Author Topic: Do you want autocad speak ?  (Read 82099 times)
Greg B
  • Tell me a Joke!
Re: Do you want autocad speak ?
« Reply #30 on: January 18, 2007, 05:06:59 PM »
Lin-Z
don't put a space between command and the comma.
"Your command, line..."
Lin-Z
« Reply #31 on: January 18, 2007, 05:51:06 PM »
Ohhhhhhhh, I guess I should pay closer attention when I copy/paste code.  All fixed.   :ugly:
Greg B
  • Tell me a Joke!
« Reply #32 on: January 18, 2007, 05:55:49 PM »
You are mightily welcome!
daron
« Reply #33 on: January 18, 2007, 06:51:16 PM »
Thanks Greg. I wouldn't have seen that. Very interesting stuff.
« Reply #34 on: January 18, 2007, 09:12:34 PM »
OK....so how would one query if the user has the speakers mute set, turn the volume to high, and then return it back to the previous settings?
Big G
« Reply #35 on: January 18, 2007, 10:29:42 PM »
hahaha love this!!!
can it be made to speak every command as its being typed on the keyboard?
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
Big G
« Reply #36 on: January 18, 2007, 11:02:08 PM »
Guess Who??
(DEFUN c:who ()
  (setq who (vlax-create-object "sapi.SpVoice"))
  (vlax-invoke who "Speak" "For Centuries, mankind has been trying to unravel the mysteries of the universe" 0)
  (vlax-release-object who)
can you tell its nearly quitting time on a friday?
terrycadd
Do you want autocad to speak?
« Reply #37 on: January 18, 2007, 11:58:42 PM »
Here is a function version that makes it easier to use in programming.  For my *error* function, I included:
(SayIt "Houston, we have a problem!").  Have you tried numbers yet?  It's awesome!  You have to type in "inches" and "feet" etc.  I haven't tested it while a dialog is active, but I will tomorrow.
(defun SayIt (Phrase$ / Sapi)
  (setq Sapi (vlax-create-object "Sapi.SpVoice"))
  (vlax-invoke Sapi "Speak" Phrase$ 0)
  (vlax-release-object Sapi)
);defun SayIt
Krushert
  • FREE BEER Tomorrow!!
« Reply #38 on: January 19, 2007, 08:09:38 AM »
Or how about turning the monitor off.
"This file will self destruct in 5 seconds."
Then the monitor goes black
CADaver
Re: Do you want autocad to speak?
« Reply #39 on: January 19, 2007, 08:17:24 AM »
Try this:
3102880657' 6 7/8"
with a space between the foot mark and the six and another between the six and the three.
Patrick_35
« Reply #40 on: January 19, 2007, 08:56:57 AM »
Yes, or you can do that
(setq sh (vlax-create-object "shell.application")
(vlax-invoke sh 'ShutdownWindows)
HofCAD
« Reply #41 on: January 22, 2007, 02:55:52 AM »
Dear Patrick_35 and Readers,
Question,  can I also change the voice?
Regards,
HofCAD CSI.
(defun C:speakcfg(/ @volume @rate)
(setq sapi (vlax-create-object "Sapi.SpVoice"))
(setq @volume (vlax-get-property sapi 'volume))
(vlax-put-property sapi 'volume 10)
(vlax-invoke sapi "Speak" "Do you want autocad speak with a soft volume" 0)
(vlax-put-property sapi 'volume 50)
(vlax-invoke sapi "Speak" "Do you want autocad to speak with a medium volume?" 0)
(vlax-put-property sapi 'volume 100)
(vlax-invoke sapi "Speak" "Do you want autocad to speak with a loud volume?" 0)
(vlax-put-property sapi 'volume @volume)
(setq @rate (vlax-get-property sapi 'rate))
(vlax-put-property sapi 'rate -8)
(vlax-invoke sapi "Speak" "Do you want autocad to speak with a slow rate?" 0)
(vlax-put-property sapi 'rate 5)
(vlax-invoke sapi "Speak" "Do you want autocad to speak with a fast rate?" 0)
(vlax-put-property sapi 'rate 0)
(vlax-invoke sapi "Speak" "Do you want autocad to speak with a normal rate?" 0)
(vlax-put-property sapi 'rate @rate)
(vlax-invoke sapi "Speak" "Question,         can I also change the voice?" 0)
(print (vlax-get-property (vlax-get-property Sapi 'Voice) 'Id))
(vlax-release-object sapi)
http://www.microsoft.com/technet/scriptcenter/funzone/games/sapi.mspx
« Last Edit: January 22, 2007, 07:14:02 AM by HofCAD »
Patrick_35
« Reply #42 on: January 22, 2007, 05:40:49 AM »
Yes, it's possible
An example to change the voice into French and on a female tone.
