Author Topic: extrude region from exploded block  (Read 9674 times)
Re: extrude region from exploded block
« Reply #15 on: August 29, 2007, 04:20:54 PM »
You're welcome, I'm glad I could help!
MickD
  • (x-in)->[process]->(y-out)
« Reply #16 on: December 05, 2007, 12:52:39 AM »
Hi All,
I have to knock out a quick modeling app similar to this, I don't have time to do it in a LL language and it will be more of a prototype to be ported later if all works well.
Anyway, I've borrowed some of Duh's code and I have a small problem, I have a library of shapes as polylines already to go, what I want to do is insert the polyline as a block, explode it to get the polyline and extrude it but I'm getting a 'self reference' error, here's the code so far.
Public Sub DrawSection()
      Dim oLayer As AcadLayer
      Dim oBeam As Acad3DSolid, oReg As AcadRegion, oBlock As AcadBlockReference, oObject As Variant
      Dim Inspt As Variant
      Dim RegEnt(0) As AcadEntity
      Set oLayer = ThisDrawing.Layers.Add("3D-mbr")
      oLayer.color = 235
      Inspt = ThisDrawing.Utility.GetPoint(, "Pick Insertion Point: ")
      Set oBlock = ThisDrawing.ModelSpace.InsertBlock(Inspt, "C:\DCS3d\310UB040.dwg", 1#, 1#, 1#, 0) '<--self ref error here
      ThisDrawing.Regen acActiveViewport
      Set oObject = oBlock.Explode
      Set RegEnt(0) = oObject
      oReg = ThisDrawing.ModelSpace.AddRegion(RegEnt)
      Set oBeam = ThisDrawing.ModelSpace.AddExtrudedSolid(oReg(0), 1000, 0)
      oReg(0).Delete
End Sub
Once I get this sorted I will add code to look up the file by name and let the user select the appropriate section, add some data to it for BOM's and manipulation and transform it into it's final place.
tia,
Mick.
SEANT
« Reply #17 on: December 05, 2007, 05:55:22 AM »
I can’t recreate that error here (AutoCAD 2004), even with the C:\DCS3d\310UB040.dwg active. :?
Generating the appropriate solid, however,  wouldn't happen until modifications (see earlier post by Jeff_M) were made to these lines of code:
      oObject = oBlock.Explode  '<---------------------
      Set RegEnt(0) = oObject(0) '<---------------------
« Last Edit: December 05, 2007, 06:55:44 AM by SEANT »
Sean Tessier
AutoCAD 2016 Mechanical
kpblc
« Reply #18 on: December 05, 2007, 07:13:07 AM »
Try this one (i didn't test it):
Public Function DrawSection(Optional DWGPath As String = "c:\DCS3d", _
  Optional DWGName As String = "310UB040") As AcadObject
' DWGPath - path to dwg-file (w/o splash)
' DWGName - file name w/o extension
' There is no control for these parameters
Dim objLayer As AcadLayer, objBeam As Acad3DSolid, objRegion As AcadRegion
Dim objBlockRef As AcadBlockReference, objBlockExplode As Variant
Dim ptInsert As Variant, lCounter As Long
  Set objLayer = ThisDrawing.Layers.Add("3D-mbr")
  objLayer.color = 235
On Error Resume Next
  objLayer.Freeze = False
  objLayer.Lock = False
  ptInsert = ThisDrawing.Utility.GetPoint(, "Pick Insertion Point <Cancel> : ")
  If IsEmpty(ptInsert) Or Err.Number <> 0 Then Exit Function
  If ThisDrawing.Blocks.Item(DWGName) Is Nothing Then
    Set objBlockRef = ThisDrawing.ModelSpace.Insertnblock(ptInsert, _
      DWGPath & "\" & DWGName & ".dwg", 1#, 1#, 1#, 0#)
  Else
      DWGName, 1#, 1#, 1#, 0#)
  End If
  objBlockExplode = objBlockRef.Explode
  objBlockRef.Delete
  For lCounter = LBound(objBlockExplode) To UBound(objBlockExplode)
    If objBlockExplode(lCounter).ObjectName = "AcDbRegion" Then
      objRegion = objBlockExplode(lCounter)
      Exit For
    End If
  Next lCounter
  Set objBeam = ThisDrawing.ModelSpace.AddExtrudedSolid(objRegion, 1000#, 0)
  objRegion.Delete
  DrawSection = objBeam
End Function
Sorry for my English.
