Author Topic: Modeless Dialog help  (Read 9615 times)
jmaeding
« on: January 09, 2007, 08:02:47 PM »
I am doing my first modeless dialog routine for Acad 2006 in .net, and need some help.
When done, the tool I am making will let you pick an entity, then show a dialog (or update it if shown) with its properties.
The dialog will also have ways to change the items layer properties, and buttons to step up or down in the nesting level.
Its a rewrite of the free ChLayColt tool on cadthinking.com, I will give out complete code along the way and when done so people can learn from this project.
I am using VB.net and VS2005.
I started by creating the form.  I did not do a user control since I don't want a palette in acad, just a form.
Question 1) can I use a user control to make a modeless dialog, just like how its done for a paletteset for acad?  the adesk labs give an example for a palette but not for a modeless dialog...
So I am going to give this tool a command name of CCM for the moment, since its fast to type.
I outlined the tasks to do with comments, some are blank.
This code for the form works fine though so far, compiles, loads into acad, and shows fine:
<CommandMethod("CCM")> _
    Public Sub ShowModalForm()
        'get entity pick
        'get properties
        'show dialog box if not already
        'lock doc
        Dim docLock As DocumentLock
        Try
            docLock = Application.DocumentManager.MdiActiveDocument.LockDocument()
            Dim modelessForm As frmMain = New frmMain()
            Application.ShowModelessDialog(modelessForm)
            docLock.Dispose()
        Catch ex As Exception
        End Try
    End Sub
Question 2) Is the docLocking necessary?  I read it was for modeless dialogs.  Clarification requested if its needed when showing a form, or just when an action spawned by the form has to do something involving acad, like change a layer property.
Question 3) Since this dialog will stay open, how do I test if its already open when CCM is run?  Obviously I'm new at .net, I could not find info on this one anywhere though.
Thanks for any help, feel free to point me to other examples of modeless dialogs, I could not find any.
James Maeding
It's Alive!
  • Retired
  • AKA Daniel
Re: Modeless Dialog help
« Reply #1 on: January 10, 2007, 12:13:08 AM »
maybe you can try
Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog();
« Reply #2 on: January 10, 2007, 12:23:59 AM »
maybe you can try
return this.Replace("maybe", "absolutely", 0, this.Length);
jmaeding
« Reply #3 on: January 10, 2007, 12:28:52 AM »
that's what I did, and it does maintain the ownership of the form.  When acad minimizes, so does the form.
I did see some examples of checking for modeless forms with general .net, not within acad.  I will see if I can adapt them.
James Maeding
jmaeding
« Reply #4 on: January 10, 2007, 01:03:01 AM »
I looked over the C# code posted, and I do not see how that addresses what I was asking.  The code I posted worked fine and showed the modeless dialog in acad.
I need to figure out how to test if its already shown next time CCM is run.
I also want to understand if doclocking is needed.
thx
James Maeding
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: January 10, 2007, 01:15:15 AM »
Try this solution
it's ugly but it works :)
added this is for Autocad 2007 you will need to change some code for 2006
enjoy
using System;
[assembly: CommandClass(typeof(ClassLibrary.CRPClass))]
namespace ClassLibrary
  public class CRPClass
    public CRPClass()
    [CommandMethod("Jim")]
    static public void test() // This method can have any name
      forjames.Form1 myform = new forjames.Form1();
      Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog(myform);
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using System.Runtime.InteropServices;
namespace forjames
  public partial class Form1 : Form
    public Form1()
      InitializeComponent();
    //for 2006
    /*[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl,
    EntryPoint = "?acedPostCommand@@YAHPBD@Z")]
    extern static public int acedPostCommand(string cmd);*/
    //for 2007
    [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode,
    EntryPoint = "?acedPostCommand@@YAHPB_W@Z")]
    //a new setfocus
    [DllImport("user32.dll")]
    private static extern System.IntPtr SetFocus(System.IntPtr hwnd);
    private void button_ok_Click(object sender, EventArgs e)
      this.Close();
    private void button_get_Click(object sender, EventArgs e)
      Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
      PromptEntityOptions entopts = new PromptEntityOptions("Pick an entity of your choice from the drawing");
      entopts.Message = "Pick an entity of your choice from the drawing";
      PromptEntityResult ent = null;
      try
        SetFocus(Autodesk.AutoCAD.ApplicationServices.Application.MainWindow.Handle);
        acedPostCommand("");
        ent = ed.GetEntity(entopts);
        if (ent.Status != PromptStatus.Error)
          ObjectId entid = ent.ObjectId;
          Database db = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database;
          Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = db.TransactionManager;
          using (Transaction myT = tm.StartTransaction())
            Entity entity = (Entity)tm.GetObject(entid, OpenMode.ForRead, true);
            this.textBox1.Text = entity.GetType().Name;
            myT.Commit();
        this.Focus();
      catch
edit ;; put more of the code in the try {}
« Last Edit: January 10, 2007, 01:36:56 AM by Danielm103 »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: January 10, 2007, 02:05:24 AM »
I am a little confused about "locking the document", I have never done this with any of my forms whether Modeless or not.
Maybe it’s because I always try to activate the active document before calling any methods.
