Author Topic: Syntax for email  (Read 11184 times)
Adesu
Syntax for email
« on: January 23, 2007, 02:31:04 AM »
Hi Alls,
That code I got from a forum,if that code load ,in column "cc" and "attachment" still blank,what wrong in syntax?.
(setq mail
   (strcat
      "mailto:adesu@telkom.net"
      "ccto=adesu_cad@yahoo.com"  ; still problem
      "?Subject=test send email via autolisp"
      "&body=This email has been sended by autolisp"
      "&attachment=\"D:\\Attention.eml\""   ; still problem
(setq Ishell
   (vla-GetInterfaceObject
      (vlax-get-acad-object)
      "Shell.Application"))
(vlax-invoke-method Ishell 'OPEN mail)
(vlax-release-object Ishell)
Patrick_35
Re: Syntax for email
« Reply #1 on: January 23, 2007, 03:09:29 AM »
Adesu
« Reply #2 on: January 23, 2007, 03:23:38 AM »
I just revised that code,but attach file still not yet display,any idea
(setq mail
   (strcat
      "?cc=adesu_cad@yahoo.com"
      "&Subject=test send email via autolisp"
      "&attachment=(findfile \"D:\\YBI\\Drawing\\Lat\\2 D\\gear.dwg\")" ; still problem
(setq Ishell
Adesu
« Reply #3 on: January 23, 2007, 03:40:46 AM »
Look at attach file,I want like that
Patrick_35
« Reply #4 on: January 23, 2007, 03:49:19 AM »
Yes, and you can do it with activex
(setq Outlk (vlax-Create-Object "CDO.Message"))
(setq Serv (vlax-Get-Property (vlax-Get-Property Outlk 'Configuration) 'Fields))
(vlax-Put-Property (vlax-Get-Property Serv 'Item "http://schemas.microsoft.com/cdo/configuration/sendusing")      'Value 2)
(vlax-Put-Property (vlax-Get-Property Serv 'Item "http://schemas.microsoft.com/cdo/configuration/smtpserver")     'Value "ServerSMTP") ; ex: smpt.aol.com
(vlax-Put-Property (vlax-Get-Property Serv 'Item "http://schemas.microsoft.com/cdo/configuration/smtpserverport") 'Value 25)
(vlax-Invoke Serv 'Update)
(vlax-Put-Property Outlk 'From     "My_email@server.com")
(vlax-Put-Property Outlk 'To       "Recipient@server.com")
(vlax-Put-Property Outlk 'Subject  "Subject")
(vlax-Put-Property Outlk 'TextBody "My Message")
(vlax-invoke outlk 'AddAttachment  "My_Text.txt")
(if (vl-catch-all-error-p (vl-catch-all-apply 'vlax-invoke (list outlk 'Send)))
  (princ "\nImpossible to send the message. No connection Internet")
(vlax-Release-Object Outlk)
Adesu
« Reply #5 on: January 23, 2007, 04:01:33 AM »
Hi Patrick,
I just tested your code,and got
#<VLA-OBJECT IMessage 08309104>
#<VLA-OBJECT Fields 07c34c5c>
nil
nil
nil
nil
nil
nil
nil
nil
; error: CDO.Message.1: The specified protocol is unknown.
