Author Topic: text style replacement  (Read 27811 times)
Andrea
Re: text style replacement
« Reply #15 on: January 03, 2007, 11:14:37 PM »
Hi Kerry, and thanks for the reply...
you'r right....SIMPLEX is a font name....but can be also the style name.
we work with many clients standards here...
so we are trying to make something easy for CAD user,..
STYLE NAME = FONT NAME here..
because to many architect use the something like..
STYLENAME = ARIAL
FONTNAME = SIMPLEX
see ?
there is what i was able to do with your appreciated help guys...
(defun c:test (/ ActDoc Obj Blk)
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(vlax-for Blk (vla-get-Blocks ActDoc)
  (vlax-for Obj Blk
    (or
     (= (vla-get-ObjectName Obj) "AcDbText")
     (= (vla-get-ObjectName Obj) "AcDbAttributeDefinition")
    (vla-put-stylename Obj "SIMPLEX")
   (vla-put-layer Obj "0")
this code seem to work.....
the problem is the block is good when inserting new one..
but all the existing are not updated.
is this in the code ?
« Last Edit: January 04, 2007, 09:05:52 AM by Andrea »
Keep smile...
Patrick_35
« Reply #16 on: January 04, 2007, 09:37:11 AM »
Hi
And with this
(defun c:test (/ Att ActDoc att Obj Blk n tot)
  (setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)) tot 0 n 0)
    (setq tot (+ tot (vla-get-count blk)))
  (acet-ui-progress-init "Traitement" tot)
    (vlax-for Obj Blk
      (setq n (1+ n))(setq aa obj)
      (acet-ui-progress-safe n)
      (if  (member (vla-get-ObjectName Obj) '("AcDbText" "AcDbMText" "AcDbAttributeDefinition"))
        (vl-catch-all-apply 'vla-put-stylename (list Obj "SIMPLEX"))
      (if (eq (vla-get-objectname Obj) "AcDbBlockReference")
        (if (eq (vla-get-hasattributes Obj) :vlax-true)
          (foreach Att (vlax-invoke Obj 'getattributes)
            (vl-catch-all-apply 'vla-put-stylename (list Att "SIMPLEX"))
  (acet-ui-progress-done)
Amicalement
Andrea
« Reply #17 on: January 04, 2007, 10:01:01 AM »
Bonne année Patrick..
Thanks for the help.
acet-ui-progress.....nice initiative !
I forgot the
"AcDbMText" Oops..
what is
(setq aa obj) for ?
Keep smile...
Patrick_35
« Reply #18 on: January 04, 2007, 10:21:02 AM »
Merci, à toi aussi et surtout bonne santé  :-)
(setq aa obj) It's for my tests. I forgot to remove it  :roll:
Andrea
« Reply #19 on: January 04, 2007, 10:58:10 AM »
Thanks.   :roll:
ok..
can anyone help me to finalise the routine..with this :
(vlax-for style (vla-get-textstyles (vla-get-activedocument (vlax-get-acad-object)))
      (= (strcase (vla-get-stylename style)) "SIMPLEX") ;;this line not working..
      (/= (strcase (vla-get-fontfile style)) "SIMPLEX.SHX")
    (vla-put-fontfile style "SIMPLEX.SHX")
Keep smile...
« Reply #20 on: January 04, 2007, 11:14:01 AM »
How about this vla-get-textfontstyle
Andrea
« Reply #21 on: January 04, 2007, 11:28:53 AM »
not sure to understand..
vla-get-stylename is not to get the textstyle ?
Keep smile...
« Reply #22 on: January 04, 2007, 11:30:52 AM »
Thanks.   :roll:
ok..
You shouldn't need this.  Once you change all the objects that depend on text styles, just delete the styles you don't want.
If you want to use something like this, then when you are stepping through the text style collection, you only need to check the 'Name' property, not 'StyleName' as that is only available on objects that use text objects.
The routine Patrick gave you is pretty close to what you want, but he doesn't check for 'Constant Attributes' within blocks, and nothing about 'Tables' or 'Dimensions', and nothing about text style overrides within 'Mtext' or 'Tables'.
« Reply #23 on: January 04, 2007, 11:54:32 AM »
Oh, I see, he is making sure Style SIMPLES uses the font file SIMPLEX.SHX
So as Tim said, this is what you need:
(= (strcase (vla-get-name style)) "SIMPLEX")
« Last Edit: January 04, 2007, 11:58:38 AM by CAB »
VVA
« Reply #24 on: January 04, 2007, 12:03:50 PM »
Corrected code Patrick_35. Checks property StyleName and TextStyle of object
  ;_Unlock Layers
  (vlax-for lay (vla-get-layers ActDoc)
    (vla-put-Lock lay :vlax-false)
    (vl-catch-all-apply 'vla-put-Freeze (list lay :vlax-false))
  (vla-put-ActiveLayer ActDoc (vla-item (vla-get-layers ActDoc) "0"))
  ;_Make TextStyle
  (mapcar (function (lambda ( _font  / text_style)
(setq text_style  (vla-add (vla-get-textstyles ActDoc) _font))
(vla-put-fontfile text_style "SIMPLEX.SHX")
(vla-put-height text_style 0.0)
(vla-put-width text_style 1.0)
        (vla-put-activetextstyle ActDoc text_style)))
'("SIMPLEX"))
    (vlax-for Obj Blk
      (setq n (1+ n))
((vlax-property-available-p Obj 'TextStyle) ;_DIMENSION
(vl-catch-all-apply 'vla-put-TextStyle (list Obj "SIMPLEX"))
((vlax-property-available-p Obj 'StyleName) ;_TEXT,MTEXT, ATTRIBUTE
((and
   (not (vlax-property-available-p Obj 'Path)) ;_Not Xref ???