Maybe one of the experts can shine a light on this as I am interested too.
 I had a lot of problems with forms pre 2007. I work with dual monitors and if my command line was not docked,
cad got a little confused on which window was active. That’s when I started using the p/invoke stuff.
So there might be better ways of setting the focus with 2007+
Dan
« Last Edit: January 10, 2007, 02:09:40 AM by Danielm103 »
Glenn R
« Reply #7 on: January 10, 2007, 09:55:34 AM »
Keep a private class level variable of your form's type and check each time the command is run for it's existence - if there, the dialog is active and do nothing. When someone closes the form, nullify the variable for next run OR just hide it and reshow - it's up to you.
As far as locking the document, you must do this if you're executing from the application context, which a modeless dialog is.
Cheers,
Glenn.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #8 on: January 10, 2007, 11:33:09 AM »
Sorry James, I miss read your post.
Just a question though, how are thinking of getting the objectid of the selected entity from your modal dialog to your ModelessDialog?
I don’t know how to do this with .NET but you might be able to get the hWnd (window handle) of your ModelessDialog to detect whether it’s open.
« Last Edit: January 10, 2007, 11:41:54 AM by Danielm103 »
jmaeding
« Reply #9 on: January 10, 2007, 01:08:36 PM »
No problem, any input helps.
The tool will only have one dialog, not two.  Assume for this command, that you are in Acad. Its not a tool that gets run from the outside somehow.
The lisp version of the tool does it with a modal so the modeless part is not critical, its almost an excercise to understand how to do it. It will make the tool slicker though, no doubt.
The class level variable is exactly what I had seen for general .net modeless dialogs.  That makes sense because the existance of the form object itself tells all.
I need some help on that approach though.
The private variable gets set to nothing after the form is shown.  I found this during debug, the variable has a value (a class id) in the ShowModelessForm method, but nothing when the close button callbak fires.
Here is the current code:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Windows
Imports Autodesk.AutoCAD.Runtime
Public Class frmMain
    Inherits System.Windows.Forms.Form
    Private modelessForm As frmMain '<----- Private variable discussed
    Public Sub ShowModelessForm()
        If Me.modelessForm Is Nothing OrElse Me.modelessForm.IsDisposed Then
            Try
                Me.modelessForm = New frmMain()
                Me.AddOwnedForm(Me.modelessForm)
                docLock.Dispose()
            End Try
        Else
            Try
                Me.modelessForm.Activate()
                docLock.Dispose()
            End Try
        End If
    End Sub
    Private Sub cmdClose_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles cmdClose.Click
        If Not Me.modelessForm Is Nothing AndAlso Not Me.modelessForm.IsDisposed Then
            Me.modelessForm.Close()
        End If
    End Sub
End Class
Now the modelessForm variable works great to test if the form is already shown, that question is answered.
Only issue now is the close button callback, it never runs the Me.modelessForm.Close() code because modelessForm is nothing (discovered from debugging).
I must have scoped or be testing the variable wrong.
I am wondering why I dont just do a Try...Me.modelessForm.Close() type statement, would that cause problems?
I also don't understand what the disposed property is.  Is that wen garbage collection has not destroyed the object yet?
thanks
James Maeding
jmaeding
« Reply #10 on: January 10, 2007, 01:25:33 PM »
Maybe I should not be doing all this in the form.  It looks like everyone is saying to make a class, then have the class call the form.
The class has the private variable, not the form.  That did seem odd to me that a form would have a variable pointing to itself.
I am still confused how the modelessForm variable got set to nothing if the form is still open though...
I'll do some playing around, it has to be a scoping thing.
James Maeding
jmaeding
« Reply #11 on: January 10, 2007, 02:42:29 PM »
I think the close issue is easier than I thought.  I changed the program structure to be two parts, a class and a form that gets called.
All I want is the close button to close the form, which must be showing to be called.  No need to check if it exists like with the code that shows the form.
So now the only code in the form is:
       Me.Close()
End Sub
Seems to work great, I wonder if dock locking is neeeded for the close method though.  This locking and error checking is theoretical so far, that will likely change soon...
James Maeding
Glenn R
« Reply #12 on: January 11, 2007, 06:05:51 AM »
Whatever file your [CommandMethod("WhatEver")] is defined in, is a class......sooooo, toss a private member variable of your form type in there and away you go........and in your commandmethod itself, that's where you check for the existence of your private variable and do your appropriate mojo...to show or not show, that is the question.
Cheers,
Glenn.
jmaeding
« Reply #13 on: January 11, 2007, 02:18:36 PM »
Exactly, that is working well.
I put this in the class:
then tested with this to see if I should open new or not:
If Me.modelessForm Is Nothing OrElse Me.modelessForm.IsDisposed Then...
I know you don't need the code, but I thought to slap it down so others reading this might see it.
I'm a happy camper at this point, the modeless form is working great.  Thanks for everyone's help!
James Maeding
It's Alive!
  • Retired
  • AKA Daniel
« Reply #14 on: January 11, 2007, 06:56:33 PM »
Cool James, we eat up samples of code  :lol:
We hope you come out to play with us more often
