Can anyone with .NET 2.0 Runtime and a version of AutoCAD greater than 2005 installed test an assembly for me? I compiling against the 2005 versions of the managed dll files and am wondering if anyone else can use them, mainly since the method of writing to the command line has changed between 2005 and future versions.
To Run:
* netload the PyAcadDotNet.dll
* issue the pyfile command
* browse to the folder you unziped to and select print.py
If you see a bunch of text strings dumped onto the commandline then it worked. If not please let me know. I'm doing some trickery to automatically add the AutoCAD managed dlls as references in python so that may be screwing things up.
Here is the source code for the dll if anyone is interested.
PyAcadDotNet.cs
Copyright (c) 2005, Tim Riley (riltim@gmail.com)
All rights reserved.
Redistribution and use in source and binary forms, with or without modification, are
permitted provided that the following conditions are met:
- Redistributions of source code must retain the above copyright notice, this list
of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright notice, this list
of conditions and the following disclaimer in the documentation and/or other materials
provided with the distribution.
- Neither the name Tim Riley nor the names of its contributors may be used to
endorse or promote products derived from this software without specific prior written
permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS &AS IS& AND ANY EXPRESS
OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
using System;
using System.Collections;
using System.Windows.Forms;
using System.IO;
using System.Text;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
using IronPython.Hosting;
namespace PyAcadDotNet
public class AcadInterface : IExtensionApplication
public Autodesk.AutoCAD.ApplicationServices.Application AcadApplication;
public void Initialize()
CommandLinePrompts.Message("\nPyAcad.NET Loaded Successfully....");
CommandLinePrompts.Message("\ntype 'pyhelp' for commands....");
public void Terminate()
//nothing to see here.
delegate void AddReference(object assembly);
[CommandMethod("pyfile", CommandFlags.Session)]
public void pythonfile()
// Create a new instance of PythonEngine and set variables.
PythonEngine engine = new PythonEngine();
engine.AddToPath(Environment.CurrentDirectory);
// Send Stdout and Stderr to the AutoCAD command line.
engine.SetStandardOutput(new AcadCommandLine());
engine.Import("clr");
//lets load some AutoCAD assemblies.
AddReference adr = engine.CreateMethod<AddReference>("clr.AddReference(assembly)");
adr(typeof(BlockTableRecord).Assembly);
adr(typeof(Editor).Assembly);
// Display an OpenFileDialog and run the script.
OpenFileDialog ofd = new OpenFileDialog();
ofd.Filter = "Python files (*.py)|*.py|All files (*.*)|*.*" ;
ofd.ShowDialog();
// Run the file selected by the open file dialog box.
//engine.ExecuteFile(ofd.FileName);
CompiledCode cc = engine.CompileFile(ofd.FileName);
cc.Execute();
class AcadCommandLine : Stream
//Modified version of a class coded by Mike Stall.
#region unsupported Read + Seek members
public override bool CanRead
get { return false; }
public override bool CanSeek
public override bool CanWrite
get { return true; }
public override void Flush()
// nop
public override long Length
get { throw new NotSupportedException("Seek not supported"); } // can't seek
public override long Position
get
throw new NotSupportedException("Seek not supported"); // can't seek
set
public override int Read(byte[] buffer, int offset, int count)
throw new NotSupportedException("Reed not supported"); // can't read
public override long Seek(long offset, SeekOrigin origin)
public override void SetLength(long value)
#endregion
public override void Write(byte[] buffer, int offset, int count)
// Very bad hack: Ignore single newline char. This is because we expect the newline is following
// previous content and we already placed a newline on that.
if (count == 1 && buffer[offset] == '\n')
return;
StringBuilder sb = new StringBuilder();
while (count > 0)
char ch = (char) buffer[offset];
if (ch == '\n')
CommandLinePrompts.Message(sb.ToString() + "\n");
sb.Length = 0; // reset.
else if(ch != '\r')
sb.Append(ch);
offset++;
count--;
if (sb.Length > 0)
CommandLinePrompts.Message(sb.ToString()+ "\n");
