Author Topic: What is it ??  (Read 8863 times)
What is it ??
« on: January 22, 2007, 02:42:31 AM »
Having a play ..
This is interesting !!
ent.List();
        [AcRx.CommandMethod("ListIt")]
        static public void ListIt()
            AcEd.Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            AcEd.PromptEntityResult resEnt = ed.GetEntity("\nSelect an Object: ");
            if (resEnt.Status != AcEd.PromptStatus.OK)
                ed.WriteMessage("\nNothing selected");
                return;
            // Something selected, so ..
            // do lots of unnecessary testing stuff ..
            ed.WriteMessage("\n PromptEntityResult : " + resEnt.ToString());
            ed.WriteMessage("\n PickedPoint : " + resEnt.PickedPoint.ToString());
            // Get the ObjectId
            AcDb.ObjectId ObjId = (resEnt.ObjectId);
            ed.WriteMessage("\n Object Id : " + resEnt.ObjectId.ToString());
            // Get the Entity
            AcDb.Entity ent = kbGetEntity(resEnt.ObjectId);
            ed.WriteMessage("\n Entity : " + ent.ToString() + "\n");
            ent.List();
            Extents3d extents3D = ent.GeometricExtents;
            ed.WriteMessage("\n extents3D : " + extents3D.ToString());
            ed.WriteMessage("\n extents3D.LLPoint : " + extents3D.MinPoint.ToString());
            ed.WriteMessage("\n extents3D.URPoint : " + extents3D.MaxPoint.ToString());
            [color=red]/// PROBLEM : how to locate the Entity WCS location ??[/color]
        /// <summary>
        public static AcDb.TransactionManager kbGetTransMan
            get
                return AcadApp.DocumentManager.MdiActiveDocument.TransactionManager;
        public static AcDb.Entity kbGetEntity(AcDb.ObjectId id)
            AcDb.Entity ent;
            AcDb.TransactionManager tm = kbGetTransMan;
            using (AcDb.Transaction tr = tm.StartTransaction())
                ent = (AcDb.Entity)tm.GetObject(id, AcDb.OpenMode.ForRead, true);
            return ent;
Here's the tough Part : How to determine the WCS location of the selected entity.
Seems a pain, but I may have to pass the type to a case function and get the 'location' property depending on the type of object .. Any ideas ??
« Last Edit: January 22, 2007, 04:56:49 AM by Kerry Brown »
Re: What is it ??
« Reply #1 on: January 22, 2007, 05:09:51 AM »
Perhaps it can be done getting the entity ECS and performing a translation ... but thats a W.A.G. and I'm brain dead tonight ...
LE
Re: What is it ??
« Reply #2 on: January 22, 2007, 02:05:16 PM »
I have not used the Extents3d.
But in the implementations I have seen they use GeomExtents or GetBoundingBox
using Autodesk.AutoCAD.Interop;
As far as I know...
Remember that this respond of mine, will be destroy in 24hrs.... [11:03 AM 1/22/2007 counting started...]
Re: What is it ??
« Reply #3 on: January 23, 2007, 12:01:32 AM »
I wonder if it is possible to get the correct GeometricExtents or boundingBox of a 3Dobject no matter its orientation, with .NET. I tried so many times to do this with lisp but failed.  My goal was to find the width, length, height of a 3D object based off its bounding box.
Using Kerry’s code
using System;
[assembly: CommandClass(typeof(aClassLibrary.CRPClass))]
namespace aClassLibrary
  public class CRPClass
    public CRPClass()
    [CommandMethod("test")]
    static public void test()
      Extents3d extents3D;
      TypedValue[] values = new TypedValue[]
                       new TypedValue((short)DxfCode.Start, "3DSOLID") ,
      SelectionFilter filter = new SelectionFilter(values);
      PromptSelectionOptions selopts = new PromptSelectionOptions();
      selopts.MessageForAdding = "Select";
      selopts.AllowDuplicates = false;
      PromptSelectionResult result = ed.GetSelection(selopts, filter);
      if (result.Status == PromptStatus.OK)
        ObjectId[] idarray = result.Value.GetObjectIds();
        Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager;
        Transaction tr = tm.StartTransaction();
        try
          foreach (ObjectId id1 in idarray)
            Entity entity1 = (Entity)tm.GetObject(id1, OpenMode.ForRead, true);
            extents3D = entity1.GeometricExtents;
          tr.Dispose();
« Last Edit: January 23, 2007, 12:05:27 AM by Danielm103 »
Re: What is it ??
« Reply #4 on: January 23, 2007, 12:13:36 AM »
Daniel, the easiest way to achieve this is by attaching 'worldpoint' xdata at creation time that indicates the extrusion direction and say an x/y axis which can be used to form a ucs to transform the object to world to get the bbox dimensions, invert the matrix and send it back. Rob Kish had some very serious vba code a few years ago that was very close and if I new then what I know now it probably wouldn't take much to get it to work without the xdata but those thoughts/code are long dissolved in memory somewhere :)
- John Carmack
- J.R.R. Tolkien
Re: What is it ??
