Author Topic: Help with file filtering  (Read 1895 times)
ELOQUINTET
« on: January 04, 2007, 12:15:16 PM »
We have a routine which we use to update and attribute in many drawings but it will only do so in .dwg files but we now need to include .dwt as well to update our templates. I found the bit of code that filters the file type but how do I specify .dwg and .dwt? I will play around with it myself but any help will be appreciated. Thanks
myOpen.Filter = "Drawings (*.dwg)|*.dwg" 'Set a filter
Chuck Gabriel
Re: Help with file filtering
« Reply #1 on: January 04, 2007, 12:28:10 PM »
    myOpen.Filter = "AutoCAD Drawing files (*.dwg)|*.dwg|" & _
                          "AutoCAD Drawing Interchange files (*.dxf)|*.dxf"
    myOpen.DefaultExt = "dwg"
ELOQUINTET
« Reply #2 on: January 04, 2007, 12:43:51 PM »
thanks chuck works great you're the best