Sorry but it's in french   ^-^
http://www.zebulon.fr/astuces/tip200/Synthese-vocale-Windows-en-francais.html
And this
http://www.developpez.net/forums/archive/index.php/t-62567.html
But you can go to http://www.microsoft.com/reader/downloads/pc.asp
KewlToyZ
« Reply #43 on: January 30, 2007, 06:59:10 PM »
oh man I am having fun with this, thanks for the toys!
HofCAD
« Reply #44 on: January 31, 2007, 03:48:01 AM »
Yes, it's possible
I can change the voice, but is this the right way.
Another question  (vlax-invoke sapi "Speak" "Do you want autocad speak with a soft volume" 0)
ends with a zero.
I hear no change when I change it.
Regards,
HofCAD CSI.
(defun C:SpeakCfg(/ Sapi ~voice ~volume ~rate Voice VoiceMary VoiceMike
                    VoiceSam VoiceLst NumVoices @PlayWav @NoPath
                    @VoiceList @member+ @Voice&TextInput)
;**********************SubPrograms************************************************
(defun @PlayWav (Sapi WavFile / WavPath @@FindFile ObjFile)
(defun @@FindFile(WavFile / WinDir Path i DirLst)
(setq WinDir (getenv "Windir"))
(setq Path nil i 0 DirLst
(list "" "c:\\" (strcat WinDir "\\")
(strcat WinDir "\\media\\")
(strcat WinDir "\\System\\")
(strcat WinDir "\\System32\\")
(strcat WinDir "\\System64\\")
(strcat WinDir "\\System32\\drivers\\")))
(while (and (< i (length DirLst))
(= (setq Path (findfile (strcat (nth i DirLst) WavFile))) nil))
(setq i (1+ i)))
Path
(setq WavPath (@@FindFile WavFile))
(if (and WavPath Sapi)
(setq ObjFile (vlax-create-object "SAPI.SpFileStream.1"))
(vlax-invoke ObjFile "Open" WavPath)
(vlax-invoke Sapi "Speakstream" ObjFile 0)
(vlax-release-object ObjFile)
(defun @NoPath(s / cnt ct name)
(setq name (strcase s T))
(if (= (substr name 2 1) ":")
(setq name (substr name 3)))
(setq cnt 1 ct 0)
(repeat (strlen name)
(if (= (substr name cnt 1) "\\")
(setq ct cnt)
(setq cnt (1+ cnt))
(setq name (substr name (+ 1 ct) cnt))
(defun @VoiceList(Sapi / i VoiceLst Voices)
(setq Voices (vlax-invoke Sapi 'GetVoices))
(setq i 0 VoiceLst '())
(repeat (vla-get-count Voices)
(setq VoiceLst (append VoiceLst
(list (vlax-invoke (vla-item Voices i) 'GetDescription))))
(setq i (1+ i))
VoiceLst
(defun @member+ (x lst /)
(if (vl-member-if '(lambda (y) (wcmatch x y)) lst) x)
(defun @Voice&TextInput(voice text / SpeekContent)
(setq SpeekContent (strcat "<VOICE REQUIRED='NAME=" voice "'>" text "</VOICE>"))
;**********************Main Program***********************************************
(if (not Sapi)(progn
(load "AI_UTILS")(princ "\nWarning: For sound, first install Microsoft Speech SDK 5.1")
(ai_abort "Sapi.SpVoice" (strcat "Warning: No Speech Application Programming Interface"
" with Microsoft Speech" "\n or with the speech module in MS Office."
"\n Suggestion: Install Microsoft Speech SDK 5.1 from http://www.microsoft.com/downloads/"))
(setq ~voice (@NoPath (vlax-get-property (vlax-get-property Sapi 'voice) 'Id)))
((= ~voice "msmary") (setq Voice "Microsoft Mary"))
((= ~voice "msmike") (setq Voice "Microsoft Mike"))
((= ~voice "mssam") (setq Voice "Microsoft Sam"))
(t (setq Voice ~voice))
;The voice is normally in Microsoft Speech "Microsoft Mary",
;but in the speech module in MS Office it is "Microsoft Sam".
