Author Topic: Need help trimming objects  (Read 4788 times)
Bryco
Re: Need help trimming objects
« Reply #15 on: January 29, 2007, 10:01:39 AM »
Tuoni, good post, it looks better to find my own intersection points. The straight ones are easy, I'll mess with the others when I get time, I'm thinking translate the arc and the line back to zero then use the line and circle formula. If it works it will be handy as I can also return the segment number at the same time.
Tony's sort by distance is a good idea. I thought of doing that but using the distance of the point from the start doesn't always work but now I realise he is sorting bt distance along the polyline which sounds like it will always work.
Good there's still hope for the lazy way.
Tuoni
  • I do stuff, and things!
« Reply #16 on: January 29, 2007, 10:04:40 AM »
You're quite welcome :)
