Author Topic: Boundary Poly in VBA  (Read 2921 times)
JohnF
« on: January 22, 2007, 02:22:09 AM »
Has anyone created code in VBA to match the Boundary Polyline command?
I have searched and got nothing - just don't want to recreate the wheel.
Tuoni
  • I do stuff, and things!
Re: Boundary Poly in VBA
« Reply #1 on: January 22, 2007, 04:34:24 AM »
There are really, from my experience, only two ways to do this (or something similar)...
one is to create regions from the polylines then use booleans (I mean as in Subtract etc) to make a region of the required shape, or to fall back on the good ol' SendCommand *shudders*
For an example of this, check here: http://discussion.autodesk.com/thread.jspa?messageID=415313
Matersammichman
« Reply #2 on: January 29, 2007, 05:47:30 PM »
This should do the trick and more...I made this to calc areas. Just copy it into your app, make the command button, run it, and click inside the closed () where you want an area.
Private Sub cmdArea_Click()
Me.Hide
Dim Pt As Variant, gotpt As Boolean
gotpt = False
Do
On Error Resume Next
Pt = ThisDrawing.Utility.GetPoint(, "Select an Internal Point")
If Err Then
Err.Clear
gotpt = False
Else
gotpt = True
End If
Loop While Not gotpt
On Error GoTo 0
ThisDrawing.SendCommand Chr(3) & Chr(3) & "-boundary" & vbCr & Pt(0) & "," & Pt(1) & vbCr & vbCr
ThisDrawing.SendCommand "_area" & vbCr & "object" & vbCr & "last" & vbCr
varArea = "_area" & vbCr & "object" & vbCr & "last" & vbCr
ThisDrawing.SendCommand "Erase" & vbCr & "Last" & vbCr & vbCr
Dim SysVarName As String
Dim VarData As Variant
Dim intData As Double
SysVarName = "DIMSCALE"
sysVarName2 = "area"
VarData = ThisDrawing.GetVariable(SysVarName)
varArea = Round(Val(ThisDrawing.GetVariable(sysVarName2)) / 144, 0) & " Sq. Ft."
intData = VarData * 0.09375 'for 3/32 text
Dim textObj As AcadText
Dim text As Variant
Dim Height As Variant
Height = intData
Set textObj = ThisDrawing.ModelSpace.AddText(varArea, Pt, Height)
End Sub
Fatty
« Reply #3 on: January 30, 2007, 04:06:30 AM »
Here is slightly edited version
Tested in A2005 only
Option Explicit
'| request check "Break on Unhandled Errors"
'| in Tools -> References -> Options -> General tab
'| -> Error Trapping field
     Me.Hide
     Dim Pt As Variant, _
         varArea As String, _
         pstr As String, _
         SysVarName As String, _
         sysVarName2 As String, _
         VarData As Variant, _
         intData As Double, _
         textObj As AcadText, _
         text As Variant, _
         Height As Variant, _
         Msg As String
     sysVarName2 = "AREA"
     With ThisDrawing
          .SetVariable "OSMODE", 0
          .SetVariable "CMDECHO", 0
          '' Multiple getpoint method by Tony Tanzillo
          Msg = vbCrLf & "Select an Internal Point"
          Do
               Pt = .Utility.GetPoint(, Msg)
               If Err Then
                    Err.Clear
                    Exit Do
               End If
               On Error GoTo 0
               pstr = Replace(CStr(Pt(0)), ",", ".") & "," & _
                      Replace(CStr(Pt(1)), ",", ".")
               .SendCommand Chr(3) & Chr(3) & "._-boundary" & vbCr & pstr & vbCr & vbCr
               .SendCommand "._area" & vbCr & "_Object" & vbCr & "_Last" & vbCr
               .SendCommand "._erase" & vbCr & "_Last" & vbCr & vbCr
               VarData = .GetVariable(SysVarName)
               varArea = Round(Val(.GetVariable(sysVarName2)) / 144, 2) & " Sq. Ft."
               Height = intData
               Set textObj = .ModelSpace.AddText(varArea, Pt, Height)
               textObj.Update
               Msg = vbCrLf & "Next Internal Point or ENTER to exit: "
          Loop
          On Error GoTo 0
          .SetVariable "OSMODE", 703
          .SetVariable "CMDECHO", 1
     End With
     MsgBox "Done"
     Unload Me
End Sub
~'J'~
Matersammichman
« Reply #4 on: January 30, 2007, 10:17:10 AM »
Thanks Fatty, that's even better!
Fatty
« Reply #5 on: January 30, 2007, 06:02:48 PM »
C'mon
I am just used your code
Not a big deal though ;-)
Regards,
~'J'~