« Reply #5 on: January 23, 2007, 12:41:27 AM »
Thanks Mick,
Interesting, I never thought of using worldpoint, What I do now is draw my parts in the correct orientation and assign the width, height  and depth in xdata at extrusion. I did get pretty far with lisp and decoding the ACIS, but I gave up.  I’ll have to take another shot at it one of these days. I do know it is possible, and I know it would be a cool tool to have
Dan
Re: What is it ??
« Reply #6 on: January 23, 2007, 12:51:34 AM »
no prob's, the simplest way is to store the normal of the region you need to create the 3dSolid as the worldpoint (z axis), it is automatically updated with modifications such as rotating/mirroring etc. This is pretty simple as you at most times know the width and depth of your 'section' to extrude, I just use the worldpoint as a vector and create an arbitory matrix to rotate to world and back using the min/max z coord's for the length, easy peasy ;)
- John Carmack
- J.R.R. Tolkien
Re: What is it ??
« Reply #7 on: January 23, 2007, 12:52:19 AM »
Here's something to get your britches in a knot.
The GeometricExtents is incorrect for text based types.
It reports 0,0,0 as the LL irrespective ... bummer.
compare it's output with/against this :
(defun c:test_bb (/ ll ur)
    (vla-getboundingbox (vlax-ename->vla-object (car (nentsel))) 'll 'ur)
    (princ (vlax-safearray->list ll))
    (princ (vlax-safearray->list ur))
I'll report it, they may get it fixed in the next month [ in time for AC2008 ]
edit: fixed local variables. duh!
« Last Edit: January 23, 2007, 01:09:10 AM by Kerry Brown »
Re: What is it ??
« Reply #8 on: January 23, 2007, 06:40:22 AM »
Change Request 862345 - GEOMETRICEXTENTS RETURNING INCORRECT VALUES FOR TEXT AND MTEXT.
Already fixed for AC2008.
Re: What is it ??
« Reply #9 on: January 23, 2007, 06:53:23 AM »
Thanks Luis, I didn't want to use COM if possible
LE
Re: What is it ??
« Reply #10 on: January 23, 2007, 11:01:31 AM »
Yes, I read about that bug yesterday... anyway on the mean time maybe we can use or do something like:
For the text objects
[CommandMethod("EXTENTSTEXT")]
public void extentstext()
    Editor ed = doc.Editor;
    Database db = doc.Database;
    PromptEntityResult res = ed.GetEntity("\nSelect a text object: ");
    if (res.Status != PromptStatus.OK) return;
        DBText en = tr.GetObject(res.ObjectId, OpenMode.ForWrite, false) as DBText;
        if (en != null)
            Point3dCollection points = new Point3dCollection();
            en.IntersectWith(en, Intersect.OnBothOperands, points, 0, 0);
            Point3d min = points[0];
            Extents3d ext = en.GeometricExtents;
            Point3d max = ext.MaxPoint;
            ed.WriteMessage("\nMin: " + min.ToString());
            ed.WriteMessage("\nMax: " + max.ToString());
        tr.Commit();
I did some tests and appears to work... HTH
LE
Re: What is it ??
« Reply #11 on: January 23, 2007, 11:08:20 AM »
And also, I noticed that when a circle, polyline with curve segments or arcs... it returns a Z value...
Command:
EXTENTS
Select an object:
Min: (5.45881777898967,3.1380655194173,-1E-08)
Max: (8.53598919405592,4.86608891299586,1E-08)
Command:
EXTENTS
Select an object:
Min: (9.51955997849185,3.76989079268639,0)
Max: (12.0768439959734,6.1427457033589,0)
Command: EXTENTS
Select an object:
Min: (26.5840584617689,-3.19303918509976,-1E-08)
Max: (33.0463436581694,1.62667942692176,1E-08)
Using this, and similar as Kerry original code post.
Point3d min = ext.MinPoint;
« Last Edit: January 23, 2007, 11:09:54 AM by LE »
Re: What is it ??
« Reply #12 on: January 23, 2007, 05:14:51 PM »
..............  Yes, I read about that bug yesterday...
Where did you read that information Luis ?
Re: What is it ??
« Reply #13 on: January 23, 2007, 05:20:33 PM »
Interesting piece of code Luis ..
Any particular reason why you open the selected object ForWrite and Commit the transaction at the end ?
        if (en != null)
        tr.Commit();
LE
Re: What is it ??
« Reply #14 on: January 23, 2007, 05:26:58 PM »
Oops... I was doing some other stuff, previous to this code and forgot to remove it.... thanks.
