Author Topic: (Challenge) Summation  (Read 14309 times)
« on: January 16, 2007, 12:40:46 PM »
Return the sum of values for each class.
-i.e.
 (summation '(("one" 1) ("two" 2) ("three" 3)))
 > one = 1
   two = 2
   three = 3
Further, return the sum of values for each class if there are several instances of each class.
-i.e.
                     ("one" 4) ("two" 5) ("three" 6)
                     ("one" 7) ("two" 8) ("three" 9)) )
 > one = 12
   two = 15
   three = 18
Rules:
You may only ``go thru'' this list once.
You may return a formatted screen print or a list (which ever is easier for you).
And to make this a bit more challenging, you must use a recursive process.
(You may use variables or a ``wrapper''.)
Note:
o  This idea came from a program I just made for reporting/calcing the len and vol of pipe in a selection. (It is a generalized concept of a function I just created.)
o  I used variables in my procedure but I would be very interested in seeing a solution that uses neither. (I could not think of a way to do that.)
Fatty
Re: (Challenge) Summation
« Reply #1 on: January 16, 2007, 03:47:47 PM »
Not tested extensively
but it may works I hope
(defun summation (lst / extrakt)
  (defun extrakt (test lst / ret)
    (setq ret
   (apply 'append
  (mapcar '(lambda (x)
     (if (eq (car x) test)
       (list x)
  lst
    (list test (apply '+ (mapcar 'cadr ret)))
  (if (car lst)
    (cons (extrakt (caar lst) lst)
  (summation
    (vl-remove-if
      (function (lambda (a)
  (eq (car a) (caar lst))
      lst
~'J'~
gile
  • Marseille, France
« Reply #2 on: January 16, 2007, 04:54:45 PM »
hi,
Here's my contribution :
(defun summation (lst / m)
      ((atom lst) nil)
      ((setq m (assoc (caar lst) (cdr lst)))
       (summation
(subst (list (caar lst) (+ (cadr m) (cadar lst)))
m
(cdr lst)
      (T (cons (car lst) (summation (cdr lst))))
« Reply #3 on: January 16, 2007, 09:36:32 PM »
Wonderful gile!! Simple and elegant. (Makes mine look like a child with a
crayon--which I will post tomorrow morn.)
Fatty, Very nice, but you can only iterate thru the list once. I count 5
times.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: January 17, 2007, 12:39:53 AM »
(defun summation_1 (lst)
  (if lst
    (cons
      (list
        (caar lst)
        (apply '+ (mapcar 'cadr (vl-remove-if-not '(lambda (x) (= (caar lst) (car x))) lst)))
      ) ;_  list
      (summation_1 (vl-remove-if '(lambda (x) (= (caar lst) (car x))) lst))
    ) ;_  cons
  ) ;_  if
« Reply #5 on: January 17, 2007, 12:50:26 AM »
I don't know why the challenge is 'one pass only' through the list
... wouldn't that preclude recursion ? ? ?  :|
Fatty
« Reply #6 on: January 17, 2007, 02:41:41 AM »
times.
Hi John, I agree with you
Looks ugly and work sloooooowly :)
~'J'~
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: January 17, 2007, 03:09:23 AM »
(defun summation_2 (lst)
  (if (cdr lst)
    (if (= (caadr lst) (caar lst))
      (summation_2 (cons (list (caar lst) (+ (cadar lst) (cadadr lst))) (cddr lst)))
      (if (assoc (caar lst) (cdr lst))
        (summation_2 (cons (car lst)(append (cddr lst) (list (cadr lst)))))
        (cons (car lst) (summation_2 (cdr lst)))
      ) ;_ if
    ) ;_ if
    lst
  ) ;_ if
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #8 on: January 17, 2007, 03:56:20 AM »
(defun summation_3 (lst)
  (if lst
   (if (= (caar lst) (caadr lst))
    (summation_3 (cons (list (caar lst) (+ (cadar lst) (cadadr lst))) (cddr lst)))
   ) ;_  if
  ) ;_  if
 ) ;_  defun
 (summation_3 (vl-sort lst '(lambda (a b) (< (car a) (car b)))))
« Reply #9 on: January 17, 2007, 09:12:52 AM »
Kerry, Im sorry bout that. I guess your kinda right in that the list itself is ``handed-off'' serveral times...but I was thinking more about the contents of the list.
