Author Topic: Copying plot settings  (Read 23129 times)
Re: Copying plot settings
« Reply #60 on: February 02, 2007, 10:50:20 PM »
Just running past ...
Thanks Glenn ... sometimes wish my old brain could handle the C++ translation to C# more easily.
I'm assuming you are feeding that from a previously saved file list ??
Mark,
I'd be interested in seeing your solution for writing/appending to the DSD file when you get your issues sorted out. I think this methodology may have some potential for something I have had fermenting for a while.
Glenn R
« Reply #61 on: February 02, 2007, 10:59:04 PM »
Kerry,
A Listview with all the drawings you want batched and a ListBox containing pagesetups...you can run mutiple plots to different devices/files all in one hit.
c_witt
« Reply #62 on: June 19, 2013, 04:42:18 PM »
Greetings from the future.
Just wanted to offer my thanks to all in this thread.   Solved my current problem.
Thank you.
