Author Topic: multiple layuot tabs - 1 instance of title block inserted on some layouts  (Read 3303 times)
adalea03
Can I map an instance of a block to the layout it resides on?
If so, point me in the right direction, please.
What little I have so far is listed below.
;;; conditions: * multiple layuot tabs
;;;             * (1) instance of title block inserted on some but not all layuot tabs
;;; goal : associate each title block (entity or object) with its respective layout
;;;        so the end user can select the target title block by its associated
;;;        layout name from a dialog list_box ragardless of the 'current' layuot status
;;; assumed info requirements:
;;;        * list of layouts and/or layout blocks
;;;        * list of entity names or object IDs of each instance of title block
;;;        * etc. , etc. , ...
;;; problem : how to develop and report the assoiations so correct selection
;;;           can be made by the end user
(defun map-titleblocks-2-layouts (/ current-doc current-layout layout-list ps-layouts)
  (setq current-doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq current-layout (vlax-get-property current-doc 'ActiveLayout))
  (setq layout-list nil)
  (vlax-for xi (vla-get-layouts current-doc)
    (setq layout-list (cons (list
                              (vlax-get-property xi 'TabOrder)
                              (vlax-get-property xi 'Name)
                              (vlax-get-property xi 'Block)) layout-list)))
  (setq ps-layouts nil)
  (foreach xi (cdr (vl-sort (mapcar 'car layout-list) '<))
    (foreach ix layout-list
      (if (= xi (car ix))
        (setq ps-layouts (append ps-layouts (list ix))) nil)))
;;;   I'm stuck
Thank you,
Tony
Have you played with dictionaries or Xrecords ?
Just to expand the idea.
Each insert has a unique immutable handle.
You may be able to add a dictionary to each layout referencing the handle < or Name > of it's designated block instance. [ depending on the setup, this may be able to be automated ]
The layouts could then be iterated, extracting the referenced handle < or Name > which could then be programmatically selected.
FengK
maybe i didn't understanding the question. is there only one title block in each layout? if so, (ssget "X" (list (cons 0 "INSERT") (cons 2 blkName) (cons 410 layoutName)) should select that block, right?
Kelie, I wasn't too sure either ...
could even select if the blocks were different but similarly named.
adalea03
While not 'fluent' in X-records I have had success using that tecnique.
I will try
"...(ssget "X" (list (cons 0 "INSERT") (cons 2 blkName) (cons 410 layoutName)) ..."
first.
Thank you, Kerry, Kelly.
Tony
adalea03
Oh, by the way Kelie, it was
one instance of the title block on some but not all layouts.
Tony
adalea03
The solution was much simpler than I had expected.
  (setq my-tblks (ss2lst (ssget "X" (list (cons 0 "INSERT") (cons 2 "A-1117PP-3")))))
  (setq my-tblk-lst
    (mapcar '(lambda (x) (list (cdr (assoc 410 (entget x))) x)) my-tblks))
Thank you for all for your suggestions.
Tony
I thought that may have been what you wanted.
My answer was aimed at the original question ; ie
.. map an instance of a block to the layout it resides on?
which in itself is also an interesting idea if the block names were unique.
.. good to see your problem resolved.
