Author Topic: Do you want autocad speak ?  (Read 82068 times)
TimSpangler
  • CAD Naked!!
Re: Do you want autocad speak ?
« Reply #90 on: October 02, 2008, 12:08:57 PM »
May want to look to see what voices are available first:
;; Check for available voices in registry
(vl-registry-descendents  "HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Speech\\Voices\\Tokens\\")
<This is why I couldn't change the voice - I only had one voice installed /slaps forehead)
ACA 2015 - Windows 7 Pro
Andrea
« Reply #91 on: October 02, 2008, 02:16:09 PM »
or this...
(setq objVoice (vlax-create-object "Sapi.SpVoice"))
(setq voice (vlax-get objVoice "Voice"))
(vlax-invoke voice 'GetDescription)
(vlax-release-object objVoice)
(vlax-release-object voice)
Keep smile...
TimSpangler
  • CAD Naked!!
« Reply #92 on: October 02, 2008, 05:13:15 PM »
That will give the current voice but not the available voices.....
or this...
Andrea
« Reply #93 on: October 02, 2008, 06:58:48 PM »
or this...
Yes you'r right.....it was only an example..
we need to use
(vlax-for ... maybe ?
Keep smile...
Notsober
« Reply #94 on: October 17, 2008, 10:15:42 AM »
wow. I so want to try this... but have NO IDEA where to start.
could someone please point me in the right direction?
KewlToyZ
« Reply #95 on: October 17, 2008, 01:15:36 PM »
Download this lsp file.
Place a copy of it in your AutoCAD support folder.
(example for AutoCAD MEP 2008)
C:\Documents and Settings\YourUserName\Application Data\Autodesk\ACD-MEP 2008\enu\Support
Open Your AutoCAD, type appload into the command line.
In the dialog box, browse to the folder you copied it to and select sayit.lsp
Click the load button, close the dialog box.
type:
sayit
type what you want AutoCAD to say.
This is an example of AutoCAD using text to speech.
If you wanted to load it with each session of AutoCAD you start you would likely want to either place this code into your acad.mnl file or your acad.lsp, or your acaddoc.lsp file.
(autoload "sayit" '("sayit"))
Notsober
« Reply #96 on: October 17, 2008, 03:11:11 PM »
type:
sayit
cool cool. well see, I didn't know it was a lisp routine. I thought it was some sort of VBA code (which is where my weakness is - I guess I still can't recognize the difference between lisp routines and other code languages).
YAY I know what to do with lisps... lol. And why would I have to add the code into my acad.mnl or acad.lsp or acaddoc.lsp? isn't it easier to just add the sayit.lsp to the StartUp Suite?
KewlToyZ
« Reply #97 on: October 20, 2008, 09:21:22 AM »
Depends on what sort of deployment you have in place.
I have a bunch of customizations on a network drive and a profile loading it up afor all of my users.
For the most part using start up suite is not good practice in an enterprise environment.  :kewl:
HofCAD
« Reply #98 on: October 21, 2008, 01:07:36 PM »
(defun C:VoiceList(/ i VoiceLst)
(setq  Sapi (vlax-create-object "Sapi.SpVoice"))
(setq Voices (vlax-invoke Sapi 'GetVoices))
(setq i 0 VoiceLst '())
(repeat (vla-get-count Voices)
(setq VoiceLst (append VoiceLst
(list (vlax-invoke (vla-item Voices i) 'GetDescription))))
(setq i (1+ i))
;(vlax-release-object Sapi)
VoiceLst
VoiceList or (C:VoiceList) gives to me:
("Microsoft Mary" "Microsoft Mike" "Microsoft Sam" "Sample TTS Voice")
For sound Animations or Simulations of
five Maltese cross or Geneva mechanism (HofMalt.zip),
three Parallel mechanism(HofPar.zip),
Pulley, Valve, Bench Vice and a Hammer(HofAni1.zip) and for
exploded views of an U-bolt pipe strap and Shaft clamp(HofAni2.zip)
see:
http://forums.augi.com/showthread.php?t=55713&page=4&highlight=animation
Regards,
HofCAD CSI
PS I made some modifications and additions in SpeakCfg.lsp.
For example, adding Wav sound, voice identification and warnings.
The program SpeakCfg is Using the Speech Application Programming Interface
from Microsoft Speech SDK 5.1 (http://www.microsoft.com/downloads/") or the
speech module from Microsoft Office (Microsoft Word 2002, or Microsoft Excel 2002).
« Last Edit: October 15, 2009, 01:24:41 PM by HofCAD »
deegeecees
« Reply #99 on: March 24, 2011, 10:44:38 AM »
*bump*
April Fools Day is right around the corner.
Matt__W
  • I like my water diluted.
« Reply #100 on: March 24, 2011, 01:15:46 PM »
*bump*
That's my birthday!  :)
Autodesk Expert Elite
Nibster
« Reply #101 on: March 24, 2011, 02:14:24 PM »
*bump*
your mom failed to keep legs crossed till after midnight, huh?
 :lmao:
mine succeeded.  8-)
Matt__W
« Reply #102 on: March 24, 2011, 02:18:20 PM »
*bump*
 :lmao:
mine succeeded.  8-)
That's the ONLY time your mom kept her legs crossed.  *ZING!!*
alanjt
  • Standby for witty remark...
« Reply #103 on: March 24, 2011, 04:34:39 PM »
Totally off topic, but are those your feet/shoes, Matt? I've seen those shoes but don't know anyone with them. Do you like them?
Dropbox
Matt__W
« Reply #104 on: March 25, 2011, 08:09:20 AM »
Yes, those are my feet/shoes.  I have two pairs and I love 'em.  Those are the Vibram KSOs.  I do about 25% of my running in them - roads, dreadmill, or in this case muddy trails.  :love:
I'm easing back into them after this past winter when I didn't use them at all - I've got start building up the calluses on my feet again.
