Author Topic: Calling a express tool within a lisp?????  (Read 3482 times)
Krushert
  • FREE BEER Tomorrow!!
« on: January 02, 2007, 03:16:11 PM »
How do you call a express tool command within a lisp?
I had this once long time ago for the rev-cloud command but I deleted the lisp because rev-cloud was incorporated within new release of Autocad.  Now I want to use it for Break Line Command and I cant remember.
Re: Calling a express tool within a lisp?????
« Reply #1 on: January 02, 2007, 03:35:24 PM »
To call a lisp in a lisp that is a full command, you would call it like
(c:CommandName)
Krushert
« Reply #2 on: January 02, 2007, 04:38:58 PM »
(c:CommandName)
Thanks Tim.
I forgot the C: part.
I was getting all kinds of "nasty-grams" from Autocad with all the combinations I was trying.  :-D
I typically modify the code if the code is mine or someone else's.  But I don't like to modify Autocad's lisp.  I like to call the command after I make my changes as in this case change the layer to the right layer prior to.
Thanks Again.
« Reply #3 on: January 02, 2007, 05:06:15 PM »
You're welcome.  From what others have done is, they will look at the lisp code provided by ET, and then call the sub functions with the appropriate arguments.  I don't, but I have seen others.