_$
Patrick_35
« Reply #6 on: January 23, 2007, 04:16:33 AM »
It's here. You must change the value of server SMPT by your SMTP
But if the mail is already configured, this part of the code is not obligatory
VVA
« Reply #7 on: January 23, 2007, 04:57:04 AM »
Try It
;;Usage
;;;(send_message "Target@mail.ru" "Send DWG" "Hi, I send DWG-File.\nBye." "c:\\temp\\ABC.DWG")
(defun send_message (adr tema message Attachment / objOutlook MailItem AddAdresse objAttachment )
  (setq objOutlook (vlax-Create-Object "Outlook.Application"))
  (if objOutlook
      (setq MailItem (vlax-Invoke-Method objOutlook 'CreateItem 0))
      (setq objMail (vlax-get-property Mailitem 'Recipients))
      (setq AddAdresse (vlax-Invoke-Method objMail 'Add adr))
      (setq objAttachment (vlax-get-property Mailitem 'Attachments))
      (vlax-Invoke-Method objAttachment 'Add Attachment 1 1 Attachment)
      (vlax-put-property Mailitem 'Subject tema)
      (vlax-put-property Mailitem 'Body message)
      (vlax-Invoke-Method MailItem 'Send)
    ); end progn
  ); end if
  (vlax-invoke-method objOutlook "Quit")
  (mapcar
    (function (lambda (x)
      (and x (not (vlax-object-released-p x)))
      (vlax-release-object x)
    );end if
    (list AddAdresse objAttachment objMail MailItem objOutlook)
  (setq objOutlook nil MailItem nil objMail nil objAttachment nil AddAdresse nil)
  (gc)
); end defun
terrycadd
« Reply #8 on: January 23, 2007, 10:10:09 AM »
This is a very cool idea!  I tested the last posted function, without errors.  There is only one small issue I found on my system.  When I went to Outlook to check the status of the last sent message it reported "This message has not been sent."  So I pressed the [Send] button and then check my email and it went through.  Any ideas as to what else I need to modify on my system to make it initialize the Send property?
Adesu
« Reply #9 on: January 23, 2007, 08:46:10 PM »
Hi VVA,
Thanks for your sharing with my problem,here after I tested your code,your code still got trouble look at below
SEND_MESSAGE
_$
"adesu@telkom.net"
"Send DWG"
"D:\\YBI\\Drawing\\Lat\\Gear.dwg"
; error: bad argument type: VLA-OBJECT nil
_$
Here your code I revised a few of part
(setq to "adesu@telkom.net")
(setq sub "Send DWG")
(setq bod "Hi, I send DWG-File.\nBye.")
(setq att "D:\\YBI\\Drawing\\Lat\\Gear.dwg")
(send_message to sub bod att)
Try It
;;Usage
  (if objOutlook
    ); end progn
  ); end if
  (mapcar
    );end if
  (gc)
); end defun
Adesu
« Reply #10 on: January 23, 2007, 08:52:41 PM »
Why this code is nil
$ (setq objOutlook (vlax-Create-Object "Outlook.Application"))
nil
_$
Adesu
« Reply #11 on: January 23, 2007, 09:05:17 PM »
Hi Patrick_35,
Here code from and then I revised it as your suggest
;(vlax-dump-object Outlk)
;(setq vgp (vlax-Get-Property Outlk 'Configuration))
;(vlax-dump-object vgp)
;(setq Serv (vlax-Get-Property vgp 'Fields))
;(vlax-dump-object Serv)
(setq http1 "http://schemas.microsoft.com/cdo/configuration/sendusing")
(setq http2 "http://schemas.microsoft.com/cdo/configuration/smtpserver")
(setq http3 "http://schemas.microsoft.com/cdo/configuration/smtpserverport")
(vlax-Put-Property (vlax-Get-Property Serv 'Item http1) 'Value 2)
(vlax-Put-Property (vlax-Get-Property Serv 'Item http2) 'Value "smtp.cbn.net.id")
(vlax-Put-Property (vlax-Get-Property Serv 'Item http3) 'Value 25)
(vlax-Put-Property Outlk 'From     "mteybid@yuasabattery.co.id")
(vlax-Put-Property Outlk 'To       "adesu_cad@yahoo.com.com")
(vlax-Put-Property Outlk 'Subject  "Test send email via autolisp")
(vlax-Put-Property Outlk 'TextBody "This email has been sended by autolisp program")
(vlax-invoke outlk 'AddAttachment  "Adesu.txt")
Patrick_35
« Reply #12 on: January 24, 2007, 03:01:54 AM »
Hi
The advantage has my opinion to use (vlax-Create-Object “CDO.Message”) rather than (vlax-Create-Object “Outlook.Application”) it's that you don't need to have Outlook of installed on your PC.
You are useful yourself of Activex which is normally pass key Moreover
If you seek well, the shipper can be anonymous
Adesu
« Reply #13 on: January 24, 2007, 08:56:15 PM »
Hi Patrick,
I hope you not bore to answer my question,your code in my opinion is "GOOD",but after I tested,it still got problem,at the recipient email not yet received,look at this below
Command: test
Enter Destination address <adesu_cad@yahoo.com>:
Enter subject for this email: test
Enter text body for this email: Test Hello
Command:
And here your code after I revised
(defun c:test (/ http1 http2 http3 outlk serv val val1 val2 val3
       vgp vgp_http1 vgp_http2 vgp_http3)
      (setq vgp_http1 (vlax-Get-Property Serv 'Item http1))
      (setq val1 (vlax-get vgp_http1 'Value))
(/= val 2)
(vlax-Put-Property vgp_http1 'Value 2)
)                                      ; if
      (setq vgp_http2 (vlax-Get-Property Serv 'Item http2))
      (setq val2 (vlax-get vgp_http2 'Value))
(/= val2 "smtp.cbn.net.id")
(vlax-Put-Property vgp_http2 'Value "smtp.cbn.net.id")
)                                      ; if
      (setq vgp_http3 (vlax-Get-Property Serv 'Item http3))
      (setq val3 (vlax-get vgp_http3 'Value))
(/= val3 25)
(vlax-Put-Property vgp_http3 'Value 25)
)                                      ; if
      (setq desti (getstring t "\nEnter Destination address <adesu_cad@yahoo.com>: "))
      (if (= desti "")(setq desti "adesu_cad@yahoo.com"))
      (vlax-Put-Property Outlk 'To desti)
      (setq sub (getstring t "\nEnter subject for this email: "))
      (vlax-Put-Property Outlk 'Subject sub)
      (setq tb (getstring t "\nEnter text body for this email: "))
      (vlax-Put-Property Outlk 'TextBody tb)
      (vlax-invoke outlk 'AddAttachment  "D://YBI/Drawing/Lat/2 D/Gear.dwg")
      )                        ; progn
    (alert "\nit can not run this message")
    )                          ; if
  )                            ; defun
Adesu
« Reply #14 on: January 24, 2007, 08:58:49 PM »
Here data for that outlook
; before
_$
; IMessage: Defines methods, properties, and collections used to manage a message.
; Property values:
;   Attachments (RO) = #<VLA-OBJECT IBodyParts 04be45c8>
;   AutoGenerateTextBody = -1
;   BCC = ""
;   BodyPart (RO) = #<VLA-OBJECT IBodyPart 04be46f8>
;   CC = ""
;   Configuration = #<VLA-OBJECT IConfiguration 04be494c>
;   Configuration (RO) = ...Indexed contents not shown...
;   DataSource (RO) = #<VLA-OBJECT IDataSource 04be5060>
;   DSNOptions = 0
;   EnvelopeFields (RO) = CDO.Message.1: The requested property or feature, while supported, is not available at this time or in this context.
;   Fields (RO) = #<VLA-OBJECT Fields 07070ec4>
;   FollowUpTo = ""
;   From = ""
;   HTMLBody = ""
;   HTMLBodyPart (RO) = CDO.Message.1: The requested body part was not found in this message.
;   Keywords = ""
;   MDNRequested = 0
;   MimeFormatted = -1
;   Newsgroups = ""
;   Organization = ""
;   ReceivedTime (RO) = 0.0
;   ReplyTo = ""
;   Sender = ""
;   SentOn (RO) = 0.0
;   Subject = ""
;   TextBody = ""
;   TextBodyPart (RO) = CDO.Message.1: The requested body part was not found in this message.