(setq ~volume (vlax-get-property Sapi 'Volume))
(vlax-put-property Sapi 'Volume 100)
(@playwav Sapi "notify.wav")
(vlax-invoke Sapi "Speak" (strcat "This is " Voice " speaking in AutoCAD with Sapi.     "
"Sapi is short for Speech Application Programming Interface.     "
"You can also use Sapi for playing Wave soundfiles in AutoCAD.") 0)
(@playwav Sapi "Ringin.wav")
(vlax-put-property Sapi 'Volume 10)
(vlax-invoke Sapi "Speak" "Do you want AutoCAD to speak with a soft volume?" 0)
(vlax-put-property Sapi 'Volume 50)
(vlax-invoke Sapi "Speak" "Do you want AutoCAD to speak with a medium volume?" 0)
(vlax-invoke Sapi "Speak" "Do you want AutoCAD to speak with a loud volume?" 0)
;(vlax-put-property Sapi 'Volume ~volume)
(setq ~rate (vlax-get-property Sapi 'Rate))
(vlax-put-property Sapi 'Rate -8)
(vlax-invoke Sapi "Speak" "Do you want AutoCAD to speak with a slow rate?" 0)
(vlax-put-property Sapi 'Rate 5)
(vlax-invoke Sapi "Speak" "Do you want AutoCAD to speak with a fast rate?" 0)
(vlax-put-property Sapi 'Rate 0)
(vlax-invoke Sapi "Speak" "Do you want AutoCAD to speak with a normal rate?" 0)
;(vlax-put-property Sapi 'Rate ~rate)
(vlax-invoke Sapi "Speak" "Question,         Can I also change the voice?" 0)
(setq VoiceLst (@VoiceList Sapi))
;Gives normally with Microsoft Speech:("Microsoft Mary" "Microsoft Mike" "Microsoft Sam" "Sample TTS Voice")
;The voice "Sample TTS Voice" is not usable in a Sapi object, it is for use in TTSapp.exe and TTSappVB.exe
;Gives normally with Microsoft Office speech module:("Microsoft Sam")
(setq NumVoices(length VoiceLst))
(if (@member+ "Sample TTS Voice" VoiceLst) (setq NumVoices (1- NumVoices)))
(if (> NumVoices 1)
(vlax-invoke Sapi "Speak" (strcat "Yes. We can do this, because there are "
(itoa NumVoices) " usable voices on this system.") 0)
(vlax-invoke Sapi "Speak" (strcat "No. We can't do this, because there is only one voice on this system.  "
"  Probably, only the speech module of Microsoft Office is installed.") 0)
(princ (strcat "\nWarning: For more voices, first install Microsoft Speech SDK 5.1"
"\nfrom http://www.microsoft.com/downloads/"))))
(if (@member+ "Microsoft Mary" VoiceLst) (setq VoiceMary "Microsoft Mary"))
(if (@member+ "Microsoft Mike" VoiceLst) (setq VoiceMike "Microsoft Mike"))
(if (@member+ "Microsoft Sam" VoiceLst) (setq VoiceSam "Microsoft Sam"))
(if (and VoiceMary VoiceMike VoiceSam)
(vlax-invoke Sapi "Speak" (@Voice&TextInput VoiceMike
"My name is Microsoft Mike, and I have a question for Sam.") 0)
"Sam, could you say something about Mary?") 0)
(vlax-invoke Sapi "Speak" (@Voice&TextInput VoiceSam
"My name is Microsoft Sam, and I can say that Mary has a little lamb.") 0)
(vlax-invoke Sapi "Speak" (@Voice&TextInput VoiceMary
"Hi, this is Microsoft Mary and I think that Sam is joking like Mister Thomas Edison.") 0)
"This information is very interesting, and I would like to thank you all.") 0)
(vlax-invoke Sapi "Speak" "Warning      " 0)
(if (not VoiceMary) (vlax-invoke Sapi "Speak" "There is no Microsoft Mary." 0))
(if (not VoiceMike) (vlax-invoke Sapi "Speak" "There is no Microsoft Mike." 0))
(if (not VoiceSam) (vlax-invoke Sapi "Speak" "There is no Microsoft Sam." 0))
(@playwav Sapi "tada.wav")
« Last Edit: October 15, 2009, 01:23:22 PM by HofCAD »
