Author Topic: Adding string to list..  (Read 2323 times)
Andrea
« on: January 15, 2007, 02:59:20 PM »
Hi all,..
Can any one tell me how I can add string to list...
(setq list1  "A11,A11v,A01,A01v,A21,A31,A41")
(setq ss2 (ssget "X" '(( 0 . "INSERT " ))))
    (-4 . "<AND ")
    (0 . "INSERT ")
    (-4 . "<NOT ")
    (2 . list1)   ;;;;;;;      <----- ???
    (-4 . "NOT>")
    (-4 . "AND>")
thanks.
Keep smile...
uncoolperson
Re: Adding string to list..
« Reply #1 on: January 15, 2007, 03:06:20 PM »
use some (cons)
(list
    '(-4 . "<AND ")
    '(0 . "INSERT ")
    '(-4 . "<NOT ")
    (cons 2 . list1)
    '(-4 . "NOT>")
    '(-4 . "AND>")
Andrea
« Reply #2 on: January 15, 2007, 03:11:24 PM »
uncoop...
Thanks..
to many work here....no time to think  :oops:
thanks again.
Keep smile...
Fatty
« Reply #3 on: January 15, 2007, 03:12:08 PM »
I use cons instead of quoted list always
Something like this:
(setq ss2 (ssget "X" (list
              (cons -4  "<AND ")
              (cons 0  "INSERT ")
              (cons -4  "<NOT ")
              (cons 2  list1)
              (cons -4 "NOT>")
              (cons -4  "AND>")
~'J'~
« Reply #4 on: January 15, 2007, 08:35:23 PM »
You can try this:
(setq lst '( "A11"
      "A11v" "A01"
      "A01v" "A21"
      "A31"  "A41"
(setq ss2 (ssget "_X"
                 (cons '(0 . "INSERT")
                       (mapcar '(lambda (x) (cons [color=red]2[/color] (strcat "~" x))) lst)
Oops, Thanks Kerry.
Yes, I was actually testing with TEXT objects and forgot to change that back.
  :oops:
« Last Edit: January 16, 2007, 08:00:03 AM by CAB »
« Reply #5 on: January 16, 2007, 06:30:44 AM »
I think Alan meant (cons 2 .... not (cons 1 ...
                       (mapcar '(lambda (x) (cons 2 (strcat "~" x))) lst)
