Author Topic: Stairs with a landing  (Read 2183 times)
spawnd
« on: January 30, 2007, 11:45:59 AM »
I am having troubles with stairs with a landing at the top that turns 90 degrees with 1 riser that goes to finished floor.  when i draw it i get a long landing and a the defect circle.  If someone can let me know how this works that would be very helpful.
Krushert
  • FREE BEER Tomorrow!!
Re: Stairs with a landing
« Reply #1 on: January 30, 2007, 11:58:29 AM »
Don't Start me to lying but I will hang around to find out how to do it.
BTW Welcome to the Swamp
I no longer CAD or Model, I just hang out here for camaraderie
daron
« Reply #2 on: February 02, 2007, 04:48:18 PM »
multi-landing; quarter-landing. Run your line to all but the last number, pick a point, turn 90 and extend all the way out until you can't extend anymore. Does that help? I just did that and it worked for me.
spawnd
« Reply #3 on: February 05, 2007, 02:12:51 PM »
yes it does.  I have been tring to use half turn.  thanks
« Reply #4 on: February 05, 2007, 03:58:14 PM »
half turns require a 6" minimum dimension at the smallest edge of the tread, thus a 90 would have to be 6" wider than the stair width.
daron
« Reply #5 on: February 06, 2007, 10:30:55 PM »
Good info Keith. I'll have to try and remember that one.
