Author Topic: Simple add text  (Read 9224 times)
mohnston
  • CAD Programmer
Simple add text
« on: January 09, 2007, 12:43:55 PM »
I'm trying to add a piece of text to a drawing and then save and close the drawing.
This code runs without error but the text is not on the drawing when I open it to check.
There has to be something simple wrong.
Won't you help? Look deep inside yourself and do the right thing.
private void StampDrawing(string fullDwgPath, string stampString)
   Document ThisDrawing = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(fullDwgPa th);
   ThisDrawing.LockDocument();
   Database thisDB = ThisDrawing.Database;
   Autodesk.AutoCAD.ApplicationServices.TransactionManager tm = ThisDrawing.TransactionManager;
   using (Transaction trans = tm.StartTransaction())
      BlockTable bt = (BlockTable)thisDB.BlockTableId.GetObject(OpenMode.ForWrite);
      BlockTableRecord modelsp = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
      DBText stampText = new DBText();
      stampText.TextString = stampString;
      stampText.Height = 12;
      stampText.HorizontalMode = TextHorizontalMode.TextRight;
      stampText.Rotation = 0;
      modelsp.AppendEntity(stampText);
      trans.TransactionManager.AddNewlyCreatedDBObject(stampText, true);
      trans.Commit();
   tm.Dispose();
   ThisDrawing.CloseAndSave(fullDwgPath);
   thisDB.Dispose();
CAD Programming Solutions
Chuck Gabriel
Re: Simple add text
« Reply #1 on: January 09, 2007, 01:11:23 PM »
I don't see where you have set the location of the text.  Could that be it?
Here is some C++ code that might help.  I know it's not C#, but it's close enough that you should be able to get the gist of it.
AcDbObjectId AcadUtilities::addText(
const AcGePoint3d& insertion,
const double& height,
const double& rotation,
const AcDb::TextHorzMode& horizMode,
const AcDb::TextVertMode& vertMode,
const string& textString,
const string& layerName) {
AcDbObjectPointer<AcDbText> textObj;
if(textObj.create() != Acad::eOk) {
acutPrintf("\nUnable to create text object.");
return AcDbObjectId::kNull;
textObj->setHeight(height);
textObj->setRotation(rotation);
textObj->setHorizontalMode(horizMode);
textObj->setVerticalMode(vertMode);
textObj->setTextString(textString.c_str());
appendObject(textObj.object());
textObj->setLayer(layerName.c_str());
if((horizMode == AcDb::kTextLeft) && (vertMode == AcDb::kTextBase))
textObj->setPosition(insertion);
else
textObj->setAlignmentPoint(insertion);
return textObj->objectId();
LE
Re: Simple add text
« Reply #2 on: January 09, 2007, 01:46:44 PM »
This works...
        [CommandMethod("ADDTEXT")]
        public void addText()
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                stampText.TextString = "TESTING";
                btr.AppendEntity(stampText);
                tr.AddNewlyCreatedDBObject(stampText, true);
                tr.Commit();
LE
Re: Simple add text
« Reply #3 on: January 09, 2007, 03:19:26 PM »
After reviewing your code a little more, the problem is on those lines, change it to:
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord modelsp = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
Have fun
note: make sure you use your own thisDB instead of db
« Last Edit: January 09, 2007, 03:21:34 PM by LE »
mohnston
  • CAD Programmer
Re: Simple add text
« Reply #4 on: January 09, 2007, 04:35:51 PM »
You might be on the right track LE.
I made the changes you suggest but not joy.
I suspect it has something to do with working on a drawing that is not the current drawing when the code starts.
        private void StampDrawing(string fullDwgPath, string stampString, bool FullSize)
            Document ThisDrawing = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(fullDwgPath);
            Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = ThisDrawing.Database.TransactionManager;
                BlockTable bt = (BlockTable)trans.GetObject(thisDB.BlockTableId, OpenMode.ForWrite);
                Point3d pIns = new Point3d(1070, 15, 0);
                stampText.Position = pIns;
                trans.Commit();
            tm.Dispose();
            thisDB.Dispose();
Your example code doesn't do what I need.
I need to open a document, add the text, save the document and close it.
Chuck, thanks for the C++ but I'm C++ illiterate. It might as well be C%$#@.
I was concerned about the location of the text also. I thought I would tackle this first and make location another thread.
There is no setPosition or setAlignmentpoint method for DBText.
There is a Position property which I set in this revised code.
Text is not on drawing when I open it.
LE
Re: Simple add text
« Reply #5 on: January 09, 2007, 04:46:50 PM »
Ok... I might end up running some tests if I had a chance.
For the alignment you need to use: TextHorizontalMode
« Last Edit: January 09, 2007, 05:06:27 PM by LE »
LE
Re: Simple add text
« Reply #6 on: January 09, 2007, 05:56:40 PM »
If I use, a session command, at least adds the text, but shows an error...
        [CommandMethod("TESTEXT", CommandFlags.Session)]
        public void txt()
            StampDrawing("C:\\test.dwg", "TESTING", true);
« Last Edit: January 09, 2007, 05:58:12 PM by LE »
LE
Re: Simple add text
« Reply #7 on: January 09, 2007, 06:11:22 PM »
I see.... you know what, the call to ThisDrawing is doing a Read-Only....
LE
Re: Simple add text
« Reply #8 on: January 09, 2007, 06:16:18 PM »
Here is the code that is working, we need to make sure the preview will be saved...
        [CommandMethod("TXT", CommandFlags.Session)]
        public void txt()
            Document ThisDrawing = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(fullDwgPath, false);
                trans.Commit();
            tm.Dispose();
            thisDB.Dispose();
Re: Simple add text
« Reply #9 on: January 09, 2007, 06:25:30 PM »
This is how I did it.
db.RetainOriginalThumbnailBitmap = true;
Re: Simple add text
« Reply #10 on: January 09, 2007, 06:35:26 PM »
Just running past, no time to play ...
Luis, you may want to wrap the locdoc in a using statement so it behaves a little better
            using (DocumentLock doclock = doc.LockDocument())
                using (Transaction tr = doc.TransactionManager.StartTransaction())
                    // bla, bla
:added:
... or at least disposing it by adding :
docLock.Dispose();
« Last Edit: January 09, 2007, 06:40:54 PM by Kerry Brown »
LE
Re: Simple add text
« Reply #11 on: January 09, 2007, 06:43:27 PM »
                    // bla, bla
Kerry;
That's scary.... I was about to implement that in this moment.... do you read minds?.... anyway, I think Mark has something that is working now :)  - also, remember that Glenn mentioned that if it is wrap inside a using the transaction, there were no need of the lock doc?... or I am dreaming?
Thanks, Tim;
I have seen that statement but only before a SaveAs... no idea if it can be applied to CloseAndSave... care to test that anyone?
Cheers!
Re: Simple add text
« Reply #12 on: January 09, 2007, 06:45:33 PM »
<snip>
That is how I use it, before a SaveAs.  I'm sick, and not well enough to think in C# right now or I would.  Sorry Luis.
Re: Simple add text
« Reply #13 on: January 09, 2007, 06:47:59 PM »
Yes, but only the positive vibes, I filter out all the negative stuff   ;-)
mohnston
  • CAD Programmer
Re: Simple add text
« Reply #14 on: January 09, 2007, 08:00:26 PM »
Kerry;
.... anyway, I think Mark has something that is working now :)...Cheers!
Not working.
I tried moving the procedure code out of my form class to regular class. No text.
I think it might have something to do with where I'm calling the code from. In my case it's a modal dialog.
