Author Topic: Help in creating entity(?) with DXF codes  (Read 7986 times)
« on: May 27, 2004, 10:50:14 AM »
I'm wondering if I can create one of these(see below) using the DXF codes? If so, what is the minimum required codes. I can make these things using activeX but was thinking it might be faster using dxf codes.
thanks
; DXF Group Codes:
;   (-1 . <Entity name: 7efebd78>)
;   (0 . "AECC_POINT")
;   (330 . <Entity name: 7eff0cf8>)
;   (5 . "1C8F")
;   (100 . "AcDbEntity")
;   (67 . 0)
;   (410 . "Model")
;   (8 . "SVY-POINTS")
;   (100 . "AecDbEntity")
;   (102 . "{AEC_SUBOBJECT")
;   (300 . "AeccImpPoint")
;   (100 . "AecImpObj")
;   (3 . "")
;   (100 . "AecImpEnt")
;   (171 . 0)
;   (100 . "AecImpGeo")
;   (10 486925.0 1.30319e+006 0.0)
;   (15 1.0 0.0 0.0)
;   (16 0.0 1.0 0.0)
;   (210 0.0 0.0 1.0)
;   (360 . <Entity name: 0>)
;   (100 . "AeccImpPoint")
;   (90 . 107)
;   (11 486925.0 1.30319e+006 -0.5)
;   (302 . "RBNK122")
;   (301 . "")
;   (300 . "")
;   (280 . 0)
;   (303 . "RBNK122")
;   (304 . "")
;   (305 . "")
;   (285 . 1)
;   (286 . 0)
;   (170 . 3)
;   (141 . 5.0)
;   (306 . "Standard")
;   (140 . 0.25)
;   (282 . 1)
;   (283 . 0)
;   (284 . 1)
;   (171 . 2)
;   (172 . 1)
;   (173 . 3)
;   (287 . 1)
;   (142 . 0.0)
;   (288 . 1)
;   (102 . "AEC_SUBOBJECT}")
;   (102 . "{AEC_NULLOBJECT}")
;   (100 . "AecDbGeo")
;   (100 . "AeccDbPoint")
« Reply #1 on: May 27, 2004, 11:51:26 AM »
Mark,
If memory serves, Reini Urban used to have some templates in his library which may be a good guide.
Personally, I am sticking with ActiveX. The difference in speed < even if a couple of seconds > on a large app seems negligable [ to me ] Most users take longer than that to find a key on the keyboard. :D
regards.kerry
« Reply #2 on: May 27, 2004, 12:10:52 PM »
Mark,
I don't think it's a good idea to create point objects in this fashion. Since points are stored externally I really believe that using the AECC Object Model and ActiveX methods is the ONLY way to work with points.
If you can explain WHY you'd want to do otherwise, I'm all ears......
And I have yet to see where (entmake) is faster than (vlax-invoke addWhatever)
Jeff
LDD3 user/hacker
« Reply #3 on: May 27, 2004, 12:51:44 PM »
Quote from: Jeff Mishler
sounds like another contest to me..........!!
True, creating them through activex is probaly the way to go, how ever I believe you could create them dxf style them update the external datbase. It's not a big deal, just thought I'd try.
thanks fot the feedback guys
« Reply #4 on: May 27, 2004, 01:10:11 PM »
I also have the same test vith VBA and Sharplisp [lisp converted to C++ ARX]  The Sharplisp blew them all away.
