Author Topic: text style replacement  (Read 27817 times)
Re: text style replacement
« Reply #30 on: January 04, 2007, 07:40:56 PM »
Tim, nice code, you're very productive when you're bored...
An ignorant question, you have the acad object passed in as a variable. Does one ever not use the active document?
Thanks,
Dan
Sometimes, like with DBX or when reading from another db, you will need to pass 'that' doc reference.
« Reply #31 on: January 04, 2007, 07:47:46 PM »
Thanks,
Dan
Yup.  Thanks Kerry.
and Thanks Dan for the nice comment.  I just like the flexibility of it, since the way the code is written it could be called from, and used with, ObjectDBX.
Andrea
« Reply #32 on: January 05, 2007, 08:46:25 AM »
Tim....
Thank you !
The code work perfectly.
Keep smile...
« Reply #33 on: January 05, 2007, 11:04:55 AM »
Tim....
Thank you !
I'm glad Andrea.  I hope you can learn from it.  And You're Welcome.
Andrea
« Reply #34 on: January 05, 2007, 11:15:40 PM »
Tim....
Thank you !
I lurn each day Tim......but with you guys......I lurn more faster..  :roll:
just a little thing...
the code works perfectly since I got a new drawing from client...
the..
....     (if (not IsLo)
      (vla-put-Layer Obj "0")......
section seem to work.....but even with regenall or
(vla-Regen (vla-get-ActiveDocument (vlax-get-Acad-Object)) acActiveViewport)all blocks seem to not being refreshed...(<- is this a english word ?)  :|
Keep smile...
« Reply #35 on: January 05, 2007, 11:19:22 PM »
the..
....     (if (not IsLo)
What do you think Tims code should do to the blocks Andrea ?
Joe Burke
« Reply #36 on: January 07, 2007, 08:32:11 AM »
Hi all,...
first, best wishes for 2007..   :-)
Is there any way to select all text and mtext in the entire drawing including in block, layout, and model space ?
I need to do this:
I have many diffrent text style and need to purge all them and keep only 1.
so I think i need to select all text by filtering them en change style.
But if you have any other idea....i'll keep it !
thanks.
Question aside, why write code given CAD Standards can do this?
I looked at Tim's code, though not in detail. I think it would not allow a text style to be purged if it is used in a dimension style.
IOM, code like Tim's is useful for examining a drawing. Tell me where this or these text styles are used, so I can decide beforehand whether it's safe to let CAD Standards do what it does.
Andrea
« Reply #37 on: January 07, 2007, 06:29:34 PM »
the..
....     (if (not IsLo)
Yes,..
Keep smile...
Andrea
« Reply #38 on: January 07, 2007, 06:37:18 PM »
Hi all,...
I need to do this:
thanks.
some client have standard.....
one of these want only SIMPLEX style in drawings..in 5 specific layers, all block created to layer "0" etc....
but we receive some drawing from architect and diffrent other discipline who work with there standard.
so when we receive these drawing we always need to clean all textstyle and fonts before returning the drawing to the client.
To obtain in the drawing this final result of textstyle:
Standard and SIMPLEX
« Last Edit: January 07, 2007, 06:40:50 PM by Andrea »
Keep smile...
« Reply #39 on: January 07, 2007, 06:53:19 PM »
......What do you think Tims code should do to the blocks Andrea ?
Yes,..
Lets try that again ...
When you read the code that Tim provided, what do you think it does to blocks ?
Andrea
« Reply #40 on: January 07, 2007, 07:52:41 PM »
((vl-position tempObjType '("AcDbText" "AcDbMText" "AcDbAttributeDefinition"));;detect text TYPE
     (vla-put-StyleName Obj StyName);;put the new stylename
     (if (not IsLo);;if is not in same layout
      (vla-put-Layer Obj "0");;put the text item found to layer "0"
do I'm right ?
Keep smile...
« Reply #41 on: January 07, 2007, 07:54:16 PM »
Forget posting  code and try to answer the question ..
M-dub
« Reply #42 on: January 07, 2007, 08:33:38 PM »
the..
....     (if (not IsLo)
Yes,..
Andrea,
Do you think you maybe misunderstood Kerry's question?  He's asking how the code should affect the blocks, not if it should affect the blocks.
just throwing a little hint out there ;)
« Reply #43 on: January 07, 2007, 08:52:14 PM »
Andrea,
exactly !
I originally wrote something like
What does Tim's code do to the blocks.?
but I have been accused of being rude or blunt to Andrea in the past, so I changed it to :
M-dub
« Reply #44 on: January 07, 2007, 08:54:59 PM »
Guilty as charged.  :oops:
My mistake and my apologies   :-)