David Hall
  • Automatic Duh Generator
« Reply #19 on: December 05, 2007, 02:38:46 PM »
Hi All,
      oLayer.color = 235
      oReg(0).Delete
End Sub
tia,
Mick.
Did you get it to work?
They say money can't buy happiness, but it can buy Bacon and that's a close second
MickD
« Reply #20 on: December 05, 2007, 04:24:24 PM »
@SEANT - I did have that code in there, I changed the oObject(0) though with no improvement.
@kpblc - thanks for that but it's still not working, I commented out On Error resume next to catch a bug and it gives a 'key not found' error at the line -> If ThisDrawing.Blocks.Item(DWGName) Is Nothing Then
And thanks for the function, you have anticipated my future needs well ;)
@CmdrDuh - not yet, I didn't mention that I was using 2007, I didn't think it mattered until I found a thread where you had the same trouble but I tried adding the file string to a variable but had the same result.
I'll keep playing and see what I can come up with, thanks.
P.S. - with all examples, after I stop the code I do not have the block listed in the dlg when I do a manual insert so the block ref isn't in the table still, I tried adding a block to the table first but it was no better.
kpblc
« Reply #21 on: December 05, 2007, 05:10:34 PM »
That's right - if there is no block named DWGName in file this line will generate a error.
MickD
« Reply #22 on: December 05, 2007, 05:27:26 PM »
Ok, do you mean that I have to create a block inside the file 310UB040.dwg called 310UB040 ?
At the moment it is a polyline in a drg file, I want to insert the file as a block, explode it to get the polyline the use the polyline for the extrusion.
I just tried to make a block inside the dwg file but no good, I also purged the block from the file so it was just the polyline too.
I'm missing something simple I think.
kpblc
« Reply #23 on: December 05, 2007, 06:05:46 PM »
No! Never! To 'erase' a error with commented line you should have a block named 310UB040 in current drawing. In 'empty' dwg you haven't it, right? Because of this you should insert a file 'like a block'. At second calling this vba-routine you've got a block definition, so you just insert getted block definition (to exclude a error 'duplicate block definition').
MickD
« Reply #24 on: December 05, 2007, 06:07:48 PM »
Ok, with this code below -
  Else
  End If
wouldn't the first 'if' generate a block named "c:\DCS3d\310UB040.dwg"
and the second 'Else' is looking for just "310UB040" ???
« Reply #25 on: December 05, 2007, 06:28:32 PM »
Well it would, or should anyway, if you spelled InsertBlock without the second "n" :-)
I'm seriuosly looking now though.....
MickD
« Reply #26 on: December 05, 2007, 06:40:38 PM »
heh, I haven't been that far through the code yet :)
I can't believe that the help doc's does not have an example of inserting a block from a drg file?? I would've thought that the idea of block, write once use many times not to create them through code!?
I actually got the old code to insert the block, it still breaks on the explode line but when I stop the debug I'm leaft with a block and a polyline ??
thanks Jeff.
edit - If I just insert the block, no prob's, I'll look a bit closer at the explode method
MickD
« Reply #27 on: December 05, 2007, 06:47:17 PM »
Ok, so acad strips the path and the file ext., that's good to know.
forget my previous post.
« Reply #28 on: December 05, 2007, 06:55:49 PM »
Mick,
This works for me....although I'd think you'd probably want to delete the BlockRef & Polyline once you have the Solid.
Option Explicit
      Dim oBeam As Acad3DSolid, oReg As Variant, oBlock As AcadBlockReference, oObject As Variant
      oLayer.color = 235
      'ThisDrawing.Regen acActiveViewport
      oReg(0).Delete
End Sub
MickD
« Reply #29 on: December 05, 2007, 07:03:39 PM »
Excellent Jeff!
I almost had kpblc's code working too, I've compared notes and should be able to work it out, I'll post when done.
thanks again.
