Author Topic: eLockViolation of blocktable  (Read 7453 times)
mohnston
  • CAD Programmer
« on: January 08, 2007, 08:08:43 PM »
Why would I get an error that says eLockViolation on the line "BlockTable bt = (BlockTable)thisDB.BlockTableId.GetObject(OpenMode.ForWrite);"
private void StampDrawing(string fullDwgPath, string stampString, bool FullSize)
   Document ThisDrawing = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(fullDwgPath);
   Database thisDB = ThisDrawing.Database;
   Autodesk.AutoCAD.ApplicationServices.TransactionManager tm = ThisDrawing.TransactionManager;
   using (Transaction trans = tm.StartTransaction())
      BlockTableRecord modelsp = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
      DBText stampText = new DBText();
      stampText.TextString = stampString;
      stampText.Height = 12;
      stampText.HorizontalMode = TextHorizontalMode.TextRight;
      stampText.Rotation = 0;
      modelsp.AppendEntity(stampText);
      trans.TransactionManager.AddNewlyCreatedDBObject(stampText, true);
      trans.Commit();
   tm.Dispose();
   ThisDrawing.CloseAndSave(fullDwgPath);
   thisDB.Dispose();
The file opens fine but I am unable to get the blocktable.
CAD Programming Solutions
Re: eLockViolation of blocktable
« Reply #1 on: January 08, 2007, 08:39:33 PM »
What is your
[CommandMethod(..... CommandFlags.XXXX
.. is it set to .Session ??    IE Application context
changing the database in Session mode without locking the database may be the issue
/// kwb
« Last Edit: January 08, 2007, 08:41:52 PM by Kerry Brown »
« Reply #2 on: January 08, 2007, 08:40:45 PM »
... or is this called from a modeless dialog ? ?
same issue !
mohnston
  • CAD Programmer
« Reply #3 on: January 09, 2007, 10:50:16 AM »
You are correct. The code was being launched from a dialog button.
I added the Document.LockDocument() and the error went away.
Thank you!
Sadly, my text does not appear on that drawing.
