Author Topic: (Challenge) Transformation of the list.  (Read 8369 times)
ElpanovEvgeniy
  • Moscow (Russia)
Re: (Challenge) Transformation of the list.
« Reply #15 on: February 04, 2007, 10:18:29 AM »
Evgeniy, I modify my code, now it works
Greetings Chen! :-)
At you it has perfectly turned out to perform work.
But you have decided to divide the task for two parts and have written two different programs...
I hoped to see one program, for all variants of the list...
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #16 on: February 04, 2007, 10:22:05 AM »
You needed to unite the programs in one - then will work for all examples!  :-)
(if (atom (caar lst))
 (test-1 lst)
 (test-2 lst)
qjchen
  • Best wishes to all
« Reply #17 on: February 05, 2007, 03:17:00 AM »
In order to fit the two case in one, I have to use a global variable-> *A
Now it can sove the three sample.
but it make me very sad :-(, I think it must have a good solve method.
I will try to solve it in a more simple way.
(defun ab (lst1 lst2 / res)
  (foreach x lst1
    (foreach y lst2
      (if (atom y)
(setq y (list y)
      *A T
(if (and
      (atom (car y))
      (not *A)
  (setq y (list y)
*A nil
      (setq res (append
  res
  (list (cons x y))
  res
(defun test (lst / res)
  (if (= (cdr lst) nil)
    (setq res (car lst))
    (setq res (ab (car lst) (test (cdr lst))))
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #18 on: February 05, 2007, 03:45:12 AM »
My congratulations Chen!
Last program works correctly! :)
edit >>
(test '(((11)) ((21) (22)) ((31))))
return
(((11) (21) 31) ((11) (22) 31))
but necessary
(((11) (21) (31)) ((11) (22) (31)))
« Last Edit: February 05, 2007, 03:53:17 AM by ElpanovEvgeniy »
gile
  • Marseille, France
« Reply #19 on: February 05, 2007, 04:54:40 AM »
Quite the same as the one I posted, but recursive form.
(defun test (l / sub1 sub2)
  (defun sub1 (e l)
    (if l
      (cons (append e (list (car l)))
    (sub1 e (cdr l))
  (defun sub2 (l)
    (if (cadr l)
      (sub2
(cons (apply 'append
     (mapcar '(lambda (x)
(sub1 x (cadr l))
     (car l)
      (cddr l)
      (car l)
  (sub2 (cons (mapcar 'list (car l)) (cdr l)))
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #20 on: February 05, 2007, 05:04:34 AM »
Excellently!
You have made the program which is very similar to mine...
All differences - at me all in one function (test).
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #21 on: February 05, 2007, 11:27:46 AM »
My version of the program...
(defun te (l)
 ;; (te l)
 ;; By ElpanovEvgeniy
 (if (cdr l)
  (apply
   (function append)
   (mapcar (function (lambda (a) (mapcar (function (lambda (b) (cons a b))) (te (cdr l)))))
           (car l)
   ) ;_  mapcar
  ) ;_  apply
  (mapcar (function list) (car l))
 ) ;_  if
) ;_  defun
gile
  • Marseille, France
« Reply #22 on: February 05, 2007, 12:30:55 PM »
 :-o One more time, a wonder of concision !!!
« Last Edit: February 06, 2007, 01:04:04 AM by gile »
« Reply #23 on: February 05, 2007, 04:42:24 PM »
WOW!!!
qjchen
« Reply #24 on: February 07, 2007, 08:05:22 PM »
so short code.
Evgeniy, could you tell me how to learn mapcar and recursive, is the only way that practice, or there are some quick way.:)
« Reply #25 on: February 07, 2007, 09:10:37 PM »
so short code.
 :wink:  ... about 15 years of practice   :-)