;   To = ""
T
_$
; after
_$
; Property values:
;   Attachments (RO) = #<VLA-OBJECT IBodyParts 018528d0>
;   AutoGenerateTextBody = 0
;   BCC = ""
;   BodyPart (RO) = #<VLA-OBJECT IBodyPart 018508b0>
;   CC = ""
;   Configuration = #<VLA-OBJECT IConfiguration 01850984>
;   DataSource (RO) = #<VLA-OBJECT IDataSource 01850a58>
;   DSNOptions = 0
;   Fields (RO) = #<VLA-OBJECT Fields 07074ba4>
;   FollowUpTo = ""
;   From = "\"mteybid@yuasabattery.co.id\" <mteybid@yuasabattery.co.id>"
;   HTMLBody = ""
;   Keywords = ""
;   MDNRequested = 0
;   Newsgroups = ""
;   Organization = ""
;   ReplyTo = ""
;   Sender = ""
;   SentOn (RO) = 0.0
;   Subject = "Test send email via autolisp"
;   TextBody = "This email has been sended by autolisp program"
;   TextBodyPart (RO) = #<VLA-OBJECT IBodyPart 01852a20>
;   To = "\"adesu_cad@yahoo.com\" <adesu_cad@yahoo.com>"
T
_$
Patrick_35
« Reply #15 on: January 28, 2007, 03:10:48 PM »
I send me this message and it's ok
(vlax-Put-Property (vlax-Get-Property Serv 'Item "http://schemas.microsoft.com/cdo/configuration/smtpserver")     'Value "smtp.aliceadsl.fr");"ServeurSMTP"
(vlax-Put-Property Outlk 'To       "patrick35@tiscali.fr");"Recipient@server.com")
  (princ "\nImpossible d'envoyer le message. Pas de connection internet")
Adesu
« Reply #16 on: January 28, 2007, 11:30:34 PM »
Hi Patrick,
I got it,your code is great,thanks you very much
Adesu
« Reply #17 on: January 29, 2007, 02:46:20 AM »
Hi Patrick,
Here picture email or look at attach file,and this code ,then not forgot ,thanks you very much for your help
(defun c:test (/ outlk serv)
    'Value 2)
    'Value 25)
  (vlax-Put-Property Outlk 'To       "mteybid@yuasabattery.co.id")
  (vlax-Put-Property Outlk 'Subject  "Test send email via Autolisp")
  (vlax-Put-Property Outlk 'TextBody "Hi Adesu, Here I just tested email,please feed back again to me,I wait it")
« Last Edit: January 29, 2007, 02:49:54 AM by Adesu »
Patrick_35
« Reply #18 on: January 29, 2007, 03:11:06 PM »
Hi Adesu
For attach a file, you do
(vlax-invoke outlk 'AddAttachment  "My_file.any_extension")before send your message
Maverick®
« Reply #19 on: January 29, 2007, 03:54:02 PM »
Adesu,  You may want to block out your email address in that image.  Just not something I would recommend posting.
Regards,
Maverick
CADwiesel
  • Wir machen das Mögliche unmöglich
« Reply #20 on: March 06, 2007, 03:38:00 AM »
I have following sendmail code:
(defun M:SENDMAIL (an Betreff Inhalt / MAIL OLOBJ)
  (setq OLOBJ (vlax-Get-Or-Create-Object "Outlook.Application")
        MAIL  (vlax-invoke-method OLOBJ "CreateItem" 0)
        ) ;_ ende von setq
  (vlax-invoke-method
    (vlax-get-property
      MAIL
      'recipients
    'add
    an
  (vlax-put-property MAIL 'subject betreff)
  (vlax-put-property MAIL 'body Inhalt)
  (vlax-invoke-method MAIL 'send)
  (vlax-release-object OLOBJ)
  (prin1)
(M:SENDMAIL "cadwiesel@cadwiesel.de"
        "testmail";Betr
        (strcat "Sehr geehrter Herr Blahblah..\n\n"
                "<A href="(chr 34)
                "C:\\TEMP\\test.xls>"
                (chr 34)
                "klick hier"
                "</A>"
                "\n\n\n mit freundlichem Gruß\n\n CADwiesel")
The question i have is:
How is it possible to create an link in the Body tag of the document.
I want to send the text  "C:\\TEMP\\test.xls>" shown as url.
Do anyone knows how this works?
CADwiesel
Gruß
CADwiesel
Besucht uns im CHAT