(defun c:kwb_speedtest4a (/ intcolor count oldecho stime etime )
  (gc)
  (setq intcolor 0
        count 0
        oldecho (getvar "cmdecho")
  (setvar "cmdecho" 0)
  (command "Zoom" "W" (list 0 0 0) (list 51000 51000 0))
  (setq stime (getvar 'millisecs))
  (repeat 50000
    (command "Line"
             (list 0 count 0)
             (list (setq count (1+ count)) (1- count) 0)
    (command "chprop" (entlast) "" "C" (setq intcolor (1+ intcolor)) "")
    (or (< intcolor 255) (setq intcolor 0))
  ;;;(command "regen")
  (setq etime (getvar 'millisecs))
  (alert (strcat (rtos (- etime stime)) " Milliseconds"))
  (setvar "cmdecho" oldecho)
(defun c:kwb_speedtest4b (/ intcolor count oldecho cecolor stime etime )
  (gc)
  (setq intcolor 0
        count 0
        oldcolor (getvar "cecolor")
  (repeat 50000
    (setvar "cecolor" (itoa (setq intcolor (1+ intcolor))))
    (command "Line"
             (list 0 count 0)
(defun c:kwb_speedtest2 (/ intcolor count stime etime)
  (gc)
  (setq intcolor 0
        count 0
  (repeat 50000
    (entmake (list '(0 . "LINE")
                   (list 10 0 count 0)
                   (list 11 (setq count (1+ count)) (1- count) 0)
                   (cons 62 (setq intcolor (1+ intcolor)))
  (command "regen")
(defun c:kwb_speedtest2a (/ sp ep intcolor count stime)
  (setq intcolor 0
        count    0
  (repeat 50000
    (setq
        sp (list 10 0 count 0)
        ep (list 11 (1+ count) count  0)
    count (1+ count)
                   sp
                   ep
                   (cons 62 intcolor )
    (if (> intcolor 255) (setq intcolor 0))
  (command "regen")
  (alert (rtos (- (getvar 'millisecs) stime)))
(defun c:kwb_speedtest2b (/ sp ep epx idl intcolor count stime)
  (setq intcolor 0
        count    0
        idl      (cons 0  "LINE")
  (repeat 50000
    (setq
        epx (1+ count)
 ;;       ep (list 11 (1+ count) count 0)
        ep (list 11 epx count 0)
    count (1+ count)
    (entmake (list idl
                   sp
                   ep
                   (cons 62 intcolor )
  (command "regen")
(defun c:kwb_speedtest1a
       (/ g_acadapp g_modelspace intcolor count stime etime)
  (gc)
  (setq g_acadapp    (vlax-get-acad-object)
        g_modelspace (vla-get-modelspace (vla-get-activedocument g_acadapp))
        intcolor     0
        count        0
  (vla-zoomwindow g_acadapp
                  (vlax-3d-point (list 0 0 0))
                  (vlax-3d-point (list 51000 51000 0))
  (repeat 50000
    (vla-put-color
      (vla-addline
        g_modelspace
        (vlax-3d-point (list 0 count 0))
        (vlax-3d-point (list (setq count (1+ count)) (1- count) 0))
  (vla-update g_acadapp)
  (vlax-release-object g_modelspace)
  (vlax-release-object g_acadapp)
(defun c:kwb_speedtest1b
  (gc)
        intcolor     1
        count        0
  (repeat 50000
    (vla-put-color (vla-addline g_modelspace
                                (vlax-3d-point (list (1+ count) count 0))
                   intcolor
« Reply #5 on: May 27, 2004, 01:28:07 PM »
These times are from Oct2002
Here are my test time results :
[edit] add test 7 [/edit]
Test 1a
31985
32016
31967
Test 1b
31953
32141
32156
Test 2
7844
7859
7846
Test VBA *may be faster if class used
18297
18484
18391
Test 4a * take a packed lunch
767672
Test 4b * ditto
146391
Test 5 * * Sharplisp
13234
13375
13328
Test 6 * *Sharplisp - Dont Blink
2531
2563
2515
Note - This is not changing colors yet, It will for the next release.
The code however is calling the setcolor method, just not changing, so i dont think the time will change much. This may be faster if class used.
