Author Topic: where be the list of last dwg edited??  (Read 1328 times)
Derwin
« on: January 17, 2007, 08:21:41 PM »
ok. so ive got this function C:OAG, OpenAsGroup, (you guys helped out with it previously) and itll open up a number of individual PART drawings within a JOB. great, works fine, but now i have to mouse it over to "Window" and select the file i want. If i then issue C:QX (which i do, it sets layers, scales, justifies, saves, closes) im back at the dwg that C:OAG was called from, and once again im mousing it towards "Window", to do it all over again.
Now i want access to the mechanism that sets the "last drawing edited" list that is invoked when you open or close a dwg, so i could in theory C:OAG my 30 files, knowing that if i C:QX the 1st dwg, ill end up looking at the 2nd.
if anyone was to suggest scripts, its not the solution im after. thanks ahead..