(t nil)
Patrick_35
« Reply #25 on: January 04, 2007, 12:21:49 PM »
I think the same thing as T.Willey but if you need this code, here
  (if (/= (strcase (vla-get-fontfile style)) "SIMPLEX.SHX")
Yes, I don't think of them, but Andrea can modify the lisp
Nice code VAA  :-)
Andrea
« Reply #26 on: January 04, 2007, 03:41:57 PM »
Nice code VAA  !!??
You mean VVA !
 :police:
yes,...very nice.
But, guys,...I don't know where you lurn all this....but very useful.
thank you very much...
last thing.....
with the..
(vla-put-layer Obj "0")It change all on layer "0".
But I need to change only all layer inside the block to "0" and leave the layer insertion of the block.
(see picture below)
for the moment I run the routine....and
add the previous code to reset the layer...
but i'm trying to understand what is the OBJ versus the BLK variable..
« Last Edit: January 04, 2007, 03:43:30 PM by Andrea »
Keep smile...
Andrea
« Reply #27 on: January 04, 2007, 04:02:23 PM »
this is how i've modified the routine for doing exactly what i need..
but i'm sure there is another solution..
(defun c:TEST (/ Att ActDoc att Obj Blk n tot f)
  ;_Unlock les couches
;;  (vla-put-ActiveLayer ActDoc (vla-item (vla-get-layers ActDoc) "0"))
;;capture tous les block
;;CREATION DU STYLE SIMPLEX
'("SIMPLEX"))
;;traitement des blocks
    (vlax-for Obj Blk
      (setq n (1+ n))
      (setq f (vla-get-layer Obj))
((and
(vla-put-layer Obj f)
(t nil)
(setq ss1 (ssget "X" '((0 . "MTEXT,TEXT"))))
(if ss1
(setq sscount (sslength ss1))
(setq val1 (- sscount 1))
(repeat sscount
(setq ent (vlax-ename->vla-object (ssname ss1 val1)))
(vla-put-layer ent "TextLayer")
(setq val1 (- val1 1))
  (vla-Regen ActDoc acActiveViewport)
Keep smile...
« Reply #28 on: January 04, 2007, 06:09:04 PM »
I wasn't going to, but I got bored.  Here is how I would do it.  It won't change the text for dim styles, or for formated mtext, but it will change all the rest.  It also assumes that layers that need to be unlocked are, and that the text style you name in the calling function exists in the drawing.
(defun ChangeAllTextObjectsStyle (Doc StyName / tempObjType IsLo ColCnt RowCnt)
(vlax-for Blk (vla-get-Blocks Doc)
 (setq IsLo (if (= (vla-get-IsLayout Blk) :vlax-true) T nil))
 (if (= (vla-get-IsXref Blk) :vlax-false)
  (vlax-for Obj Blk
   (setq tempObjType (vla-get-ObjectName Obj))
    ((vl-position tempObjType '("AcDbText" "AcDbMText" "AcDbAttributeDefinition"))
     (vla-put-StyleName Obj StyName)
     (if (not IsLo)
      (vla-put-Layer Obj "0")
    ((wcmatch tempObjType "AcDb*Dimension")
     (vla-put-TextStyle Obj StyName)
    ((= tempObjType "AcDbBlockReference")
     (foreach Att (vlax-invoke Obj 'GetAttributes)
      (vla-put-StyleName Att StyName)
     (foreach Att (vlax-invoke Obj 'GetConstantAttributes)
    ((= tempObjType "AcDbTable")
     (setq ColCnt 0)
     (repeat (vla-get-Columns Obj)
      (setq RowCnt 0)
      (repeat (vla-get-Rows Obj)
       (vlax-invoke Obj 'SetCellTextStyle RowCnt ColCnt StyName)
       (setq RowCnt (1+ RowCnt))
      (setq ColCnt (1+ ColCnt))
Call like for the active drawing.
(ChangeAllTextObjectsStyle (vla-get-ActiveDocument (vlax-get-Acad-Object)) "Simplex")
Edit:  I changed the wording in the attribute area to be correct.  I had it trying to change 'TextStyle' but needed to be 'StyleName'.
« Last Edit: January 04, 2007, 06:49:17 PM by T.Willey »
dan19936
« Reply #29 on: January 04, 2007, 07:35:44 PM »
Tim, nice code, you're very productive when you're bored...
An ignorant question, you have the acad object passed in as a variable. Does one ever not use the active document?
Thanks,
Dan
