfortable with creating vba code.
; Arguments: 1
;   ListCmds@ = List of commands and functions to execute
; Returns: Executes list of commands and functions on all open drawings
; Syntax example: (OpenDwgsCmds (list "line 0,0 100,100" "" "(c:PurgeAll)" "zoom e"))
; Note: The current drawing must be the last in the list of open drawings.
(defun OpenDwgsCmds (ListCmds@ / Cmd$ CurrentDwg$ FileName%)
  (setq CurrentDwg$ (strcat (getvar "DWGPREFIX") (getvar "DWGNAME")))
  (if (/= CurrentDwg$ (last (GetDwgsList)))
      (alert (strcat "To run the function OpenDwgsCmds,\n"
                     "the current drawing must be the last\n"
                     "in the list of open drawings.")
      );alert
      (ActivateDwg (last (GetDwgsList)))
      (exit)
    );progn
  );if
  );if
  );foreach
  (close FileName%)
; c:CDC - Current Drawing Commands version of the OpenDwgsCmds function
(defun c:CDC (/ Cmd$ FileName% ListCmds@ Loop)
  (princ "\nExecute commands and functions on current drawing")
  (setq Loop t)
  (while Loop
    (if (= (strcase Cmd$) "END")
      (setq Loop nil)
    );if
  );while
  (if ListCmds@
      );if
      );foreach
      (close FileName%)
    );progn
  );if
);defun c:CDC
; c:ODC - Open Drawings Commands version of the OpenDwgsCmds function
(defun c:ODC (/ Cmd$ CurrentDwg$ ListCmds@ Loop)
  (princ "\nExecute commands and functions on all open drawings")(princ)
      (alert (strcat "To run the function ODC, Open Drawings\n"
                     "Commands, the current drawing must be\n"
                     "the last in the list of open drawings.")
      );alert
      (exit)
    );progn
  );if
  (setq Loop t)
  (while Loop
      (setq Loop nil)
    );if
  );while
  (if ListCmds@
  );if
);defun c:ODC
(defun c:OpenDwgsCmds ()
; Start of OpenDwgsCmds Support Utility Functions
            DwgsList@ nil
      );setq
      );vlax-for
    );progn
  );if
  DwgsList@
);defun GetDwgsList
; Arguments: 1
      (setq Num# Cnt#)
    );if
  );foreach
);defun ActivateDwg
; OpenDwgsCmds.dvb - vba part of the code
;Option Explicit
;Sub Main()
;  Dim objDwg As AcadDocument
;  Dim objAcad As AcadApplication
;  Dim intDwgCnt As Integer
;  Dim strThisDwg As String
;  Dim intThisDwg As Integer
;  Set objAcad = AcadApplication.Application
;  intDwgCnt = 0
;  strThisDwg = ThisDrawing.FullName
;  For Each objDwg In objAcad.Documents
;    If objAcad.Documents.Item(intDwgCnt).FullName <> strThisDwg Then
;      objAcad.Documents.Item(intDwgCnt).Activate
;      objDwg.SendCommand "(load ""OpenDwgsCmds.lsp"")" & vbCr & "OpenDwgsCmds" & vbCr
;    Else
;      intThisDwg = intDwgCnt
;    End If
;    intDwgCnt = intDwgCnt + 1
;  Next objDwg
;  objAcad.Documents.Item(intThisDwg).Activate
;  ThisDrawing.SendCommand "(load ""OpenDwgsCmds.lsp"")" & vbCr & "OpenDwgsCmds" & vbCr
;End Sub
(princ);End of OpenDwgsCmds
« Last Edit: May 03, 2007, 10:39:44 AM by Terry Cadd »
jessebelcher
« Reply #24 on: February 13, 2007, 05:48:55 PM »
Hello i am very new to this lisp and vba stuff. Can you  tell me how to use this file. I have the above saved in a text file. Better yet can you point me to a site that tells you how to run vba. I know how to use lisp files (cant write them very well) but the vba part has me stumped. I am willing to learn on my own just need a little push in the right direction.
Thanks.
JB
terrycadd
« Reply #25 on: February 13, 2007, 06:12:21 PM »
You can copy and paste the contents into NotePad and save the file as OpenDwgsCmds.lsp in a folder in your AutoCAD search path. Then download the OpenDwgsCmds.dvb and copy it there also. To load the function on the command line type (load "OpenDwgsCmds")
To test the quick command line version try the CDC, Current Drawing Commands function.
Command: CDC
Enter command or function, or type 'END' to end: tilemode 1
Enter command or function, or type 'END' to end: zoom e
Enter command or function, or type 'END' to end: qsave
Enter command or function, or type 'END' to end: end
To test the open drawings version try the ODC, Open Drawings Commands function.
Command: ODC
You can also include AutoCAD functions by enclosing them in parenthesis. i.e. (c:PurgeAll) etc.
There are a lot of things that you can do similar to running a script file. It's up to your needs and imagination.
The programming version of the above example would look like the following:
(OpenDwgsCmds (list "tilemode 1" "zoom e" "qsave"))
