Author Topic: field justification issue  (Read 1047 times)
« on: January 03, 2007, 10:21:39 AM »
Has anyone had problems with fields that are xreffed into another drawing not retain their justification? We use the CTAB field for sheet numbers that is inserted onto a titleblock which is then xref into another drawing.
Bottom right justification in titleblock drawing:
Titleblock xref into paperspace and field shifts right?
Guest
Re: field justification issue
« Reply #1 on: January 03, 2007, 11:20:46 AM »
I've seen that.  I do the same thing here.  99.9% of the time it works.  I've seen it happen to only 1 sheet in a drawing with multiple tabs.  I couldn't figure it out so I had to fudge that one sheet.
If you find out what's making it do that, please post back.
Atook
  • AKA Tim
« Reply #2 on: January 03, 2007, 12:07:14 PM »
Might it have something to do with styles? IE the style with the same name is designated in the second drawing with a different alignment/justification?
« Reply #3 on: January 03, 2007, 12:58:51 PM »
I don't think you can assign the justification in the style? I did compare the two styles and the width factor differed in the stylename. I made them the same but no results. :realmad:
