Author Topic: Do you want autocad speak ?  (Read 82145 times)
Harrie
Re: Do you want autocad speak ?
« Reply #105 on: March 26, 2011, 08:49:49 PM »
Nice Jokes,
But is it possible to change the voice of Mary in something different,
without using  Microsoft Speech SDK 5.1.
(setq Sapi (vlax-create-object "Sapi.SpVoice"))
(setq Voice (vlax-get-property Sapi 'voice))
(vlax-dump-object Voice T)
With Microsoft Speech I only hear the voices of Mary, Mike and Sam.
Regards.
« Last Edit: March 26, 2011, 08:55:31 PM by Harrie »
alanjt
  • Standby for witty remark...
« Reply #106 on: March 28, 2011, 09:51:27 AM »
Totally off topic, but are those your feet/shoes, Matt? I've seen those shoes but don't know anyone with them. Do you like them?
Yes, those are my feet/shoes.  I have two pairs and I love 'em.  Those are the Vibram KSOs.  I do about 25% of my running in them - roads, dreadmill, or in this case muddy trails.  :love:
I'm easing back into them after this past winter when I didn't use them at all - I've got start building up the calluses on my feet again.
Very cool. Is there a difference in those and what they call Camp Shoes?
I've been wanting to get a pair, but the price is a hard pill to swallow. I been working for years at hardening my feet (don't wear shoes unless I have to), but I'm still not brave enough to cruise deep in the woods barefoot.
It'd be a site seeing me come out of the woods during hunting season wearing those.  :lol:
I'll eventually get a pair...
Dropbox
Matt__W
  • I like my water diluted.
« Reply #107 on: March 28, 2011, 09:54:53 AM »
What are "camp shoes"?
Autodesk Expert Elite
alanjt
« Reply #108 on: March 28, 2011, 09:56:07 AM »
http://www.amazon.com/Original-MuckBoots-Unisex-Edgewater-Womens/dp/B000WG7NV6/ref=sr_1_1?ie=UTF8&qid=1301320551&sr=8-1
Dropbox
Matt__W
« Reply #109 on: March 28, 2011, 10:04:01 AM »
Yeah... Vibrams are a LOT different from camp shoes.   :-D
alanjt
« Reply #110 on: March 28, 2011, 10:05:25 AM »
Minus the toes? I've never seen either in person, so I really was curious.
Dropbox
jah011
« Reply #111 on: March 18, 2015, 10:41:17 AM »
Hi guys... I like this thread so much.
I am trying to make it work but my skills are still quite poor.
I would like to make acad say Kaboom when I explode ...
i did this simple code but it is not really synchronized :)
(defun  C:exx () (command "explode")
(setq sapi (vlax-create-object "Sapi.SpVoice"))
(vlax-invoke sapi "Speak" "Kaboom" 0)
(vlax-release-object sapi))
I would like to see principle , to have simple function that after it is done says something or even better play a sound. Also I would need to have volume up.
Jan
Andrea
« Reply #112 on: March 18, 2015, 03:09:47 PM »
Hi jah011 and welcome to theswamp.
try this:
(defun  C:exx ()
(command "._explode")
(while (/= 0 (getvar 'cmdactive))
 (vlax-put-property sapi 'volume 2);;;volume
  (vlax-put-property sapi 'rate 2);;;speed
« Last Edit: March 18, 2015, 03:17:24 PM by Andrea »
Keep smile...
jah011
« Reply #113 on: March 18, 2015, 05:28:21 PM »
Hi Andrea!
Thanks for the help!
I changed a routine according to some other comments and it goes like this now
(defun  C:kab () (command "explode")
(while (> (getvar 'cmdactive) 0) (command pause))
 (vlax-put-property sapi 'volume 100);;;volume
  (vlax-put-property sapi 'rate -3);;;speed
Another thing, maybe i am stretching out too far but i was trying to implement your code for playing wav... but no success
(setq objVoice (vlax-create-object "Sapi.SpVoice")
      objFile  (vlax-create-object "SAPI.SpFileStream.1")
(vlax-invoke objFile "Open" "c:\\Windows\\Media\\Ding.wav")
(vlax-invoke objVoice "Speakstream" objFile 0)
(vlax-release-object objVoice)
(vlax-release-object objFile)
BlackBox
« Reply #114 on: March 18, 2015, 06:07:39 PM »
These old posts may be of use.  :-)
Cheers
NICK_VNV
« Reply #115 on: March 19, 2015, 08:26:03 AM »
Try this method for wav, mp3, etc...
(Setq wmp (vlax-get-or-Create-Object "MediaPlayer.MediaPlayer.1"))
(vlax-invoke-method wmp 'Open "c:\\Windows\\Media\\Ding.wav")
(vlax-invoke-method wmp 'Stop)
(vlax-release-object wmp)
Sorry for my English...
NOT SURE
« Reply #116 on: March 19, 2015, 09:55:37 AM »
How would this be done in a SCR type file outside of AutoCad?
« Reply #117 on: March 19, 2015, 10:58:12 AM »
Maybe THIS ?
NOT SURE
« Reply #118 on: March 19, 2015, 12:55:12 PM »
Maybe THIS ?
Couldn't the SAPISpVoice be called through a SCR or a BAT file? I've tried the VBS route but I can't run it since I don't have Visual Studio.
« Reply #119 on: March 19, 2015, 01:03:38 PM »
You should be able to copy the code into notepad and save the file with a VBS extension. Then just double click on it.
