Author Topic: Do you want autocad speak ?  (Read 82110 times)
terrycadd
Re: Do you want autocad speak ?
« Reply #60 on: February 09, 2007, 12:59:54 PM »
Here's a link that you might try to test for other free voices, to see if they will run on your system.
http://www.bytecool.com/voices.htm
M-dub
« Reply #61 on: April 01, 2008, 03:22:36 PM »
*bump*
Should have bumped it a few days ago, in preparation for April Fool's.
Bob Wahr
« Reply #62 on: April 01, 2008, 03:28:19 PM »
This takes me back.  I was doing some HD cleanup the outh day and deleted a bunch of the CV agent chat stuff.
David Hall
  • Automatic Duh Generator
« Reply #63 on: April 01, 2008, 04:25:38 PM »
Mine wont work,
; error: no function definition: VLAX-CREATE-OBJECT
« Reply #64 on: April 01, 2008, 05:13:06 PM »
Mine wont work,
Do you have (vl-load-com) issued from anywhere?  You have to have this loaded once per session to use the ActiveX calls within lisp.
David Hall
« Reply #65 on: April 01, 2008, 05:17:47 PM »
I knew it was something simple
« Reply #66 on: April 01, 2008, 05:21:55 PM »
Glad it was simple.  By the way, you can call (vl-load-com) as many times as you want with no performance loss, but it only needs to be called once.
daron
« Reply #67 on: April 02, 2008, 10:23:58 AM »
Are you sure?
(while t (vl-load-com)) :lmao: :lmao:
« Reply #68 on: April 02, 2008, 11:11:51 AM »
Are you sure?
I stand corrected.  Good one Daron.
TimSpangler
  • CAD Naked!!
« Reply #69 on: April 02, 2008, 12:43:06 PM »
How in the heck did I miss this thread???
Great one!
ACA 2015 - Windows 7 Pro
David Hall
« Reply #70 on: April 02, 2008, 12:55:48 PM »
seems to lock up my computer, ideas?
« Reply #71 on: April 02, 2008, 12:59:29 PM »
Because it is always true, so it will keep issuing (vl-load-com).  Just do it once, no while loop, at the beginning of the code.
daron
« Reply #72 on: April 02, 2008, 01:38:36 PM »
It was a joke David. I was just toying with Tim's comment about being able to use (vl-load-com) as much as you want without performance loss. With that while loop, it will never finish executing the vl-load-com. You have performance loss from the get go, because it will eternally load or lock up as you experienced, never getting to the rest of the procedures.
TimSpangler
  • CAD Naked!!
« Reply #73 on: April 02, 2008, 01:47:08 PM »
OK we can get autocad to speak but what about play tones.  I read in the a lisp programming book (not sure which one) that you can get autocad to beep. (or play sounds).
Anyone here know how this is possible.  (I cold get the example to work if I remember)  I also have beep on error turned off maybe that has something to do with it.
David Hall
« Reply #74 on: April 02, 2008, 01:50:31 PM »
I guess I should have read it a little closer.  For that matter, I should use LISP more
