Author Topic: (Challenge) Summation  (Read 14439 times)
gile
  • Marseille, France
Re: (Challenge) Summation
« Reply #30 on: January 17, 2007, 04:29:47 PM »
Ditto^
What does it mean ???
My English is poor.
LE
« Reply #31 on: January 17, 2007, 04:32:40 PM »
Ditto^
My English is poor.
I think it is "idem" in French
(means that I think the same as your comment) :)
gile
  • Marseille, France
« Reply #32 on: January 17, 2007, 04:34:33 PM »
OK ,Thanks  :-)
LE
« Reply #33 on: January 18, 2007, 12:53:49 AM »
Note:
I'll start a new topic in the ARX forum, in case some of the masters in arx, end up adding some more solutions...
Just for fun, here is a function in C++/ARX
Here is:
http://www.theswamp.org/index.php?topic=14600.msg176186#msg176186
« Last Edit: January 18, 2007, 10:02:08 PM by LE »
fools
  • China
« Reply #34 on: March 02, 2007, 03:25:06 AM »
I always use sort+combination like this below codes
(DEFUN Sort&Comb (lst func / tmplst)
  (SETQ tmplst nil)
  (FOREACH item (VL-SORT lst
(FUNCTION (LAMBDA (p1 p2) (< (CAR p1) (CAR p2))))
    (IF (AND tmplst (EQUAL (CAAR tmplst) (CAR item)))
      (SETQ tmplst (SUBST (LIST (CAR item)
(APPLY func (LIST (CADR item) (CADAR tmplst)))
  (CAR tmplst)
  tmplst
      (SETQ tmplst (CONS item tmplst))
  tmplst
(setq aaa '(("one" 1) ("two" 2) ("three" 3)
              ("one" 4) ("two" 5) ("three" 6)
              ("one" 7) ("two" 8) ("three" 9)
(Sort&Comb aaa '+)
;;return (("two" 15) ("three" 18) ("one" 12))
(Sort&Comb aaa '*)
;;return (("two" 80) ("three" 162) ("one" 28))
(Sort&Comb aaa (FUNCTION (LAMBDA (P1 P2) (IF (ATOM P2) (LIST P1 P2) (CONS P1 P2)))))
;;return (("two" (8 5 2)) ("three" (9 6 3)) ("one" (7 4 1)))
« Last Edit: March 02, 2007, 03:38:42 AM by fools »
Good good study , day day up . Sorry about my Chinglish .
fools
  • China
« Reply #35 on: March 02, 2007, 03:47:34 AM »
Also can like this
(DEFUN Sort&Comb (lst SortFunc CombFunc / tmplst)
  (SETQ tmplst nil)
  (FOREACH item (VL-SORT lst SortFunc)
(APPLY CombFunc (LIST (CADR item) (CADAR tmplst)))
  (CAR tmplst)
  tmplst
  tmplst
(SORT&COMB AAA (FUNCTION (LAMBDA (p1 p2) (< (CAR p1) (CAR p2)))) '+)
;;ruturn (("two" 15) ("three" 18) ("one" 12))
