Author Topic: Malformed String??  (Read 2997 times)
vinnyg
Malformed String??
« on: January 09, 2007, 05:09:02 PM »
Hi All,
I recently added a few lines of code to a lisp program that was loading and
running just fine. Since I added these lines, I get this error message
"malformed string".  Here is the lines I added. Can anybody find the malformed
string and let me know how to correct it?
Appreciate any help
vinnyg
(setq ans50 (getstring "\n Do you want to locate a point for an
 embed at left side of panel near top? <Y or N>: "))
  (if (or (= ans50 "Y") (= ans50 "y"))
  (prompt "\n 1st point is how far")
  (setq pt1 (getdist "\nBelow top of panel?:"))
  (setq p108 (polar p4 (+(dtr 180) ang) pt1))
  (command "exit" "")
(setq ans51 (getstring "\n Do you want to locate a second point for an
 embed at right side of panel near top? <Y or N>: "))
  (if (or (= ans51 "Y") (= ans51 "y"))
  (prompt "\n 2nd point is how far")
  (setq pt2 (getdist "\nBelow top of panel?:"))
  (setq p109 (polar p3 (-(dtr 0) ang) pt2))
  (command "exit" "")
(setq ans52 (getstring "\n Do you want a center line between
 those 2 points <Y or N>: "))
  (if (or (= ans52 "Y") (= ans52 "y"))
  (setvar "clayer" "1")
  (setvar "cecolor "1")
  (command "line" p108 p109 "")
  (command "exit" "")
  (redraw)
) ; end of defun
<edit>  Added code tags   Mav
« Last Edit: January 09, 2007, 05:32:23 PM by Maverick® »
hmspe
Re: Malformed String??
« Reply #1 on: January 09, 2007, 06:28:34 PM »
The obvious issue is:
should be
  (setvar "cecolor" "1")
"Science is the belief in the ignorance of experts." - Richard Feynman
« Reply #2 on: January 09, 2007, 09:20:21 PM »
vinnyg,
If you open that code in the VLIDE < or any editor with color coding capability > you will/should see immediately where the problem is located.
« Reply #3 on: January 09, 2007, 09:24:14 PM »
as an aside, do you normaly draw byColor < not ByLayer >
'cause when the routine exits you will be left with all new objects being drawn byColor RED.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: January 09, 2007, 10:23:37 PM »
Kerry, How did you get the nice little red ellipse?
« Reply #5 on: January 09, 2007, 10:33:49 PM »
Snagit 8.2
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: January 09, 2007, 10:44:32 PM »
Very cool !
Thank you
vinnyg
« Reply #7 on: January 10, 2007, 09:01:22 AM »
Kerry & Danielm,
Thanks for your help....thought that maybe it was something as simple
as you pointed out, but just couldn't find it. Where can I get VLIDE or
any editor with color coding capability?
Thanks again
vinnyg
hmspe
« Reply #8 on: January 10, 2007, 09:43:04 AM »
The editor built-in to Autocad has color coding.  It's under Tools / AutoLISP / Visual LISP Editor
Martin
« Reply #9 on: January 10, 2007, 02:45:34 PM »
Type VLIDE at the command prompt.
