Author Topic: Do you want autocad speak ?  (Read 81841 times)
Re: Do you want autocad speak ?
« Reply #75 on: April 02, 2008, 01:51:10 PM »
OK we can get autocad to speak but what about play tones.  I read in the a lisp programming book (not sure which one) that you can get autocad to beep. (or play sounds).
Anyone here know how this is possible.  (I cold get the example to work if I remember)  I also have beep on error turned off maybe that has something to do with it.
you can get it to play any sound file located on your computer.
KewlToyZ
« Reply #76 on: April 03, 2008, 11:14:53 AM »
LOL I could just hear it now....
User Clicks on Close....
song starts "I hate everything about you....." :lmao:
error while in CAD, a Jim Carey sound byte "Yes! Yes! Can ya feel that buddy? Huh? Huh?"
TimSpangler
  • CAD Naked!!
« Reply #77 on: April 03, 2008, 11:23:00 AM »
I have a question about the MSAgents  Can the be accessed through lisp?  Can I show the characters with lisp?
ACA 2015 - Windows 7 Pro
« Reply #78 on: April 03, 2008, 08:29:12 PM »
I havn't looked at MsAgents
TimSpangler
  • CAD Naked!!
« Reply #79 on: April 03, 2008, 08:38:57 PM »
I have been playing around with a couple of things from this thread.  I can't seem to get the voice to change.  Is it possible?.  I also played with the MSagents to no avail. (I don't know enough about accessing dll to get anything to work).  Maybe some one can shed some light on this subject, or start a new thread with a little tut. to get me going.
« Reply #80 on: April 03, 2008, 09:53:26 PM »
You can try this tim, but it never worked for me.
(write-char 7)
DEVITG
« Reply #81 on: May 11, 2008, 11:36:29 AM »
Well this thread certainly got the creative juices flowing...
Let's have some fun with the MS Agent as well!
Hi How I can runt the MS agent.
I appload it , but I have no way to call or use it.
Thanks in advance
CECE_CAD
« Reply #82 on: May 15, 2008, 05:06:17 PM »
Ok, so Just wondering... How do you call a command (still having the command work) and have this be called at the same time or after, even before if possible.. Would you use an IF statement?
I was using the copy command.. but its to obvious because it stops the copy command.
(DEFUN c:C ()
  (setq sapi (vlax-create-object "Sapi.SpVoice"))
  (vlax-invoke sapi "Speak" "Johnny!." 0)
  (vlax-invoke sapi "Speak" "What are you doing?." 0)
  (vlax-release-object sapi)
« Reply #83 on: May 15, 2008, 05:54:25 PM »
Create a reactor and have it look for the start of a command.
You could modify this one.
http://www.theswamp.org/index.php?topic=22733.msg273953#msg273953
CECE_CAD
« Reply #84 on: May 15, 2008, 06:01:01 PM »
 :-o Woo!! I will try to modify.. :laugh: Thanks...
TimSpangler
  • CAD Naked!!
« Reply #85 on: August 28, 2008, 12:41:13 PM »
*BUMP*
 :-P
jnieman
« Reply #86 on: August 28, 2008, 03:24:33 PM »
haha good timing.
HofCAD
« Reply #87 on: September 04, 2008, 07:06:46 AM »
For Five Sound Animations or Simulations of the Maltese cross or Geneva mechanism(HofMalt.zip),
and three Parallel mechanism(HofPar.zip) see:
http://forums.augi.com/showthread.php?t=55713&page=4
Regards,
HofCAD CSI
BrunoToniutti
« Reply #88 on: October 02, 2008, 05:29:32 AM »
 :-D funny !
thx Patrick and other people,
I changed the voice with "LH Veronique", it's fine
(vlax-invoke sapi "Speak" "<VOICE REQUIRED=\"NAME=LH Veronique\">Patrick, merci et bonne journée" 0)
 :-) Bruno
Andrea
« Reply #89 on: October 02, 2008, 10:18:08 AM »
Want to Use SAPI to play wav file ?
(setq objVoice (vlax-create-object "Sapi.SpVoice")
      objFile  (vlax-create-object "SAPI.SpFileStream.1")
(vlax-invoke objFile "Open" "c:\\Windows\\Media\\Ding.wav")
(vlax-invoke objVoice "Speakstream" objFile 0)
(vlax-release-object objVoice)
(vlax-release-object objFile)
Keep smile...
