Author Topic: (code) working eith objects  (Read 3466 times)
« on: May 25, 2004, 09:30:49 AM »
Just something to look at.
(defun get-utilobj ()
  (vla-get-utility
    (vla-get-activedocument
      (vlax-get-acad-object))
;;; returns a vla-object or nil
(defun obj-select (/ obj pt)
    (not (vl-catch-all-error-p
           (vl-catch-all-apply
             'vlax-invoke-method
             (list (get-utilobj) 'GetEntity 'obj 'pt)
    obj
;;; returns the id number(integer) of the current modelspace object
(defun get-mspace-id ()
  (vla-get-objectid
    (vla-get-modelspace
;;; returns the id number(integer) of the current paperspace object
(defun get-pspace-id ()
  (vla-get-objectid
    (vla-get-paperspace
;;; returns what 'space' (string) the supplied object resides
(defun what-space-t (obj)
  (if (= (type obj) 'VLA-OBJECT)
    (cond ((= (vla-get-ownerid obj) (get-mspace-id))
           "model"
          ((= (vla-get-ownerid obj) (get-pspace-id))
           "paper"
(defun c:main1 (/ obj)
  (if (setq obj (obj-select))
    (alert (strcat "the object is in " (what-space-t obj) "space"))
;;; returns the paperspace object
(defun get-pspace ()
  (vla-get-paperspace
;;; returns the modelspace object
(defun get-mspace ()
  (vla-get-modelspace
;;; returns the object (model/paperspace) the supplied object
;;; resides in
(defun what-space-o (obj)
    (cond ((= (vla-get-ownerid obj) (vla-get-objectid (get-mspace)))
           (get-mspace)
          ((= (vla-get-ownerid obj) (vla-get-objectid (get-pspace)))
           (get-pspace)
(defun c:main2 (/ obj)
    (vlax-dump-object (what-space-o obj))
  (textscr)
