Author Topic: (Challenge) Transformation of the list.  (Read 8366 times)
ElpanovEvgeniy
  • Moscow (Russia)
« on: February 02, 2007, 03:32:23 AM »
Yesterday, I have received the letter:
14:17 Evgeniy hello :-)
If there is time, help my, to make something beautiful
I had perfectly a good time!
I suggest you to write program TEST
Example 1:
(setq l '(((11))
          ((21) (22))
          ((31))
(test l)
'(((11) (21) (31))
  ((11) (22) (31)))
Example 2:
(setq l '(((11) (12))
          ((21))
          ((31) (32))
          ((41) (42))
(test l)
'(((11) (21) (31) (41))
  ((11) (21) (31) (42))
  ((11) (21) (32) (41))
  ((11) (21) (32) (42))
  ((12) (21) (31) (41))
  ((12) (21) (31) (42))
  ((12) (21) (32) (41))
  ((12) (21) (32) (42)))
Example 3:
(setq l '((11)
          (21 22)
          (31 32 33)
(test l)
'((11 21 31)
  (11 21 32)
  (11 21 33)
  (11 22 31)
  (11 22 32)
  (11 22 33))
ElpanovEvgeniy
  • Moscow (Russia)
Re: (Challenge) Transformation of the list.
« Reply #1 on: February 02, 2007, 12:08:22 PM »
On Monday, at this time, I shall show my variant...
Have a good time!
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #2 on: February 03, 2007, 09:37:29 AM »
I am surprised!
Nobody wishes to show the code, for the decision of this problem...
Probably I have badly explained the task?
Tell to me, in what complexity...
PS. This task is not interesting?
« Reply #3 on: February 03, 2007, 10:01:19 AM »
Sorry Evgeniy,
I am still trying to understand the problem. (complex.)
Can you explain again?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: February 03, 2007, 10:05:11 AM »
(setq lst '((11 12) (21) (31 32)))
It is necessary to find all variants of the transposed list without repetitions
(test lst)
((11 21 31) (11 21 32) (12 21 31) (12 21 32))
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: February 03, 2007, 10:10:27 AM »
11,12,21,31,32 = atom or list...
(length lst) = any
(length (car lst)) = any
« Reply #6 on: February 03, 2007, 10:13:54 AM »
Ahh!! Very good!! Thank you.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: February 03, 2007, 10:15:44 AM »
Sorry Evgeniy,
No problem!
The problem for a long time is solved, I wished to enable to have a good time to you...
It is a little to knead brains.  :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #8 on: February 03, 2007, 10:48:30 AM »
I wish to explain the task once again...  :?
(test '((11 12) (21 22)))
Returns:
(([11 or 12] [21 or 22]) ([11 or 12] [21 or 22])....)
(test '((11 12 13) (21 22) (31 32 33)))
Returns:
(([11 or 12 or 13] [21 or 22] [31 or 32 or 33])....)
(test '((11) (21 22) (31 32 33)))
Returns:
(([only 11] [21 or 22] [31 or 32 or 33])....)
« Reply #9 on: February 03, 2007, 10:51:14 AM »
I believe Evgeniy has give us a challenge involving ``Permutations and Combinations''
This will be a lot of fun!
gile
  • Marseille, France
« Reply #10 on: February 03, 2007, 12:39:06 PM »
Here's my contribution.
EDIT: I'm sorry there was a little mistake (sub1 instead of sub).
(defun test (l / sub)
  (defun sub (e l)
    (if l
      (cons (append e (list (car l)))
    (sub e (cdr l))
  (setq l (cons (mapcar 'list (car l)) (cdr l)))
  (while (cadr l)
    (setq l (cons
      (apply 'append
     (mapcar '(lambda (x)
(sub x (cadr l))
     (car l)
      (cddr l)
  (car l)
« Last Edit: February 03, 2007, 01:00:57 PM by gile »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #11 on: February 03, 2007, 12:50:48 PM »
Greetings gile
At you it has very well turned out!
qjchen
  • Best wishes to all
« Reply #12 on: February 04, 2007, 03:00:05 AM »
hi,evgeniy, I use recursive method to do it
(defun ab (lst1 lst2 / res)
  (foreach x lst1
    (foreach y lst2
      (if (atom y)
(setq y (list y))
      (setq res (append
  res
  (list (cons x y))
  res
(defun test (lst / res)
  (if (= (cdr lst) nil)
    (setq res (car lst))
    (setq res (ab (car lst) (test (cdr lst))))
(setq l (list (list 1 2 3) (list 4 5 ) (list 6 7 8 9) (list 10 11)))
(test l)=>
((1 4 6 10) (1 4 6 11) (1 4 7 10) (1 4 7 11) (1 4 8 10) (1 4 8 11) (1 4 9 10) (1 4 9 11) (1 5 6 10) (1 5 6 11) (1 5 7 10) (1 5 7 11) (1 5 8 10) (1 5 8 11) (1 5 9 10) (1 5 9 11) (2 4 6 10) (2 4 6 11) (2 4 7 10) (2 4 7 11) (2 4 8 10) (2 4 8 11) (2 4 9 10) (2 4 9 11) (2 5 6 10) (2 5 6 11) (2 5 7 10) (2 5 7 11) (2 5 8 10) (2 5 8 11) (2 5 9 10) (2 5 9 11) (3 4 6 10) (3 4 6 11) (3 4 7 10) (3 4 7 11) (3 4 8 10) (3 4 8 11) (3 4 9 10) (3 4 9 11) (3 5 6 10) (3 5 6 11) (3 5 7 10) (3 5 7 11) (3 5 8 10) (3 5 8 11) (3 5 9 10) (3 5 9 11))
and if the l structure is different
like
(setq l '(((11))((21) (22))((31))))
the code maybe like as follow
  (foreach x lst1
    (foreach y lst2
      (if (atom (car y))
(setq y (list y))
      (setq res (append
  res
  (list (cons x y))
  res
(test1 l)===>
(((11) ((21) (31))) ((11) ((22) (31))))
(setq l '(((11)) ((21) (22))
       ((31)) ((41)(42)(43))
(test l)
(((11) (21) (31) (41)) ((11) (21) (31) (42)) ((11) (21) (31) (43)) ((11) (22) (31) (41)) ((11) (22) (31) (42)) ((11) (22) (31) (43)))
« Last Edit: February 04, 2007, 10:11:07 AM by yuanqiu »
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #13 on: February 04, 2007, 03:47:12 AM »
like
(defun cd (lst1 lst2 / res)
  (foreach x lst1
    (foreach y lst2
      (setq res (append
  res
  (list (list x y))
  res
(defun test1 (lst / res)
    (setq res (cd (car lst) (test1 (cdr lst))))
(test1 l)===>
It is very a pity, but for the list
It is necessary to receive
(((11) (21) (31)) ((11) (22) (31)))
For other lists.
(caar lst) == atom
Your program works! :)
« Last Edit: February 04, 2007, 03:50:38 AM by ElpanovEvgeniy »
qjchen
« Reply #14 on: February 04, 2007, 10:12:17 AM »
Evgeniy, I modify my code, now it works, sorry, it can do Example 1 and 2 ,but not 3, it seems that I still not finished.
« Last Edit: February 04, 2007, 10:17:43 AM by yuanqiu »