SomeCallMeDave
« Reply #10 on: January 17, 2007, 09:15:50 AM »
My 2 cents -  if the solution can be found via one-pass through the list, why recurse?
(defun summ3(pClassList)
   (setq sumList (list))
   (last (mapcar '(lambda(x) (if (setq SumListElem (assoc (car x) SumList))
                               (setq SumList (subst (cons (car x) (+ (cdr SumListElem) (cdr x)))
                                                     SumListElem SumList))
                               (setq SumList (append SumList (list x)))
                             );if
                  );lambda
           pClassList
         );mapcar
   );last
);defun summ3
« Reply #11 on: January 17, 2007, 09:19:36 AM »
~'J'~
Hey dont sweat it; wait till you see my monster! Its fricken ug-ly! After seeing some of these others, I dont even want to post the darn thing! *lol*)
Here was my version. (I took mine from that procedure I was doing and modified it to fit into this challenge.) please dont run this on a production dwg. It creates some global vars.
(defun summation ( lst / item temp )
  Example:
  (setq one nil two nil three nil _masterlist nil)
  Just to make sure these vars are nil...
  (summation '(("one" 1) ("two" 2) ("Three" 3)
                         ("one" 3) ("two" 6) ("Three" 8)))
  Sum up all the diff types of sizes.
  (mapcar '(lambda ( x ) (eval (read x))) _masterlist)
  report the sizes summed up
  (defun set! ( item val )
    (set (eval (list 'quote item)) val) )
  (setq item (car (car lst)))
    ((null lst) nil)
    ((eval (read item))
     (setq temp (eval (quote (read item))))
     (set!
       (+ (eval temp) (car (reverse (car lst))))
    ((not (eval (read item)))
     (set!
     (if (not (member item _masterlist))
       (setq _masterlist (cons item _masterlist)))
  (setq _masterlist (reverse _masterlist))
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #12 on: January 17, 2007, 09:31:55 AM »
One more variant, slow, but interesting...
(defun lst->matrix (lst)
 (if lst
  (cons (mapcar (function cadr) lst)
        (lst->matrix (vl-member-if (function (lambda (x) (= (car x) (caar lst)))) (cdr lst)))
  ) ;_  cons
 ) ;_  if
) ;_  defun
(defun summation_4 (lst)
 (mapcar
  (function list)
  (mapcar (function car) lst)
  (apply (function mapcar) (cons (function +) (lst->matrix lst)))
 ) ;_  mapcar
) ;_  defun
Ps. This function works, only for the structured list!
(summation_4'(("one" 1) ("two" 2) ("three" 3)
(summation_4'(("one" 1) ("two" 2) ("three" 3) ("Four" 4)
              ("one" 4) ("two" 5) ("three" 6) ("Four" 7)
              ("one" 7) ("two" 8) ("three" 9)  ("Four" 10)
« Last Edit: January 17, 2007, 09:57:34 AM by ElpanovEvgeniy »
« Reply #13 on: January 17, 2007, 10:04:02 AM »
There is some very good code in this thread ('cept my contribution.)!
Please, continue. forget the rules. Go for it! (Post your best!)
« Reply #14 on: January 17, 2007, 10:45:50 AM »
Mine turned out much like  SomeCallMeDave routine
  (defun sum (lst / total result)
               (setq result
                        ((null result) (list x))
                        ((setq total (assoc (car x) result))
                         (subst (list (car x) (+ (cadr x) (cadr total))) total result)
                        ((cons x result))
            lst
    result