Test 7 * *Sharplisp - Workaround to change color
3266
3297
3250
« Reply #6 on: May 27, 2004, 01:50:15 PM »
This was the VBA
Option Explicit
Private Declare Function timeGetTime Lib "winmm.dll" () As Long
Private lngStart As Long
Public Sub SpeedTestVBA()
    Dim objLine As AcadLine
    Dim objSpace As AcadModelSpace
    Dim dblStart(2) As Double
    Dim dblEnd(2) As Double
    Dim lngCnt As Long
    Dim byColor As Byte
    On Error GoTo Err_Control
    Set objSpace = ThisDrawing.ModelSpace
    lngStart = timeGetTime
    For lngCnt = 0 To 49999
        byColor = byColor + 1
        dblEnd(0) = dblEnd(0) + 1
        objSpace.AddLine(dblStart, dblEnd).Color = byColor
        dblStart(1) = dblStart(1) + 1
        dblEnd(1) = dblStart(1)
    Next lngCnt
    Application.Update
    MsgBox timeGetTime - lngStart & " Milliseconds"
Exit_Here:
    Exit Sub
Err_Control:
    Select Case Err.Number
    Case 6
        byColor = 0
        Err.Clear
        Resume
    Case Else
Debug.Print Err.Number; Err.Description
        Err.Clear
        Resume Exit_Here
    End Select
End Sub
And for the sake of completeness, the Sharplisp stuff
(defun-e c:kwb_speedtest6 (/ intcolor count etime stime)
 (IAcadApplication acApp (AxGetAcadApp))
 ;;;(acApp.ZoomWindow (point 0 0 0) (point 51000 51000 0))
 (setq intcolor 1
       count    0
 (repeat 50000
   (arx_setcolor
    (arx_line (point 0 count 0) (point (1+ count) count 0))
    intcolor
   (if (> intcolor 255)(setq intcolor 1))
 (acApp.Update)
(defun-e c:kwb_speedtest7
  (iacadapplication acapp (axgetacadapp))
  (setq intcolor 1
        count    0
  (repeat 50000
    (arx_setcolor (entlast) intcolor)
      (setq intcolor 1)
  (acapp.update)
« Reply #7 on: May 27, 2004, 01:53:11 PM »
well i did one test each on the following, the times are at the end of the code. (BTW I did edit your code slightly Kerry)
(defun c:kwb_speedtest1i
       (/ g_acadapp g_modelspace new_line count stime etime)
  (gc)
        intcolor     1
        count        0
  (repeat 50000
(setq new_line
  (vlax-invoke-method
g_modelspace
'AddLine
(vlax-release-object new_line)
  ;(vla-update g_acadapp)
  ;(vlax-release-object g_acadapp)
  (princ (strcat (rtos (- etime stime)) " Milliseconds"))
;15843.0000 Milliseconds
(defun c:kwb_speedtest2a (/ sp ep count stime)
  (setq count 0
  (repeat 50000
(setq
 count (1+ count)
(entmake
 (list
'(0 . "LINE")
sp
ep
  (princ
(strcat
 " Milliseconds"
;4281.0000 Milliseconds"
« Reply #8 on: May 27, 2004, 01:58:13 PM »
That's pretty speedy for 50,000 lines  heh.
« Reply #9 on: May 27, 2004, 02:04:21 PM »
Yep! notice the _slight_ *cough* difference between vlax-invoke-method and entmake
 - Jeff
if you dig through theswamp you will find similar results, SMadsen has proven this point before.
« Reply #10 on: May 27, 2004, 02:15:25 PM »
Yep I noticed ..
« Reply #11 on: May 27, 2004, 02:19:10 PM »
What happens when you put the color change back in.
Would be interesting to test vla-invoke-method ... against vla-addline ...
also
Why (vlax-release-object new_line) in each loop cycle ????
« Reply #12 on: May 27, 2004, 02:24:00 PM »
  (gc)
        intcolor     0
        count        0
  (repeat 50000
(vla-put-color
 (setq new_line
(vlax-invoke-method
  g_modelspace
  'AddLine
;21250.0000 Milliseconds
« Reply #13 on: May 27, 2004, 02:30:22 PM »
Quote from: Kerry Brown
Hi Kerry -- If I could impose -- when you have the time could you detail some of the shortcomings you've found using sharplisp? Of course, if you wish to include the flip side you certainly can, but I'm more interested in hearing about the drawbacks of using that product -- I've come close to buying it more than once, but then I think "Feh, I should just ante up and learn arx".
THANKS!
« Reply #14 on: May 27, 2004, 02:32:59 PM »
Mark ,
What was your time for my original kwb_speedtest1a on your machine ??
please :D
